Displays IS-IS IPv6 route information
| URI | Description |
| <base_URI>/operational-state/isis-state/ipv6-routes | Displays IS-ISv6 routes. |
| <base_URI>/operational-state/isis-state/ipv6-routes/level1-route-count | Displays Level-1 IS-IS ipv6 route count. |
| <base_URI>/operational-state/isis-state/ipv6-routes/level2-route-count | Displays Level-2 IS-IS ipv6 route count. |
| <base_URI>/operational-state/isis-state/ipv6-routes/ecmp-route-count | Displays ECMP route count. |
| <base_URI>/operational-state/isis-state/ipv6-routes/total-routes-count | Displays total number of IS-IS ipv6 routes. |
| <base_URI>/operational-state/isis-state/ipv6-routes/ipv6-route-entry | Displays ISIS route entry. |
| <base_URI>/operational-state/isis-state/ipv6-routes/ipv6-route-entry/{ipv6-dest-addr},{ipv6-prefix-len}/level | Displays ISIS route type. |
| <base_URI>/operational-state/isis-state/ipv6-routes/ipv6-route-entry/{ipv6-dest-addr},{ipv6-prefix-len}/cost | Displays Cost of ISIS route. |
| <base_URI>/operational-state/isis-state/ipv6-routes/ipv6-route-entry/{ipv6-dest-addr},{ipv6-prefix-len}/tag | Displays Tag value. |
| <base_URI>/operational-state/isis-state/ipv6-routes/ipv6-route-entry/{ipv6-dest-addr}/v{pv6-prefix-len}/flags | Displays Flags. |
| <base_URI>/operational-state/isis-state/ipv6-routes/ipv6-route-entry/{ipv6-dest-addr},{ipv6-prefix-len}/is-l1-summarized | Displays whether L1 route is summarized or not. |
| <base_URI>/operational-state/isis-state/ipv6-routes/ipv6-route-entry/{ipv6-dest-addr},{ipv6-prefix-len}/is-l2-summarized | Displays whether L2 route is summarized or not. |
| <base_URI>/operational-state/isis-state/ipv6-routes/ipv6-route-entry/{ipv6-dest-addr},{ipv6-prefix-len}/is-summary | Displays whether the specified route is the summary route or not. |
| <base_URI>/operational-state/isis-state/ipv6-routes/ipv6-route-entry/{ipv6-dest-addr},{ipv6-prefix-len}/nh-info | Displays Next Hop information. |
| <base_URI>/operational-state/isis-state/ipv6-routes/ipv6-route-entry/{ipv6-dest-addr},{ipv6-prefix-len}/nh-info/{outgoing-intf-name}/ipv6-nh-addr | Displays the next hop ipv6 address. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/operational-state/isis-state/ipv6-routes
None
<ipv6-routes xmlns="urn:brocade.com:mgmt:brocade-isis-operational" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/operational-state/isis-state/ipv6-routes">
<level1-route-count>11</level1-route-count>
<level2-route-count>0</level2-route-count>
<ecmp-route-count>0</ecmp-route-count>
<total-routes-count>11</total-routes-count>
<ipv6-route-entry y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/140:140:140::%2C64">
<ipv6-dest-addr>140:140:140::</ipv6-dest-addr>
<ipv6-prefix-len>64</ipv6-prefix-len>
<level>1</level>
<cost>20</cost>
<tag>0</tag>
<flags>0</flags>
<is-l1-summarized>false</is-l1-summarized>
<is-l2-summarized>false</is-l2-summarized>
<is-summary>false</is-summary>
<nh-info y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/140:140:140::%2C64/nh-info/
eth%2C%221/49%22">
<outgoing-intf-type>eth</outgoing-intf-type>
<outgoing-intf-number>1/49</outgoing-intf-number>
<ipv6-nh-addr>fe80::200:65ff:fedd:c2f7</ipv6-nh-addr>
</nh-info>
</ipv6-route-entry>
<ipv6-route-entry y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::1%2C128">
<ipv6-dest-addr>150:150:150::1</ipv6-dest-addr>
<ipv6-prefix-len>128</ipv6-prefix-len>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>0</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::1%2C128/nh-info/
eth%2C%221/49%22">
</nh-info>
</ipv6-route-entry>
<ipv6-route-entry y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::2%2C128">
<ipv6-dest-addr>150:150:150::2</ipv6-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>0</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::2%2C128/nh-info/
eth%2C%221/49%22">
</nh-info>
</ipv6-route-entry>
<ipv6-route-entry y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::3%2C128">
<ipv6-dest-addr>150:150:150::3</ipv6-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>0</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::3%2C128/nh-info/
eth%2C%221/49%22">
</nh-info>
</ipv6-route-entry>
<ipv6-route-entry y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::4%2C128">
<ipv6-dest-addr>150:150:150::4</ipv6-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>0</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::4%2C128/nh-info/
eth%2C%221/49%22">
</nh-info>
</ipv6-route-entry>
<ipv6-route-entry y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::5%2C128">
<ipv6-dest-addr>150:150:150::5</ipv6-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>0</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::5%2C128/nh-info/
eth%2C%221/49%22">
</nh-info>
</ipv6-route-entry>
<ipv6-route-entry y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::6%2C128">
<ipv6-dest-addr>150:150:150::6</ipv6-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>0</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::6%2C128/nh-info/
eth%2C%221/49%22">
</nh-info>
</ipv6-route-entry>
<ipv6-route-entry y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::7%2C128">
<ipv6-dest-addr>150:150:150::7</ipv6-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>0</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::7%2C128/nh-info/
eth%2C%221/49%22">
</nh-info>
</ipv6-route-entry>
<ipv6-route-entry y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::8%2C128">
<ipv6-dest-addr>150:150:150::8</ipv6-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>0</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::8%2C128/nh-info/
eth%2C%221/49%22">
</nh-info>
</ipv6-route-entry>
<ipv6-route-entry y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::9%2C128">
<ipv6-dest-addr>150:150:150::9</ipv6-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>0</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::9%2C128/nh-info/
eth%2C%221/49%22">
</nh-info>
</ipv6-route-entry>
<ipv6-route-entry y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::a%2C128">
<ipv6-dest-addr>150:150:150::a</ipv6-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>0</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv6-routes/ipv6-route-entry/150:150:150::a%2C128/nh-info/
eth%2C%221/49%22">
</nh-info>
</ipv6-route-entry>
</ipv6-routes>
