Retrieves the firmware version information.
| URI | Description |
| <base_URI>/operations/show-firmware-version | Retrieves the firmware version information. |
Only POST operation is supported.
http://host:80/rest/operations/show-firmware-version
<show-firmware-version></show-firmware-version>
<output xmlns='urn:Extreme.com:mgmt:Extreme-firmware-ext'>
<os-name>SLX Operating System Software</os-name>
<os-version>16r.1.00</os-version>
<copy-right-info>Copyright (c) 2016 Extreme Communications Systems, Inc.</copy-right-info>
<build-time>Sun Aug 7 12:29:51 2016
</build-time>
<firmware-full-version>16r.1.00slxos_16r.1.00_patch_160807_0300</firmware-full-version>
<control-processor-vendor></control-processor-vendor>
<control-processor-chipset></control-processor-chipset>
<control-processor-memory>7890 MB</control-processor-memory>
<node-info>
<slot-no>1</slot-no>
<node-instance-no>0</node-instance-no>
<node-type>type-mm</node-type>
<is-active-cp>true</is-active-cp>
<firmware-version-info>
<application-name>NOS</application-name>
<primary-version>16r.1.00slxos_16r.1.00_patch_160807_0300</primary-version>
<secondary-version>16r.1.00slxos_16r.1.00_patch_160807_0300</secondary-version>
</firmware-version-info>
</node-info>
<node-info>
<slot-no>2</slot-no>
</node-info>
<node-info>
<slot-no>3</slot-no>
<node-type>type-lc</node-type>
</node-info>
</output>
