prefix-independent-convergence
Configures prefix-independent-convergence.
Resource URIs
URI Description
<base_URI>/config/running/prefix-independent-convergence
Parameters
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://<srvrip>:80/rest/config/running/prefix-independent-convergence
None
