Configures, retrieves, and modifies IPv6 address prefix list.
URI | Description |
<base_URI>/config/running/ipv6/prefix-list/{name},{seq-keyword},{instance} | Configures IPv6 address prefix list. |
GET URIs | Description |
<base_URI>/config/running/ipv6/prefix-list/{name},{seq-keyword},{instance} | Retrieves IPv6 address prefix list. |
<base_URI>/config/running/ipv6/prefix-list/{name},{seq-keyword},{instance}/ge | Retrieves minimum IPv6 prefix length. |
<base_URI>/config/running/ipv6/prefix-list/{name},{seq-keyword},{instance}/le | Retrieves maximum IPv6 prefix length. |
PATCH URIs | Payload | Description |
<base_URI>/config/running/ipv6/prefix-list/{name},{seq-keyword},{instance} | <prefix-list><action-ipp>{action-t}</action-ipp><ipv6-prefix-ipp>{inet:ipv6-prefix}</ipv6-prefix-ipp></prefix-list> | Configures IPv6 address prefix list. |
<base_URI>/config/running/ipv6/prefix-list/{name},{seq-keyword},{instance} | <prefix-list><ge>{ipv6-prefix-len-t}</ge></prefix-list> | Configures minimum IPv6 prefix length. |
<base_URI>/config/running/ipv6/prefix-list/{name},{seq-keyword},{instance} | <prefix-list><le>{ipv6-prefix-len-t}</le></prefix-list> | Configures maximum IPv6 prefix length. |
PUT URIs | Payload | Description |
<base_URI>/config/running/ipv6/prefix-list/{name},{seq-keyword},{instance}/ge | <ge>{ipv6-prefix-len-t}</ge> | Configures minimum IPv6 prefix length. |
<base_URI>/config/running/ipv6/prefix-list/{name},{seq-keyword},{instance}/le | <le>{ipv6-prefix-len-t}</le> | Configures maximum IPv6 prefix length. |
DELETE URIs |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/ipv6/prefix-list/PR6LIST4,seq,5/
<prefix-list xmlns="urn:brocade.com:mgmt:brocade-ip-policy" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/ipv6/prefix-list/PR6LIST4%2Cseq%2C5"> <name>PR6LIST4</name> <seq-keyword>seq</seq-keyword> <instance>5</instance> <action-ipp>permit</action-ipp> <ipv6-prefix-ipp>2001:5555:2222:4444::/64</ipv6-prefix-ipp> <ge>120</ge> <le>128</le> </prefix-list>
None
The following example uses the PUT option to configure IPv6 address prefix list.
http://host:80/rest/config/running/config/running/ipv6/prefix-list/PR6LIST2,seq,5/ge
None
The following example uses the DELETE option to remove IPv6 address prefix list.
http://host:80/rest/config/running/ipv6/prefix-list/PR6LIST4%2Cseq%2C5
None
None
