Configures, retrieves, and modifies Remote Authentication Dial-In User Service (RADIUS) server.
| URI | Description |
| <base_URI>/config/running/radius-server | Configures RADIUS server. |
| GET URIs | Description |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf} | Configures the host name of the RADIUS server and specifies a VRF though which to communicate with the RADIUS server. |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf}/auth-port | Configures UDP port for authentication (default=1812). |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf}/protocol | Specifies the authentication protocol. Parameters include CHAP, PAP, or PEAP-MSCHAP. The default is CHAP. |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf}/key | Specifies the text string that is used as the shared secret between the device and the RADIUS server. The default is sharedsecret . |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf}/encryption-level | Designates the encryption level for the shared secret key operation. |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf}/retries | Configures the number of attempts allowed to connect to a RADIUS server. The default is 5 attempts. |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf}/timeout | Configures the time to wait for the RADIUS server to respond, in seconds. The default is 5 seconds. |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf}/source-interface | Retrieves Source Interface information. |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf}/source-interface/source-interface-value | Displays Source Interface. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf} | <host><auth-port>{rad-auth-port}</auth-port></host> | Configures the host name of the RADIUS server and specifies a VRF though which to communicate with the RADIUS server. |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf} | <host><key>{string}</key></host> | Specifies the text string that is used as the shared secret between the device and the RADIUS server. The default is sharedsecret. |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf} | <host><encryption-level>{enumeration}</encryption-level></host> | Designates the encryption level for the shared secret key operation. |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf} | <host><retries>{uint32}</retries></host> | Configures the number of attempts allowed to connect to a RADIUS server. |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf} | <host><timeout>{uint32}</timeout></host> | Configures the time to wait for the RADIUS server to respond, in seconds. |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf}/source-interface | <source-interface><source-interface-name>{track-iftype}</source-interface-name><source-interface-value>{track-ifname}</source-interface-value></source-interface> | Sets source-interface for the RADIUS packets. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf}/auth-port | <auth-port>{rad-auth-port}</auth-port> | Configures UDP port for authentication (default=1812). |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf}/key | <key>{string}</key> | Specifies the text string that is used as the shared secret between the device and the RADIUS server. The default is sharedsecret. |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf}/encryption-level | <encryption-level>{enumeration}</encryption-level> | Designates the encryption level for the shared secret key operation. |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf}/retries | <retries>{uint32}</retries> | Configures the number of attempts allowed to connect to a RADIUS server. |
| <base_URI>/config/running/radius-server/host/{hostname},{use-vrf}/timeout | <timeout>{uint32}</timeout> | Configures the time to wait for the RADIUS server to respond, in seconds. |
| DELETE URIs |
| <base_URI>///running/radius-server/host/{hostname},{use-vrf}/source-interface |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/radius-server
None
<radius-server xmlns="urn:brocade.com:mgmt:brocade-aaa" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/radius-server">
<host y:self="/rest/config/running/radius-server/host/50.50.50.50%2Cdata-vrf-1">
<hostname>50.50.50.50</hostname>
<use-vrf>data-vrf-1</use-vrf>
</host>
<host y:self="/rest/config/running/radius-server/host/10.20.106.145%2Cdata-vrf">
<hostname>10.20.106.145</hostname>
<use-vrf>data-vrf</use-vrf>
</host>
</radius-server>
The following example uses the PUT option to configure RADIUS server.
http://host:80/rest/config/running/config/running/radius-server/host/10.20.106.145/data-vrf/auth-port
<auth-port>11111</auth-port>
None
The following example uses the DELETE option to remove RADIUS server.
http://host:80/rest/config/running/radius-server/host/10.20.106.145/data-vrf
None
None
