Configures, modifies, or retrieves security email settings.
| URI | Description |
| <base_URI>/config/running/system-monitor-mail | Configures the FRU email alerts. |
| <base_URI>/config/running/system-monitor-mail/security | Security email settings. |
| POST URIs | Payload | Description |
| /rest/config/running/system-monitor-mail/security | <email-list><email>(string)</email></email-list> | Configures the security email alerts. |
| PUT URIs | Payload | Description |
| /rest/config/running/system-monitor-mail/security/enable | <enable>true</enable> | Modifies the security email alerts. |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/system-monitor-mail/security
None
<security y:self="/rest/config/running/system-monitor-mail/security">
<email-list y:self="/rest/config/running/system-monitor-mail/security/email-list/abc@brocade.com">
<email>abc@brocade.com</email>
</email-list>
</security>
The following is an example of the DELETE operation to remove the security e-mail settings.
None
None
