get-tunnel-statistics
Retrieves tunnel statistics - count of bytes and frames transmitted and received.
Resource URIs
URI Description
<base_URI>/operations/get-tunnel-statistics Retrieves tunnel statistics - count of bytes and frames transmitted and received. Output records are sorted in ascending order of tunnel ID.
Input Parameters
page-cursor
Opaque data identifying the next page, returned by previous RPC call. RPC returns first page data if this value is not present or empty.
node-id
Node from which the tunnel statistics is to be retrieved. If not specified, data is retrieved from all nodes.
tunnel-id-type
Filter by tunnel ID. Output can have at most only one tunnel information. The last-rcvd-record-id parameter is ignored.
filter-by-mode
Filter by tunnel mode.
case filter-by-gateway
Filter by overlay gateway name.
Output Parameters
id
Displays the tunnel ID.
tx-frames
Displays the number of frames transmitted.
tx-bytes
Displays the number of bytes transmitted
rx-frames
Displays the number of frames received.
rx-bytes
Displays the number of bytes received. Value will not be present if the hardware does not support rx byte counter.
next-page-cursor
Opaque data identifying the next page. Client must pass this value as 'page-cursor' parameter in following RPC to retrieve next page tunnel data. Value will not be present if no more tunnel records exist i.e. if current page is the last page.
Usage Guidelines
Only POST operation is supported.
URI
http://host:80/rest/operations/get-tunnel-statistics
<get-tunnel-statistics></get-tunnel-statistics>
