interface/{interface-type}/{interface-name}/ip/igmp
Configures, modifies, or retrieves the Internet Group Management Protocol (IGMP).
Resource URIs
URI Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp Configures IGMP. Valid interface type: Ethernet.
GET URIs Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp Retrieves IGMP. Valid interface type: Ethernet.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/last-member-query-interval Retrieves the IGMP last-member query interval for an interface. Valid interface type: Ethernet.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/query-interval Retrieves the IGMP query interval for an interface. Valid interface type: Ethernet.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/query-max-response-time Retrieves the maximum response time for IGMP queries for an interface. Valid interface type: Ethernet.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/immediate-leave Removes a group from the IGMP table immediately following receipt of a Leave Group request. Valid interface type: Ethernet.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/version Retrieves the IGMP version on a device. Valid interface type: Ethernet.
POST URIs Payload Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp <static-group><igmpl3-sg-addr>{igmpl3-sg-addr}</igmpl3-sg-addr></static-group> Configures the IGMP static group membership entries for a specific interface.Valid interface type: Ethernet.
PATCH URIs Payload Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp "<igmp><last-member-query-interval>{unit32}</last-member-query-interval></igmp> Configures the IGMP last-member query interval for an interface. Valid interface type: Ethernet.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp "<igmp><query-interval>{unit32}</query-interval></igmp> Configures the IGMP query interval for an interface. Valid interface type: Ethernet.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp <igmp><query-max-response-time>{unit32}</query-max-response-time></igmp> Configures the maximum response time for IGMP queries for an interface. Valid interface type: Ethernet.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp <igmp><immediate-leave>{enumeration}</immediate-leave></igmp> Removes a group from the IGMP table immediately following receipValid interface type: Ethernet.t of a Leave Group request.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp <igmp><version>{unit32}</version></igmp> Configures the IGMP version on a device. Valid interface type: Ethernet.
PUT URIs Payload Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/last-member-query-interval <last-member-query-interval>{unit32}</last-member-query-interval> Configures the IGMP last-member query interval for an interface. Valid interface type: Ethernet.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/query-interval <query-interval>{unit32}</query-interval> Configures the IGMP query interval for an interface. Valid interface type: Ethernet.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/query-max-response-time "<query-max-response-time>{unit32}</query-max-response-time> Configures the maximum response time for IGMP queries for an interface. Valid interface type: Ethernet.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/immediate-leave "<immediate-leave>{enumeration}</immediate-leave> Removes a group from the IGMP table immediately following receipt of a Leave Group request. Valid interface type: Ethernet.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/version "<version>{unit32}</version> Configures the IGMP version on a device. Valid interface type: Ethernet.
DELETE URIs
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/static-group/{igmpl3-sg-addr}
Parameters
interface-type
Valid interface type:Ethernet only.
Specifies the the IGMP last-member query interval time in milliseconds. Range is from 100 through 25500 milliseconds. The default is 1000.
query-interval
Specifies the IGMP query interval time in seconds. Range is from 1 through 18000 seconds. The default is 125.
Specifies the maximum response time for IGMP queries for an interface in seconds. Range is from 1 through 25 seconds. The default is 10.
version
Specifies the IGMP version number on a device: 1, 2, or 3. Version 2 is the default.
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/Ethernet/%221/1%22/ip/igmp
None
<igmp xmlns="urn:brocade.com:mgmt:brocade-igmp" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/interface/Ethernet/%223/12%22/ip/igmp">
  <last-member-query-interval>2000</last-member-query-interval>
  <query-interval>200</query-interval>
  <query-max-response-time>20</query-max-response-time>
  <immediate-leave>true</immediate-leave>
  <version>3</version>
</igmp>
URI
The following is an example of the POST operation to configure the IGMP static group membership entries for a specific interface.
http://host:80/rest/config/running/interface/Ve/11/ip/igmp
<static-group><igmpl3-sg-addr>230.100.100.100</igmpl3-sg-addr></static-group>
None
URI
The following is an example of the DELETE operation to remove managed config flag on a specified interface.
http://host:80/rest/config/running/interface/Ve/11/ip/igmp/last-member-query-interval
None
None
