Displays the OAM packet statistics.
| URI | Description |
| <base_URI>/operational-state/mpls-state/statistics-oam | Displays the OAM packet statistics. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
http://host:80/rest/operational-state/mpls-state/statistics-oam
None
<statistics-oam xmlns="urn:brocade.com:mgmt:brocade-mpls-operational" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/operational-state/mpls-state/statistics-oam">
<usr-ping-count>1</usr-ping-count>
<usr-traceroute-count>1</usr-traceroute-count>
<echo-req-sent-count>8</echo-req-sent-count>
<echo-req-received-count>0</echo-req-received-count>
<echo-req-timeout-count>0</echo-req-timeout-count>
<echo-resp-sent-count>0</echo-resp-sent-count>
<echo-resp-received-count>8</echo-resp-received-count>
<return-codes y:self="/rest/operational-state/mpls-state/statistics-oam/return-codes/3">
<number>3</number>
<name>Egress</name>
<tx-count>0</tx-count>
<rx-count>6</rx-count>
</return-codes>
<return-codes y:self="/rest/operational-state/mpls-state/statistics-oam/return-codes/8">
<number>8</number>
<name>Transit</name>
<rx-count>2</rx-count>
</return-codes>
<return-codes y:self="/rest/operational-state/mpls-state/statistics-oam/return-codes/0">
<number>0</number>
<name>"No return code"</name>
<rx-count>0</rx-count>
</return-codes>
<return-codes y:self="/rest/operational-state/mpls-state/statistics-oam/return-codes/1">
<number>1</number>
<name>"Malformed request"</name>
</return-codes>
<return-codes y:self="/rest/operational-state/mpls-state/statistics-oam/return-codes/2">
<number>2</number>
<name>"Unsupported TLV"</name>
</return-codes>
<return-codes y:self="/rest/operational-state/mpls-state/statistics-oam/return-codes/4">
<number>4</number>
<name>"No FEC mapping"</name>
</return-codes>
<return-codes y:self="/rest/operational-state/mpls-state/statistics-oam/return-codes/5">
<number>5</number>
<name>"DS map mismatch"</name>
</return-codes>
<return-codes y:self="/rest/operational-state/mpls-state/statistics-oam/return-codes/6">
<number>6</number>
<name>"Unknown upstream intf"</name>
</return-codes>
<return-codes y:self="/rest/operational-state/mpls-state/statistics-oam/return-codes/7">
<number>7</number>
<name>"Reserved return code"</name>
</return-codes>
<return-codes y:self="/rest/operational-state/mpls-state/statistics-oam/return-codes/9">
<number>9</number>
<name>"Unlabeled output intf"</name>
</return-codes>
<return-codes y:self="/rest/operational-state/mpls-state/statistics-oam/return-codes/10">
<number>10</number>
<name>"FEC mapping mismatch"</name>
</return-codes>
<return-codes y:self="/rest/operational-state/mpls-state/statistics-oam/return-codes/11">
<number>11</number>
<name>"No label entry"</name>
</return-codes>
<return-codes y:self="/rest/operational-state/mpls-state/statistics-oam/return-codes/12">
<number>12</number>
<name>"Rx intf protocol mismatch"</name>
</return-codes>
<return-codes y:self="/rest/operational-state/mpls-state/statistics-oam/return-codes/13">
<number>13</number>
<name>"Premature LSP termination"</name>
</return-codes>
</statistics-oam>
