Enables the OSPF graceful restart capability.
| URI | Description |
<base_URI>/config/running/router/ospf/default-vrf/graceful-restart |
Enables OSPF graceful restart. |
| GET URI | Description |
Retrieves OSPF graceful restart configuration information. |
| PATCH URI | Payload | Description |
<graceful-restart-enable>true</graceful-restart-enable> |
<helper-disable>true</helper-disable> |
Disables helper mode. |
<restart-time> </restart-time> |
Configures the maximum restart wait time that is advertised to neighbors. |
| DELETE URI |
<base_URI>/config/running/router/ospf/default-vrf/graceful-restart/helper-disable |
<base_URI>/config/running/router/ospf/default-vrf/graceful-restart/restart-time |
GET, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
<graceful-restart xmlns="urn:brocade.com:mgmt:brocade-ospf" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/router/ospf/default-vrf/graceful-restart"> <graceful-restart-enable>true</graceful-restart-enable> <helper-disable>true</helper-disable> <restart-time>150</restart-time> </graceful-restart>
