Retrieves the status of a previous configuration command.
| URI | Description |
| <base_URI>/operations/bna-config-cmd-status | Retrieves the status of a previous configuration command. |
Only POST operation is supported.
http://host:80/rest/operations/bna-config-cmd-status
<bna-config-cmd-status> <session-id>0</session-id> </bna-config-cmd-status>
<output xmlns='urn:brocade.com:mgmt:brocade-ras'> <status>completed</status> <status-string></status-string> </output>
