Creates role-based access permissions (RBAC) associated with a role.
| URI | Description |
| <base_URI>/config/running/rule | Creates RBAC associated with a role. |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The switch obtains its configuration from the principal node. Enabling this feature solves most node-segmentation issues.
The following example uses the GET option to retrieve the configuration details.
http://host:80/config/runnin/rule/5
None
<ruleurn:brocade.com:mgmt:brocade-aaa"" xmlns:y=""http://brocade.com/ns/rest"" y:self=""/rest/config/running/rule/5"">
<index>5</index>
<action>reject</action>
<operation>read-write</operation>
<role>testRole</role>
<command y:self=""/rest/config/running/rule/5/command"">
<show y:self=""/rest/config/running/rule/5/command/show"">
<running-config y:self=""/rest/config/running/rule/5/command/show/running-config"">
</running-config>
</show>
</command>
</rule>
The following example uses the PATCH option to modify the RBAC associated with a role.
http://host:80/rest/config/running/rule/5
<rule> <index>5</index> <action>reject</action> <operation>read-write</operation> <role>testRole</role> </rule>
None
The following example uses the DELETE option to delete the RBAC associated with a role.
None
None
