Configures, retrieves, and modifies an IP address on an interface.
| URI | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip | Configures an IP address on an interface. |
| GET URIs | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip | Configures an IP address on an interface. Allowed interface types: Management, Ethernet, Port-channel, Ve, Loopback. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/address | Specifies the IP address. Allowed interface types: Management, Management, Ethernet, Port-channel, Ve, Loopback. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip | <address><address>{inet:ipv4-prefix}</address></address> | Specifies the mask for the associated IP subnet. Allowed interface types: Ethernet, Ve, Loopback. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ | <shutdown>{enumeration}</shutdown> | Shuts down the interface. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/address | <address><address>{inet:ipv4-prefix}</address></address> | Specifies the mask for the associated IP subnet. Allowed interface types: Ethernet, Ve, Loopback. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/shutdown | <shutdown>{enumeration}</shutdown> | Shuts down the interface. Allowed interface types: Ethernet, Port-channel, Ve. |
| DELETE URIs |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/mtu |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve an IP address.
http://host:80/rest/config/running/interface/ethernet/%220/10%22/ip/address
None
<address xmlns="urn:brocade.com:mgmt:brocade-ip-config" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/interface/Ethernet/%220/10%22/ip/address/%2210.20.1.1/20%22"> <address>10.20.1.1/20</address> </address>
The following example uses the PATCH option to configure an IP address on an interface.
<address><address>10.20.1.1/20</address></address>
None
The following example uses the DELETE option to remove an IP address on an interface.
None
None
