Displays dhcp snooping information
URI | Description |
<base_URI>/operational-state/dhcp-snooping-state | Displays dhcp snooping information including status of dhcp snooping on device, status of dhcp snooping information option, dhcp snooping enabled VLANs, and trusted interfaces. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example shows the complete cURL command and server response for the
dhcp-snooping-state
GET operation.
http://host:80/rest/operational-state/dhcp-snooping-state
curl -H "Accept: application/vnd.operational-state.resource+xml" -H "Resource-Depth: 6" -u "lab:Tester**" http://10.20.229.40:80/rest/operational-state/dhcp-snooping-state
<data xmlns="http://brocade.com/ns/rest" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/operational-state"> <dhcp-snooping-state xmlns="urn:brocade.com:mgmt:brocade-dhcp-operational" y:self="/rest/operational-state/dhcp-snooping-state"> <dhcp-snooping>false</dhcp-snooping> <information-option>false</information-option> <allowed-untrusted>false</allowed-untrusted> <enabled-vlans>" NONE"</enabled-vlans> <trusted-interfaces>" NONE"</trusted-interfaces> </dhcp-snooping-state> </data>
Release version | History |
18r.2.00 | This API call was introduced. |
