app-telemetry-counters-state
Displays counters per protocol
Resource URIs
URI Description
<base_URI>/operational-state/app-telemetry-counters-state Displays counters per protocol.
Usage Guidelines
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
URI
The following example shows the complete cURL command and server response for the app-telemetry-counters-state GET operation.
http://host:80/rest/operational-state/app-telemetry-counters-state
curl -H "Accept: application/vnd.operational-state.resource+xml" -H "Resource-Depth: 6"
-u "lab:Tester**"  http://10.20.229.40:80/rest/operational-state/app-telemetry-counters-state
<data xmlns="http://brocade.com/ns/rest" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/operational-state">
<app-telemetry-counters-state xmlns="urn:brocade.com:mgmt:brocade-ssm-operational" y:self="/rest/operational-state/
app-telemetry-counters-state">
</app-telemetry-counters-state>
</data>
Release version History
18r.2.00 This API call was introduced.
