Displays LINK-OAM operational information
| URI | Description |
| <base_URI>/operational-state/loam-state | Displays LINK-OAM operational information. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example shows the complete cURL command and server response for the
loam-state GET operation.
http://host:80/rest/operational-state/loam-state
curl -H "Accept: application/vnd.operational-state.resource+xml" -H "Resource-Depth: 6" -u "lab:Tester**" http://10.20.229.40:80/rest/operational-state/loam-state
<data xmlns="http://brocade.com/ns/rest" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/operational-state"> <loam-state xmlns="urn:brocade.com:mgmt:brocade-dot1ag-operational" y:self="/rest/operational-state/loam-state"> </loam-state> </data>
| Release version | History |
| 18r.2.00 | This API call was introduced. |
