Base resource
The base resource represents the high-level resources in the system, and is categorized under the media type "application/vnd.base.resource+xml".
The entry point container in the resource model is "/rest"; all fields, and sub-resources with the same resource type are defined in the namespace "http://brocade.com/ns/rest".
The base resource consists of Configuration resource (/config/running), YANG-RPC Operations resource (/operations), and operational-state (/operational-state) resources as first-level child resources.
