Configures, modifies, or retrieves the Chassis Virtual address.
| URI | Description |
| <base_URI>/config/running/chassis | Chassis Virtual address. |
| GET URIs | Description |
| /rest/config/running/chassis | Configure Chassis Virtual address. |
| /rest/config/running/chassis/virtual-ip | Chassis Virtual IPv4 address |
| /rest/config/running/chassis/virtual-ipv6 | Chassis Virtual IPv6 address |
| PATCH URIs | Payload | Description |
| /rest/config/running/chassis | <chassis><virtual-ip>(string)</virtual-ip></chassis> | Chassis Virtual IPv4 address |
| /rest/config/running/chassis | <chassis><virtual-ipv6>(string)</virtual-ipv6></chassis> | Chassis Virtual IPv6 address |
| PUT URIs | Payload | Description |
| /rest/config/running/chassis/virtual-ip | <virtual-ip>(string)</virtual-ip> | Chassis Virtual IPv4 address |
| /rest/config/running/chassis/virtual-ipv6 | <virtual-ipv6>(string)</virtual-ipv6> | Chassis Virtual IPv6 address |
| DELETE URIs | Payload | Description |
| POST URIs | Payload | Description |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/chassis
None
<chassis xmlns="urn:brocade.com:mgmt:brocade-chassis" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/chassis"> <virtual-ip>10.24.81.195/20</virtual-ip> <virtual-ipv6>2001:2017:111:1::/64</virtual-ipv6> </chassis>
The following example of the PATCH operation to set virtual IPv4 address.
<chassis> <virtual-ip>10.20.108.66/20</virtual-ip> </chassis>
None
The following example of the DELETE operation to remove virtual IPv4 address.
http://host:80/rest/config/running/chassis/virtual-ip
None
None
