Displays IS-IS Dynamic Host Name Mapping
| URI | Description |
| <base_URI>/operational-state/isis-state/host-table | Displays IS-IS Dynamic Host Name Mapping. |
| <base_URI>/operational-state/isis-state/host-table/hostname-enabled | Displays true if the IS-IS Routing Protocol Hostname feature support is enabled. |
| <base_URI>/operational-state/isis-state/host-table/isis-router-entry | Displays IS-IS Routing Protocol host-table mapping details for an IS-IS Router |
| <base_URI>/operational-state/isis-state/host-table/isis-router-entry/{system-id}/host-name | Displays the hostname for an IS-IS Router for a specified system-id. |
| <base_URI>/operational-state/isis-state/host-table/isis-router-entry/{system-id}/is-local | Displays true if the host is local. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/operational-state/isis-state/host-table
None
<host-table xmlns="urn:brocade.com:mgmt:brocade-isis-operational" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/operational-state/isis-state/host-table">
<hostname-enabled>true</hostname-enabled>
<isis-router-entry y:self="/rest/operational-state/isis-state/host-table/isis-router-entry/1111.1111.1111">
<system-id>1111.1111.1111</system-id>
<host-name>Fusion1</host-name>
<is-local>true</is-local>
</isis-router-entry>
<isis-router-entry y:self="/rest/operational-state/isis-state/host-table/isis-router-entry/a9e0.0001.0000">
<system-id>a9e0.0001.0000</system-id>
<host-name>IXIA1101</host-name>
<is-local>false</is-local>
</host-table>
