arp
Configures, modifies, or retrieves Address Resolution Protocol (ARP).
Resource URIs
URI Description
<base_URI>/config/running/arp Address Resolution Protocol (ARP).
GET URIs Description
<base_URI>/config/running/arp/{arp-ip-address} Retrieves Address Resolution Protocol (ARP) configuration information.
PATCH URIs Payload Description
<base_URI>/config/running/arp <arp><arp-ip-address>{inet:ipv4-address}</arp-ip-address><mac-address-value>{mac-access-list:mac-address-type}</mac-address-value><interfacename>{enumeration}</interfacename><Ethernet>{interface:interface-type}</Ethernet></arp> Configures ARP IP address and MAC address.
<base_URI>/config/running/arp <arp><arp-ip-address>{inet:ipv4-address}</arp-ip-address><mac-address-value>{mac-access-list:mac-address-type}</mac-address-value><interfacename>{enumeration}</interfacename><Ve>{interface:interface-type}</Ve></arp> Configures ARP IP address and MAC address.
DELETE URIs
Parameters
arp-ip-address
Specifies the IP address of the ARP entry.
mac-address-value
Specifies the MAC address in HHHH.HHHH.HHHH format.
interfacename
Specifies the interface to use.
Usage Guidelines
GET, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/arp
None
<arp xmlns="urn:brocade.com:mgmt:brocade-arp" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/arp/10.24.25.26">
  <arp-ip-address>10.24.25.26</arp-ip-address>
  <mac-address-value>0000.2222.2233</mac-address-value>
  <interfacename>interface</interfacename>
  <Ethernet>1/1</Ethernet>
</arp>
URI
The following is an example of the PATCH operation to modify ARP configuration.
<arp>
  <arp-ip-address>10.34.23.56</arp-ip-address>
  <mac-address-value>0001.0002.0003</mac-address-value>
  <Ve>233</Ve>
</arp>
None
URI
The following is an example of the DELETE operation to remove the ARP configuration.
http://host:80/rest/config/running/arp/10.34.23.56
None
None
