Configures, modifies, or retrieves Border Gateway Protocol (BGP) configurations.
URI | Description |
<base_URI>/config/running/router/bgp | Border Gateway Protocol (BGP). |
GET URIs | Description |
<base_URI>/config/running/router/bgp/local-as | Displays local AS number. |
<base_URI>/config/running/router/bgp/always-compare-med | Displays whether the device is set to always compare the Multi-Exit Discriminators (MEDs). |
<base_URI>/config/running/router/bgp/compare-med-empty-aspath | Displays whether comparison of Multi-Exit Discriminators (MEDs) for internal routes is enabled. |
<base_URI>/config/running/router/bgp/med-missing-as-worst | Considers routes missing MED attributes as least desirable. |
<base_URI>/config/running/router/bgp/as-path-ignore | Displays whether the comparison of the autonomous system (AS) path lengths of otherwise equal paths is enabled. |
<base_URI>/config/running/router/bgp/compare-routerid | Displays whether comparison of device IDs is enabled. |
<base_URI>/config/running/router/bgp/install-igp-cost | Enables the device to use the IGP cost instead of the default BGP4 or BGP4+ Multi-Exit Discriminator (MED) value. |
<base_URI>/config/running/router/bgp/cluster-id | Configures Route-Reflector Cluster-ID. |
<base_URI>/config/running/router/bgp/default-local-preference | Specifies the local preference value. The value can range from 0 through 65535. |
<base_URI>/config/running/router/bgp/distance/lcl-route-distance | Specifies the local BGP4 and BGP4+ distance. The value can range from 1 through 255 |
<base_URI>/config/running/router/bgp/capability | Displays capability configuration. |
<base_URI>/config/running/router/bgp/capability/as4-enable | Enables 4-byte autonomous system number (ASN) capability. |
<base_URI>/config/running/router/bgp/maxas-limit/in/num-as-in-path | Configures the number of autonomous systems in the AS-PATH attribute. |
<base_URI>/config/running/router/bgp/enforce-first-as | Enforces the use of the first autonomous system (AS) path for external BGP (EBGP) routes. |
<base_URI>/config/running/router/bgp/fast-external-fallover | Resets the session if a link to an EBGP peer goes down. |
<base_URI>/config/running/router/bgp/timers | Diplsplays timers information. |
<base_URI>/config/running/router/bgp/timers/hold-time | Displays the interval in seconds that a device waits to receive a keepalive message from a peer before declaring that peer dead. |
<base_URI>/config/running/router/bgp/log-dampening-debug | Logs dampening debug messages. |
<base_URI>/config/running/router/bgp/confederation | Displays confederation information. |
<base_URI>/config/running/router/bgp/confederation/identifier | Specifies an autonomous system number (ASN). |
<base_URI>/config/running/router/bgp/confederation/peers | Displays the autonomous system (AS) numbers for BGP peers that will belong to the confederation. |
<base_URI>/config/running/router/bgp/neighbor | Displays neighbor router. |
<base_URI>/config/running/router/bgp/neighbor/neighbor-peer-grp | Displays neighbor peer group. |
<base_URI>/config/running/router/bgp/neighbor/peer-grps/neighbor-peer-grp/address | Displays neighbor address. |
<base_URI>/config/running/router/bgp/neighbor/neighbor-peer-grp/{group-name}/shutdown | Displays peer group shutdown status. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/redistribute/ospf | Displays OSPF redistribution status. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/redistribute/isis | Dipslays IS-IS redistribution status. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/redistribute/connected | Displays unicast connected mode configuration. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/redistribute/static | Displays unicast static mode configuration. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/vrf/{vrf-name}/redistribute/ospf | Displays OSPF redistribution status. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/vrf/{vrf-name}/redistribute/connected | Displays connected redistribution. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/vrf/{vrf-name}/redistribute/static | Displays static redistribution. |
POST URIs | Payload | Description |
<base_URI>/config/running/router | <bgp></bgp> | Enters router BGP configuration mode. |
<base_URI>/config/running/router/bgp | <local-as>{unit32}</local-as> | Configures Local AS. |
<base_URI>/config/running/router/bgp/neighbor | <neighbor-peer-grp><address>{string}</address><peer-group>{enumeration}</peer-group></neighbor-peer-grp> | Configures neighbor peer group. |
<base_URI>/config/running/router/bgp/neighbor | <neighbor-peer-grp><address>{string}</address><peer-group>true</peer-group><remote-as>{unit32}</remote-as></neighbor-peer-grp> | Configures Remote AS for neighbor peer group. |
<base_URI>/config/running/router/bgp/neighbor/neighbor-peer-grp/{group-name} | <remote-as>{unit32}</remote-as> | Configures Remote AS. |
<base_URI>/config/running/router/bgp/neighbor | <neighbor-addr><address>{ip-address}</address><remote-as>{unit32}</remote-as><peer-group>{group-name}</peer-group></neighbor-addr> | Configures neighbor address, remote AS, and peer group. |
<base_URI>/config/running/router/bgp/neighbor | <neighbor-addr><address>{ip-address}</address><remote-as>{unit32}</remote-as></neighbor-addr> | Configures neighbor address and remote AS. |
<base_URI>/config/running/router/bgp/neighbor/neighbor-addr/{ip-address} | <peer-group>{group-name}</peer-group> | Configures peer group. |
<base_URI>/config/running/router/bgp/neighbor/neighbor-addr/{ip-address}/update-source | <loopback>{unit32}</loopback> | Configures loopback. |
<base_URI>/config/running/router/bgp/neighbor/neighbor-addr/{ip-address}/next-hop-self | <next-hop-self-status>{enumeration}</next-hop-self-status> | Configures next hop self status. |
<base_URI>/config/running/router/bgp/neighbor/neighbor-addr/{ip-address}/ebgp-multihop | <ebgp-multihop-count>{unit32}</ebgp-multihop-count> | Configures EBGP multi-hop count. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/redistribute/ospf | <redistribute-ospf>{enumeration}</redistribute-ospf> | Configures OSPF redistribution. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/redistribute | <isis></isis> | Configures ISIS redistribution. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/redistribute/static | <redistribute-static>{enumeration}</redistribute-static> | Configures static redistribution. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/redistribute/connected | <redistribute-connected>{enumeration}</redistribute-connected> | Configures connected redistribution. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast | <vrf><vrf-name>{string}</vrf-name></vrf> | Configures VRF for address-family unicast. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/vrf/{vrf-name}/neighbor | <af-ipv4-neighbor-addr><address>{ip-address}</address><remote-as>{unit32}</remote-as><peer-group>{group-name}</peer-group></af-ipv4-neighbor-addr> | Configures neighbor. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/vrf/{vrf-name}/neighbor/af-ipv4-neighbor-addr/{ip-address}/update-source | <loopback>{unit32}</loopback> | Configures loopback. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/vrf/{vrf-name}/neighbor/af-ipv4-neighbor-addr/{ip-address}/next-hop-self | <next-hop-self-status>{enumeration}</next-hop-self-status> | Configures next hop self status. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/vrf/{vrf-name}/neighbor/af-ipv4-neighbor-addr/{ip-address}/ebgp-multihop | <ebgp-multihop-count>{unit32}</ebgp-multihop-count> | Configures EBGP multi-hop count. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/vrf/{vrf-name}/redistribute/ospf | <redistribute-ospf>{enumeration}</redistribute-ospf> | Configures OSPF redistribution. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/vrf/{vrf-name}/redistribute/connected | <redistribute-connected>{enumeration}</redistribute-connected> | Configures connected redistribution. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/vrf/{vrf-name}/redistribute/static | <redistribute-static>{enumeration}</redistribute-static> | Configures static redistribution. |
<base_URI>/config/running/router/bgp/neighbor/neighbor-peer-grp/{group-name} | <description>{string}</description> | Configures description. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast | <network><network-ipv4-address>{ip-address/mask}</network-ipv4-address></network> | Configures IPv4 unicast address family. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast | <network><network-ipv4-address>{ip-address/mask}</network-ipv4-address><weight>{unit32}</weight></network> | Configures network weight. |
<base_URI>/config/running/router/bgp/neighbor/neighbor-peer-grp/{group-name}/shutdown | <shutdown-status>{enumeration}</shutdown-status> | Shuts down the peer group. |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/neighbor/af-ipv4-neighbor-address/{ip-address}/route-map/in | <neighbor-route-map-name-direction-in>{string}</neighbor-route-map-name-direction-in> | Configures route map direction. |
PATCH URIs | Payload | Description |
<base_URI>/config/running/router/bgp | <bgp></bgp> | Configures Router BGP. |
<base_URI>/config/running/router/bgp/local-as | <local-as>{unit32}</local-as> | Configures local AS. |
<base_URI>/config/running/router/bgp/local-as | <bgp><local-as>{unit32}</local-as></bgp> | Configures local AS. |
<base_URI>/config/running/router/bgp/neighbor/neighbor-peer-grp | <neighbor-peer-grp><address>{group-name}</address><peer-group>{enumeration}</peer-group></neighbor-peer-grp> | Configures peer group. |
<base_URI>/config/running/router/bgp/neighbor/neighbor-peer-grp/{group-name} | <peerGroup1><remote-as>{enumeration}</remote-as></peerGroup1> | Configures peer group Remote AS. |
PUT URIs | Payload | Description |
<base_URI/config/running/router/bgp/neighbor/neighbor-peer-grp/{group-name}/remote-as | <remote-as>{unit32}</remote-as> | Configures remote AS. |
DELETE URIs |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/network/{ip-address} |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/vrf/{vrf-name}/network/{ip-address} |
<base_URI>/config/running/router/bgp/address-family/ipv4/unicast/network |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/router/bgp
None
<bgp xmlns="urn:brocade.com:mgmt:brocade-bgp" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/router/bgp/default"> <local-as>124</local-as> <always-compare-med>true</always-compare-med> <compare-med-empty-aspath>true</compare-med-empty-aspath> <med-missing-as-worst>true</med-missing-as-worst> <as-path-ignore>true</as-path-ignore> <compare-routerid>true</compare-routerid> <install-igp-cost>true</install-igp-cost> <cluster-id y:self="/rest/config/running/router/bgp/default/cluster-id"> <id>122</id> </cluster-id> <default-local-preference>100</default-local-preference> <distance y:self="/rest/config/running/router/bgp/default/distance"> <ext-route-distance>20</ext-route-distance> <int-route-distance>25</int-route-distance> <lcl-route-distance>22</lcl-route-distance> </distance> <capability y:self="/rest/config/running/router/bgp/default/capability"> <as4-enable>true</as4-enable> </capability> <maxas-limit y:self="/rest/config/running/router/bgp/default/maxas-limit"> <in y:self="/rest/config/running/router/bgp/default/maxas-limit/in"> <num-as-in-path>250</num-as-in-path> </in> </maxas-limit> <enforce-first-as>true</enforce-first-as> <fast-external-fallover>true</fast-external-fallover> <timers y:self="/rest/config/running/router/bgp/default/timers"> <keep-alive>65</keep-alive> <hold-time>170</hold-time> </timers> <log-dampening-debug>true</log-dampening-debug> <auto-shutdown-new-neighbors>true</auto-shutdown-new-neighbors> <confederation y:self="/rest/config/running/router/bgp/default/confederation"> <identifier>20000</identifier> <peers>100 120 130 140 1200 2300 5600 40000</peers> </confederation> <bfd xmlns="urn:brocade.com:mgmt:brocade-bgp" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/router/bgp/bfd"> <holdover-interval>10</holdover-interval> <interval xmlns="urn:brocade.com:mgmt:brocade-bfd" y:self="/rest/config/running/router/bgp/bfd/interval"> <min-tx>75</min-tx> <min-rx>80</min-rx> <multiplier>3</multiplier> </interval> </bfd> <neighbor y:self="/rest/config/running/router/bgp/default/neighbor/INTERNAL"> <address>INTERNAL</address> </neighbor> <neighbor y:self="/rest/config/running/router/bgp/default/neighbor/PeerGroup1"> <address>PeerGroup1</address> </neighbor> <neighbor xmlns="urn:brocade.com:mgmt:brocade-bgp" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/router/bgp/neighbor"> <neighbor-peer-grp y:self="/rest/config/running/router/bgp/neighbor/neighbor-peer-grp/peer1"> <address>peer1</address> <bfd y:self="/rest/config/running/router/bgp/neighbor/neighbor-peer-grp/peer1/bfd"> <holdover-interval>10</holdover-interval> <interval xmlns="urn:brocade.com:mgmt:brocade-bfd" y:self="/rest/config/running/router/bgp/neighbor/ neighbor-peer-grp/peer1/bfd/interval"> <min-tx>70</min-tx> <min-rx>60</min-rx> <multiplier>10</multiplier> </interval> </bfd> </neighbor-peer-grp> <neighbor-ipv6-addr y:self="/rest/config/running/router/bgp/neighbor/neighbor-ipv6-addr/2004:384d::21:22"> <address>2004:384d::21:22</address> <bfd y:self="/rest/config/running/router/bgp/neighbor/neighbor-ipv6-addr/2004:384d::21:22/bfd"> <holdover-interval>25</holdover-interval> <interval xmlns="urn:brocade.com:mgmt:brocade-bfd" y:self="/rest/config/running/router/bgp/neighbor/ neighbor-ipv6-addr/2004:384d::21:22/bfd/interval"> <min-tx>60</min-tx> <min-rx>60</min-rx> <multiplier>40</multiplier> </interval> </bfd> </neighbor-ipv6-addr> <neighbor-addr xmlns="urn:brocade.com:mgmt:brocade-bgp" y:self="/rest/config/running/router/bgp/neighbor/ neighbor-addr/1.1.1.1"> <address>1.1.1.1</address> <ebgp-btsh></ebgp-btsh> <bfd y:self="/rest/config/running/router/bgp/neighbor/neighbor-addr/1.1.1.1/bfd"> <holdover-interval>20</holdover-interval> <interval xmlns="urn:brocade.com:mgmt:brocade-bfd" y:self="/rest/config/running/router/bgp/neighbor/ neighbor-addr/1.1.1.1/bfd/interval"> <min-tx>5000</min-tx> <min-rx>3000</min-rx> <multiplier>4</multiplier> </interval> </bfd> </neighbor-addr> </neighbor> <neighbor y:self="/rest/config/running/router/bgp/default/neighbor/VCS_8192"> <address>VCS_8192</address> </neighbor> <address-family y:self="/rest/config/running/router/bgp/default/address-family"> <ipv4 y:self="/rest/config/running/router/bgp/default/address-family/ipv4"> <unicast y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast"> <bgp-redistribute-internal>true</bgp-redistribute-internal> <redistribute y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast/redistribute"> <connected y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast/redistribute/connected"> <redistribute-connected>true</redistribute-connected> <metric>23</metric> <route-map>route1</route-map> </connected> <ospf y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast/redistribute/ospf"> <redistribute-ospf>true</redistribute-ospf> <match y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast/redistribute/ospf/match"/> <metric>26</metric> </ospf> <static y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast/redistribute/static"> <redistribute-static>true</redistribute-static> <metric>30</metric> <route-map>route1</route-map> </static> </redistribute> <aggregate-address y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast/ aggregate-address/%2210.11.12.0/24%22"> <aggregate-ip-prefix>10.11.12.0/24</aggregate-ip-prefix> <advertise-map>map2</advertise-map> <as-set>true</as-set> <attribute-map>map2</attribute-map> <summary-only>true</summary-only> <suppress-map>map1</suppress-map> </aggregate-address> <neighbor y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast/neighbor/INTERNAL"> <address>INTERNAL</address> </neighbor> <neighbor y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast/neighbor/10.11.132.7"> <address>10.11.132.7</address> </neighbor> <neighbor xmlns="urn:brocade.com:mgmt:brocade-bgp" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/router/bgp/address-family/ipv4/unicast/neighbor"> <af-ipv4-neighbor-address y:self="/rest/config/running/router/bgp/address-family/ipv4/unicast/neighbor/ af-ipv4-neighbor-address/1.1.1.1"> <address>1.1.1.1</address> <activate>true</activate> <af-ipv4-neighbor-address> </neighbor> <neighbor xmlns="urn:brocade.com:mgmt:brocade-bgp" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/router/bgp/address-family/ipv4/unicast/neighbor"> <af-ipv4-neighbor-address xmlns="urn:brocade.com:mgmt:brocade-bgp" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/router/bgp/address-family/ipv4/unicast/neighbor/af-ipv4-neighbor-address/10.10.10.1"> <address>10.10.10.1</address> <route-reflector-client>true</route-reflector-client> <additional-paths y:self="/rest/config/running/router/bgp/address-family/ipv4/unicast/neighbor/ af-ipv4-neighbor-address/10.10.10.1/additional-paths"> <advertise y:self="/rest/config/running/router/bgp/address-family/ipv4/unicast/neighbor/ af-ipv4-neighbor-address/10.10.10.1/additional-paths/advertise"> <best>1</best> </advertise> </additional-paths> <capability y:self="/rest/config/running/router/bgp/address-family/ipv4/unicast/neighbor/ af-ipv4-neighbor-address/10.10.10.1/capability"> <additional-paths y:self="/rest/config/running/router/bgp/address-family/ipv4/unicast/ neighbor/af-ipv4-neighbor-address/10.10.10.1/capability/additional-paths"> <add-path-both>true</add-path-both> <receive>true</receive> </additional-paths> </capability> </af-ipv4-neighbor-address> </neighbor> <network y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast/network/%2210.11.12.0/24%22"> <network-ipv4-address>10.11.12.0/24</network-ipv4-address> <weight>100</weight> <backdoor>true</backdoor> <route-map>map1</route-map> </network> <static-network y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast/static-network/ %2210.10.12.0/24%22"> <static-network-address>10.10.12.0/24</static-network-address> <distance>10</distance> </static-network> <maximum-paths y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast/maximum-paths"> <ebgp>2</ebgp> <ibgp>3</ibgp> <use-load-sharing>true</use-load-sharing> </maximum-paths> <multipath y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast/multipath"> <ibgp>true</ibgp> <multi-as>true</multi-as> </multipath> <always-propagate>true</always-propagate> <default-information-originate>true</default-information-originate> <rib-route-limit>2000</rib-route-limit> <dampening y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast/dampening"> <half-time>20</half-time> <reuse-value>755</reuse-value> <start-suppress-time>2100</start-suppress-time> <max-suppress-time>45</max-suppress-time> </dampening> <default-metric>1</default-metric> <table-map y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast/table-map"/> <update-time>10</update-time> <graceful-restart y:self="/rest/config/running/router/bgp/default/address-family/ipv4/unicast/graceful-restart"> <restart-time>250</restart-time> <purge-time>200</purge-time> <stale-routes-time>300</stale-routes-time> </graceful-restart> <vrf y:self="/rest/config/running/router/bgp/address-family/ipv4/unicast/vrf/red"> <vrf-name>red</vrf-name> <redistribute y:self="/rest/config/running/router/bgp/address-family/ipv4/unicast/vrf/red/redistribute"> <bgp y:self="/rest/config/running/router/bgp/address-family/ipv4/unicast/vrf/red/redistribute/bgp"> <metric>250</metric> <route-map>map1</route-map> </bgp> </redistribute> </vrf> </unicast> </ipv4> <ipv6 y:self="/rest/config/running/router/bgp/default/address-family/ipv6"> <unicast y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast"> <bgp-redistribute-internal>true</bgp-redistribute-internal> <redistribute y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/redistribute"> <connected y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/redistribute/connected"> <redistribute-connected>true</redistribute-connected> <metric>23</metric> </connected> <ospf y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/redistribute/ospf"> <redistribute-ospf>true</redistribute-ospf> <match y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/redistribute/ospf/match"/> <metric>34</metric> </ospf> <static y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/redistribute/static"> <redistribute-static>true</redistribute-static> <metric>45</metric> <route-map>redist107_1</route-map> </static> </redistribute> <aggregate-address y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/aggregate-address/ %22fd80:122:122:122::/64%22"> <aggregate-ip-prefix>fd80:122:122:122::/64</aggregate-ip-prefix> </aggregate-address> <network y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/network/%22131::1/128%22"> <network-ipv6-address>131::1/128</network-ipv6-address> </network> <network y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/network/ %22fd80:122:122:122:105:105:0:122/128%22"> <network-ipv6-address>fd80:122:122:122:105:105:0:122/128 </network-ipv6-address> </network> <neighbor y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/neighbor/vcs_2122"> <address>vcs_2122</address> </neighbor> <neighbor y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/neighbor/VCS_8192_rr"> <address>VCS_8192_rr</address> </neighbor> <neighbor y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/neighbor/fd80:2001:2040::40"> <address>fd80:2001:2040::40</address> </neighbor> <neighbor xmlns="urn:brocade.com:mgmt:brocade-bgp" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor"> <af-ipv6-neighbor-address y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/ af-ipv6-neighbor-address/2001:2018:8192::124"> <address>2001:2018:8192::124</address> <send-community y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/ af-ipv6-neighbor-address/2001:2018:8192::124/send-community"> </send-community> <capability y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/ af-ipv6-neighbor-address/2001:2018:8192::124/capability"> <orf y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/af-ipv6-neighbor-address/ 2001:2018:8192::124/capability/orf"> <prefixlist y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/ af-ipv6-neighbor-address/2001:2018:8192::124/capability/orf/prefixlist"> </prefixlist> </orf> <additional-paths y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/ af-ipv6-neighbor-address/2001:2018:8192::124/capability/additional-paths"> </additional-paths> </capability> <additional-paths y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/ af-ipv6-neighbor-address/2001:2018:8192::124/additional-paths"> <advertise y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/ af-ipv6-neighbor-address/2001:2018:8192::124/additional-paths/advertise"> </advertise> </additional-paths> <activate>true</activate> <allowas-in>3</allowas-in> <enable-peer-as-check>true</enable-peer-as-check> <filter-list y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/ af-ipv6-neighbor-address/2001:2018:8192::124/filter-list"> </filter-list> <maximum-prefix y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/ af-ipv6-neighbor-address/2001:2018:8192::124/maximum-prefix"> </maximum-prefix> <default-originate y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/ af-ipv6-neighbor-address/2001:2018:8192::124/default-originate"> </default-originate> <prefix-list y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/ af-ipv6-neighbor-address/2001:2018:8192::124/prefix-list"> </prefix-list> <route-map y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/ af-ipv6-neighbor-address/2001:2018:8192::124/route-map"> <in y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/ af-ipv6-neighbor-address/2001:2018:8192::124/route-map/in"> </in> <out y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/ af-ipv6-neighbor-address/2001:2018:8192::124/route-map/out"> </out> </route-map> <unsuppress-map y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/neighbor/ af-ipv6-neighbor-address/2001:2018:8192::124/unsuppress-map"> </unsuppress-map> </af-ipv6-neighbor-address> </neighbor> <maximum-paths y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/maximum-paths"> <ebgp>2</ebgp> <ibgp>2</ibgp> <use-load-sharing>true</use-load-sharing> </maximum-paths> <multipath y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/multipath"/> <always-propagate>true</always-propagate> <default-information-originate>true</default-information-originate> <rib-route-limit>1000</rib-route-limit> <dampening y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/dampening"> <half-time>30</half-time> <reuse-value>1100</reuse-value> <start-suppress-time>2100</start-suppress-time> <max-suppress-time>45</max-suppress-time> </dampening> <default-metric>2</default-metric> <table-map y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/table-map"/> <update-time>10</update-time> <graceful-restart y:self="/rest/config/running/router/bgp/default/address-family/ipv6/unicast/graceful-restart"> <restart-time>1400</restart-time> <purge-time>1200</purge-time> <stale-routes-time>1600</stale-routes-time> </graceful-restart> <vrf y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/vrf/vrf1"> <vrf-name>vrf1</vrf-name> <redistribute y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/vrf/vrf1/redistribute"> <bgp y:self="/rest/config/running/router/bgp/address-family/ipv6/unicast/vrf/vrf1/redistribute/bgp"> <metric>500</metric> <route-map>map2</route-map> </bgp> </redistribute> </vrf> </unicast> </ipv6> </address-family> </bgp>
The following is an example of the POST operation to configure BGP neighbor.
http://host:80/rest/config/running/router/bgp/neighbor
<neighbor-peer-grp> <address>peerGroup1</address> <peer-group>true</peer-group> </neighbor-peer-grp>
None
The following is an example of the DELETE to remove router BGP configuration.
None
None
