Displays the MCT client operational information.
| URI | Description |
| <base_URI>/operational-state/mctd-client-state-state | Displays the MCT client operational information. |
| <base_URI>/operational-state/mctd-client-state-state/show-cluster-mctd-client | Displays MCT cluster client states. |
| <base_URI>/operational-state/mctd-client-state-state/show-cluster-mem-vlan/1/num-vlans | Displays the number of VLANs configured. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/operational-state/mctd-client-state-state
None
<mctd-client-state-state xmlns="urn:brocade.com:mgmt:brocade-mct-operational"
y:self="/rest/operational-state/mctd-client-state-state">
<show-cluster-mem-vlan y:self="/rest/operational-state/mctd-client-state-state/show-cluster-mem-vlan/56">
<cluster-id>56</cluster-id>
<num-vlans>2663</num-vlans>
<vlan-label-info y:self="/rest/operational-state/mctd-client-state-state/show-cluster-mem-vlan/56/vlan-label-info/2">
<vlan-id>2</vlan-id>
<mcast-label-local>817154</mcast-label-local>
<mcast-label-remote>817154</mcast-label-remote>
</vlan-label-info>
<vlan-label-info y:self="/rest/operational-state/mctd-client-state-state/show-cluster-mem-vlan/56/vlan-label-info/3">
<vlan-id>3</vlan-id>
<mcast-label-local>817155</mcast-label-local>
<mcast-label-remote>817155</mcast-label-remote>
</vlan-label-info>
<vlan-label-info y:self="/rest/operational-state/mctd-client-state-state/show-cluster-mem-vlan/56/vlan-label-info/4">
<vlan-id>4</vlan-id>
<mcast-label-local>817156</mcast-label-local>
<mcast-label-remote>817156</mcast-label-remote>
</vlan-label-info>
