interface/{interface-type}/{interface-name}/ipv6/access-group
Configures, modifies, or retrieves the Internet Protocol version 6 (IPv6) access group.
Resource URIs
URI Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/access-group
Configures IPv6 access group. Valid interface types: Ethernet, Port-channel, Ve
GET URIs Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/access-group/{ipv6-access-list},{ip-direction} Retrieves IPv6 access group. Valid interface types: Ethernet, Port-channel, Ve, Management.
POST URIs Payload Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/access-group <access-group><ipv6-access-list>{acl-name}</ipv6-access-list><ip-direction>{direction}</ip-direction></access-group> Configures an IPv6 access group. Valid interface types: Ethernet, Port-channel, Ve.
<base_URI>/config/running/ipv6/receive <access-group><acl-name>{acl-name}</acl-name></access-group> Configures IPv6 Receive Access group.
DELETE URIs
<base_URI>/config/running/ipv6/receive/access-group/{acl-name}
Parameters
ipv6-access-list
Specifies the name of the standard or extended IP access list.
ip-direction
Specifies the binding direction.
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/Ethernet/%222/2%22/ipv6/access-group/traf_ext3,in
None
<access-group xmlns="urn:brocade.com:mgmt:brocade-ipv6-access-list" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/interface/Ethernet/%222/2%22/ipv6/access-group/traf_ext3%2Cin">
  <ipv6-access-list>traf_ext3</ipv6-access-list>
  <ip-direction>in</ip-direction>
</access-group>
URI
The following is an example of the POST operation to add an access-group.
<access-group>
</access-group>
None
URI
The following is an example of the DELETE operation to remove the access-group configuration.
None
None
