Displays IS-IS configuration
URI | Description |
<base_URI>/operational-state/isis-state/router-isis-config | Displays IS-IS configuration. |
<base_URI>/operational-state/isis-state/router-isis-config/nsr-state | Displays NSR state for IS-IS configuration. |
<base_URI>/operational-state/isis-state/router-isis-config/lsp-flood-count | Displays LSP flood count. |
<base_URI>/operational-state/isis-state/router-isis-config/lsp-fast-flood-count | Displays LSP fast flood count. |
<base_URI>/operational-state/isis-state/router-isis-config/fast-flood-wait-count | Displays LSP flood wait count. |
<base_URI>/operational-state/isis-state/router-isis-config/hello-padding | Displays whether Hello padding is enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/hello-padding-ptp | Displays Hello padding for ptp |
<base_URI>/operational-state/isis-state/router-isis-config/csnp-interval | Displays CSNP interval time |
<base_URI>/operational-state/isis-state/router-isis-config/lsp-gen-interval | Displays LSP gen interval. |
<base_URI>/operational-state/isis-state/router-isis-config/lsp-interval | Displays LSP interval. |
<base_URI>/operational-state/isis-state/router-isis-config/lsp-refresh-interval | Displays LSP refresh interval. |
<base_URI>/operational-state/isis-state/router-isis-config/lsp-lifetime | Displays LSP lifetime. |
<base_URI>/operational-state/isis-state/router-isis-config/retransmit-interval | Displays LSP retransmit interval. |
<base_URI>/operational-state/isis-state/router-isis-config/pspf-enabled | Displays whether Partial-SPF is enabled or not. |
<base_URI>/operational-state/isis-state/router-isis-config/ispf-enabled | Displays whether Incremental Shortcut SPF enabled or not. |
<base_URI>/operational-state/isis-state/router-isis-config/istct-spf-enabled | Displays whether Incremental Shortcut SPF is enabled or not. |
<base_URI>/operational-state/isis-state/router-isis-config/overload-state | Displays ISIS overload state. |
<base_URI>/operational-state/isis-state/router-isis-config/overload-startup-time | Displays ISIS overload startup wait time |
<base_URI>/operational-state/isis-state/router-isis-config/overload-wait-on-bgp | Displays whether ISIS overload bgp wait timer is enabled or not. |
<base_URI>/operational-state/isis-state/router-isis-config/overload-bgp-wait-time | Displays ISIS overload bgp wait timer value. |
<base_URI>/operational-state/isis-state/router-isis-config/enable-code-assertions | Displays whether ISIS code-assertions are enabled or not. |
<base_URI>/operational-state/isis-state/router-isis-config/graceful-restart-helper | Displays whether graceful restart helper is enabled or not. |
<base_URI>/operational-state/isis-state/router-isis-config/isis-hostname-enabled | Displays whether hostname is enabled or not. |
<base_URI>/operational-state/isis-state/router-isis-config/isis-system-info | Displays ISIS System Information. |
<base_URI>/operational-state/isis-state/router-isis-config/isis-system-info/protocol-enabled | Displays IS-IS Routing Protocol Operation State. |
<base_URI>/operational-state/isis-state/router-isis-config/isis-system-info/operation-mode | Displays operation mode. |
<base_URI>/operational-state/isis-state/router-isis-config/isis-system-info/system-id | Displays system ID. |
<base_URI>/operational-state/isis-state/router-isis-config/isis-system-info/nsap | Displays whether NSAP is enabled or not. |
<base_URI>/operational-state/isis-state/router-isis-config/isis-system-info/nsap/val_net-addr_val/length | Displays NSAP net addres length. |
<base_URI>/operational-state/isis-state/router-isis-config/l1-auth-profile | Displays Auth profile for Level-1. Displays Auth profile for Level-1. |
<base_URI>/operational-state/isis-state/router-isis-config/l1-auth-profile/auth-check | Displays Auth Check for Level-1. |
<base_URI>/operational-state/isis-state/router-isis-config/l1-auth-profile/auth-mode | Displays Auth Mode for Level-1. |
<base_URI>/operational-state/isis-state/router-isis-config/l1-auth-profile/auth-key | Displays Auth Key for Level-1. |
<base_URI>/operational-state/isis-state/router-isis-config/l2-auth-profile | Displays Auth profile for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/l2-auth-profile/auth-check | Displays Auth Check for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/l2-auth-profile/auth-mode | Displays Auth Mode for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/l1-spf-timer | Displays SPF timer value for Level-1. |
<base_URI>/operational-state/isis-state/router-isis-config/l2-auth-profile/auth-key | Displays Auth Key for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/log-handler | Displays Displays ISIS log status. |
<base_URI>/operational-state/isis-state/router-isis-config/log-handler/log-adj-state-change | Displays ISIS log status for adjacency state change. |
<base_URI>/operational-state/isis-state/router-isis-config/log-handler/log-bad-lsp | Displays ISIS log status for bad LSPs |
<base_URI>/operational-state/isis-state/router-isis-config/l1-spf-timer/init-delay-time | Displays SPF Init Wait time for Level-1. |
<base_URI>/operational-state/isis-state/router-isis-config/l1-spf-timer/hold-down-time | Displays SPF Hold time for Level-1. |
<base_URI>/operational-state/isis-state/router-isis-config/l1-spf-timer/max-time | Displays SPF Max Wait time for Level-1. |
<base_URI>/operational-state/isis-state/router-isis-config/l2-spf-timer | SPF timer for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/l2-spf-timer/init-delay-time | Displays SPF Init Wait time for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/l2-spf-timer/hold-down-time | Displays SPF Hold time for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/l2-spf-timer/max-time | Displays SPF Max Wait time for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/l1-spf6-timer | Displays SPF6 timer value for Level-1. |
<base_URI>/operational-state/isis-state/router-isis-config/l1-spf6-timer/init-delay-time | Displays SPF6 Init Wait time for Level-1. |
<base_URI>/operational-state/isis-state/router-isis-config/l1-spf6-timer/hold-down-time | Displays SPF6 Hold time for Level-1. |
<base_URI>/operational-state/isis-state/router-isis-config/l1-spf6-timer/max-time | Displays SPF6 Max Wait time for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/l2-spf6-timer | Displays SPF6 timer value for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/l2-spf6-timer/init-delay-time | Displays SPF6 Init Wait time for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/l2-spf6-timer/hold-down-time | SPF6 Hold time for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/l2-spf6-timer/max-time | SPF6 Max Wait time for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/pspf-timer | Displays PSPF timer. |
<base_URI>/operational-state/isis-state/router-isis-config/pspf-timer/init-delay-time | Displays PSPF Init Wait time. |
<base_URI>/operational-state/isis-state/router-isis-config/pspf-timer/hold-down-time | Displays PSPF Hold time. |
<base_URI>/operational-state/isis-state/router-isis-config/pspf-timer/max-time | Displays PSPF Max Wait time. |
<base_URI>/operational-state/isis-state/router-isis-config/pspf6-timer | Displays PSPF6 Timer. |
<base_URI>/operational-state/isis-state/router-isis-config/pspf6-timer/init-delay-time | Displays PSPF6 Init Wait time. |
<base_URI>/operational-state/isis-state/router-isis-config/pspf6-timer/hold-down-time | Displays PSPF6 Hold time. |
<base_URI>/operational-state/isis-state/router-isis-config/pspf6-timer/max-time | Displays PSPF6 Max Wait time. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4 | Displays ISISv4 address family information. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/originate-default-route | Displays whether redistribution of default route is enabled or not. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/originate-default-routemap-name | Displays route map name if default route redistribution is enabled with route-map. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/default-metric | Displays default metric. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/l1-default-link-metric | Displays default metric for Level-1. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/l2-default-link-metric | Displays default metric for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/administrative-distance | Displays Administrative Distance. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/maximum-equal-cost-paths | Displays ECMP path. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-static | Displays redistribution of static route information. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-static/redist-enabled | Displays whether redistribution of static route is enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-static/redist-level | Displays static route redistribution level. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-static/redist-metric | Displays metric for redistributed static route. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-static/redist-metric-type | Displays IS-IS metric type for redistributed static routes. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-static/redist-routemap-name | Displays Route map name if static route redistribution is enabled with route-map. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-connected | Displays redistribution of connected route information. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-connected/redist-enabled | Displays whether redistribution of connected route is enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-connected/redist-level | Displays connected route redistribution level. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-connected/redist-metric | Displays metric for redistributed connected route. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-connected/redist-metric-type | Displays IS-IS metric type for redistributed connected routes. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-connected/redist-routemap-name | Displays Route map name if connected route redistribution is enabled with route-map. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-bgp | Displays redistribution of BGP route information. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-bgp/redist-enabled | Displays whether redistribution of BGP route is enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-bgp/redist-level | Displays BGP route redistribution level. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-bgp/redist-metric | Displays metric for redistributed BGP route. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-bgp/redist-metric-type | Displays IS-IS metric type for redistributed BGP routes. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-bgp/redist-routemap-name | Displays Route map name if BGP route redistribution is enabled with route-map. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-isis | Displays ISIS redistribution information. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-isis/redist-is-l2-to-l1 | Redistribute ISIS route Level-2 to Level-1 Status. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-isis/redist-is-l2-to-l1 | Redistribute ISIS route Level-2 to Level-1 with prefix list. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-isis/redist-is-l1-to-l2 | Redistribute ISIS route redistribution Level-1 to Level-2 status. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-isis/redist-is-l1-to-l2-prefix | Redistribute ISIS route Level-2 to Level-1 with prefix list. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-ospf | Displays redistribution of OSPF route information. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-ospf/redist-enabled | Displays whether redistribution of OSPF route is enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-ospf/redist-level | Displays OSPF redistribution level. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-ospf/redist-metric | Displays IS-IS metric type for redistributed OSPF routes. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-ospf/redist-metric-type | Displays IS-IS metric type for redistributed OSPF routes. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-ospf/redist-routemap-name | Displays Route map name if OSPF route redistribution is enabled with route-map. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-ospf/ospf-internal-enabled | Displays whether Redistribution of OSPF Internal routes is enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-ospf/ospf-external1-enabled | Displays whether Redistribution of OSPF External type 1 routes is enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-ospf/ospf-external2-enabled | Displays whether Redistribution of OSPF External type 2 routes is enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/l1-wide-metric-enabled | Displays Metric Style for Level-1. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/l2-wide-metric-enabled | Displays Metric Style for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/ldp-sync-enabled | Displays LDP sync state. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/ldp-sync-hold-down | Displays LDP sync hold down timer. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/summary-address-v4 | Displays summary address information. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/summary-address-v4/val_address_val/ipv4-mask | Displays summary address mask value. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v4/summary-address-v4/val_address_val/level | Displays summary address level. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6 | Displays ISISv6 address family information. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/originate-default-route | Displays whether redistribution of default route is enabled or not. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/originate-default-routemap-name | Displays route map name if default route redistribution is enabled with route-map. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/default-metric | Displays default metric. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/l1-default-link-metric | Displays default metric for Level-1. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/l2-default-link-metric | Displays default metric for Level-2. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/administrative-distance | Displays Administrative Distance. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/maximum-equal-cost-paths | Displays ECMP path. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-static | Displays redistribution of static route information. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-static/redist-enabled | Displays whether redistribution of static route is enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-static/redist-level | Displays static route redistribution level. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-static/redist-metric | Displays metric for redistributed static route. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-static/redist-metric-type | Displays IS-IS metric type for redistributed static routes. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-static/redist-routemap-name | Displays Route map name if static route redistribution is enabled with route-map. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-connected | Displays redistribution of connected route information. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-connected/redist-enabled | Displays whether redistribution of connected route is enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-connected/redist-level | Displays connected route redistribution level. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-connected/redist-metric | Displays metric for redistributed connected route. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-connected/redist-metric-type | Displays IS-IS metric type for redistributed connected routes. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-connected/redist-routemap-name | Displays Route map name if connected route redistribution is enabled with route-map. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-bgp | Displays redistribution of BGP route information. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-bgp/redist-enabled | Displays whether redistribution of BGP route is enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-bgp/redist-level | Displays BGP route redistribution level. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-bgp/redist-metric | Displays metric for redistributed BGP route. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-bgp/redist-metric-type | Displays IS-IS metric type for redistributed BGP routes. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-bgp/redist-routemap-name | Displays Route map name if OSPF route redistribution is enabled with route-map. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-isis | Displays ISIS redistribution information. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-isis/redist-is-l2-to-l1 | Redistribute ISIS route Level-2 to Level-1 Status. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-isis/redist-is-l2-to-l1-prefix | Redistribute ISIS route Level-2 to Level-1 with prefix list. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-isis/redist-is-l1-to-l2 | Redistribute ISIS route redistribution Level-1 to Level-2 status. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-isis/redist-is-l1-to-l2-prefix | Redistribute ISIS route Level-2 to Level-1 with prefix list. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-ospf | Displays redistribution of OSPF route information. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-ospf/redist-enabled | Displays whether redistribution of OSPF route is enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-ospf/redist-level | Displays OSPF redistribution level. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-ospf/redist-metric | Displays IS-IS metric type for redistributed OSPF routes. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-ospf/redist-metric-type | Displays IS-IS metric type for redistributed OSPF routes. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-ospf/redist-routemap-name | Displays Route map name if OSPF route redistribution is enabled with route-map. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-ospf/ospf-internal-enabled | Displays whether Redistribution of OSPF Internal routes is enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-ospf/ospf-external1-enabled | Displays whether Redistribution of OSPF External type 1 routes is enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-ospf/ospf-external2-enabled | Displays whether Redistribution of OSPF External type 2 routes is enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/adjacency-check | Displays ISIS adjacency check status. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/multi-topology | Displays ISIS multi-topology status. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/mt-transition-state | Displays ISIS multi-topology with transition enabled or disabled. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/summary-prefix-v6 | Displays summary prefix information. |
<base_URI>/operational-state/isis-state/router-isis-config/is-address-family-v6/summary-prefix-v6/val_address_val/level | Displays summary prefix level. |
<base_URI>/operational-state/isis-state/router-isis-config/reverse-metric | Displays ISIS Reverse Metric. |
<base_URI>/operational-state/isis-state/router-isis-config/reverse-metric/reverse-metric-value | Displays ISIS Reverse metric value. |
<base_URI>/operational-state/isis-state/router-isis-config/reverse-metric/rev-metric-whole-lan | Displays ISIS Reverse Metric for whole LAN. |
<base_URI>/operational-state/isis-state/router-isis-config/reverse-metric/rev-metric-te-def-metric | Displays ISIS Reverse metric TE default metric. |
<base_URI>/operational-state/isis-state/router-isis-config/reverse-metric/rev-metric-tlv-type | Displays ISIS Reverse metric tlv type |
<base_URI>/operational-state/isis-state/router-isis-config/debug-handler | Displays ISIS debug information. |
<base_URI>/operational-state/isis-state/router-isis-config/debug-handler/debug-nsr | Displays debug for NSR |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/operational-state/isis-state/router-isis-config
None
<router-isis-config xmlns="urn:brocade.com:mgmt:brocade-isis-operational" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/operational-state/isis-state/router-isis-config"> <nsr-state>is-disabled</nsr-state> <lsp-flood-count>25</lsp-flood-count> <lsp-fast-flood-count>0</lsp-fast-flood-count> <fast-flood-wait-count>10</fast-flood-wait-count> <hello-padding>is-enabled</hello-padding> <hello-padding-ptp>is-enabled</hello-padding-ptp> <csnp-interval>10</csnp-interval> <lsp-gen-interval>10</lsp-gen-interval> <lsp-interval>33</lsp-interval> <lsp-refresh-interval>900</lsp-refresh-interval> <lsp-lifetime>1200</lsp-lifetime> <retransmit-interval>5</retransmit-interval> <pspf-enabled>is-enabled</pspf-enabled> <ispf-enabled>is-enabled</ispf-enabled> <istct-spf-enabled>is-enabled</istct-spf-enabled> <overload-state>is-disabled</overload-state> <overload-startup-time>0</overload-startup-time> <overload-wait-on-bgp>is-disabled</overload-wait-on-bgp> <overload-bgp-wait-time>600</overload-bgp-wait-time> <enable-code-assertions>is-enabled</enable-code-assertions> <graceful-restart-helper>is-enabled</graceful-restart-helper> <isis-hostname-enabled>is-enabled</isis-hostname-enabled> <isis-system-info y:self="/rest/operational-state/isis-state/router-isis-config/isis-system-info"> <protocol-enabled>is-enabled</protocol-enabled> <operation-mode>isis-level1-2</operation-mode> <system-id>1111.1111.1111</system-id> <nsap y:self="/rest/operational-state/isis-state/router-isis-config/isis-system-info/nsap/01.1111.1111.1111.00"> <net-addr>01.1111.1111.1111.00</net-addr> <length>8</length> </nsap> </isis-system-info> <log-handler y:self="/rest/operational-state/isis-state/router-isis-config/log-handler"> <log-adj-state-change>is-enabled</log-adj-state-change> <log-bad-lsp>is-disabled</log-bad-lsp> </log-handler> <is-address-family-v4 y:self="/rest/operational-state/isis-state/router-isis-config/is-address-family-v4"> <afi>isis-ipv4-afi</afi> <safi>isis-ipv4-unicast-safi</safi> <originate-default-route>is-enabled</originate-default-route> <originate-default-routemap-name></originate-default-routemap-name> <default-metric>0</default-metric> <l1-default-link-metric>0</l1-default-link-metric> <l2-default-link-metric>0</l2-default-link-metric> <administrative-distance>100</administrative-distance> <maximum-equal-cost-paths>8</maximum-equal-cost-paths> <redist-isis y:self="/rest/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-isis"> <redist-is-l2-to-l1>is-disabled</redist-is-l2-to-l1> <redist-is-l2-to-l1-prefix></redist-is-l2-to-l1-prefix> <redist-is-l1-to-l2>is-enabled</redist-is-l1-to-l2> <redist-is-l1-to-l2-prefix></redist-is-l1-to-l2-prefix> </redist-isis> <redist-ospf y:self="/rest/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-ospf"> <redist-enabled>is-enabled</redist-enabled> <redist-level>isis-level1-2</redist-level> <redist-metric>0</redist-metric> <redist-metric-type>is-metric-internal</redist-metric-type> <redist-routemap-name></redist-routemap-name> <ospf-internal-enabled>is-enabled</ospf-internal-enabled> <ospf-external1-enabled>is-disabled</ospf-external1-enabled> <ospf-external2-enabled>is-disabled</ospf-external2-enabled> </redist-ospf> <redist-static y:self="/rest/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-static"> <redist-enabled>is-enabled</redist-enabled> <redist-level>isis-level2</redist-level> <redist-metric>0</redist-metric> <redist-metric-type>is-metric-internal</redist-metric-type> <redist-routemap-name></redist-routemap-name> </redist-static> <redist-connected y:self="/rest/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-connected"> <redist-enabled>is-disabled</redist-enabled> <redist-level>isis-level2</redist-level> <redist-metric>0</redist-metric> <redist-metric-type>is-metric-internal</redist-metric-type> <redist-routemap-name></redist-routemap-name> </redist-connected> <redist-rip y:self="/rest/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-rip"> <redist-enabled>is-disabled</redist-enabled> <redist-level>isis-level2</redist-level> <redist-metric>0</redist-metric> <redist-metric-type>is-metric-internal</redist-metric-type> <redist-routemap-name></redist-routemap-name> </redist-rip> <redist-bgp y:self="/rest/operational-state/isis-state/router-isis-config/is-address-family-v4/redist-bgp"> <redist-enabled>is-enabled</redist-enabled> <redist-level>isis-level1-2</redist-level> <redist-metric>0</redist-metric> <redist-metric-type>is-metric-internal</redist-metric-type> <redist-routemap-name>"test"</redist-routemap-name> </redist-bgp> <l1-wide-metric-enabled>true</l1-wide-metric-enabled> <l2-wide-metric-enabled>true</l2-wide-metric-enabled> <ldp-sync-enabled>is-disabled</ldp-sync-enabled> <ldp-sync-hold-down>0</ldp-sync-hold-down> </is-address-family-v4> <is-address-family-v6 y:self="/rest/operational-state/isis-state/router-isis-config/is-address-family-v6"> <afi>isis-ipv6-afi</afi> <safi>isis-ipv6-unicast-safi</safi> <originate-default-route>is-disabled</originate-default-route> <originate-default-routemap-name></originate-default-routemap-name> <default-metric>0</default-metric> <l1-default-link-metric>0</l1-default-link-metric> <l2-default-link-metric>0</l2-default-link-metric> <administrative-distance>115</administrative-distance> <maximum-equal-cost-paths>8</maximum-equal-cost-paths> <redist-isis y:self="/rest/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-isis"> <redist-is-l2-to-l1>is-disabled</redist-is-l2-to-l1> <redist-is-l2-to-l1-prefix></redist-is-l2-to-l1-prefix> <redist-is-l1-to-l2>is-enabled</redist-is-l1-to-l2> <redist-is-l1-to-l2-prefix></redist-is-l1-to-l2-prefix> </redist-isis> <redist-ospf y:self="/rest/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-ospf"> <redist-enabled>is-disabled</redist-enabled> <redist-level>isis-level2</redist-level> <redist-metric>0</redist-metric> <redist-metric-type>is-metric-internal</redist-metric-type> <redist-routemap-name></redist-routemap-name> <ospf-internal-enabled>is-enabled</ospf-internal-enabled> <ospf-external1-enabled>is-disabled</ospf-external1-enabled> <ospf-external2-enabled>is-disabled</ospf-external2-enabled> </redist-ospf> <redist-static y:self="/rest/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-static"> <redist-enabled>is-disabled</redist-enabled> <redist-level>isis-level2</redist-level> <redist-metric>0</redist-metric> <redist-metric-type>is-metric-internal</redist-metric-type> <redist-routemap-name></redist-routemap-name> </redist-static> <redist-connected y:self="/rest/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-connected"> <redist-enabled>is-disabled</redist-enabled> <redist-level>isis-level2</redist-level> <redist-metric>0</redist-metric> <redist-metric-type>is-metric-internal</redist-metric-type> <redist-routemap-name></redist-routemap-name> </redist-connected> <redist-rip y:self="/rest/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-rip"> <redist-enabled>is-disabled</redist-enabled> <redist-level>isis-level2</redist-level> <redist-metric>0</redist-metric> <redist-metric-type>is-metric-internal</redist-metric-type> <redist-routemap-name></redist-routemap-name> </redist-rip> <redist-bgp y:self="/rest/operational-state/isis-state/router-isis-config/is-address-family-v6/redist-bgp"> <redist-enabled>is-disabled</redist-enabled> <redist-level>isis-level2</redist-level> <redist-metric>0</redist-metric> <redist-metric-type>is-metric-internal</redist-metric-type> <redist-routemap-name></redist-routemap-name> </redist-bgp> <adjacency-check>is-enabled</adjacency-check> <multi-topology>is-disabled</multi-topology> <mt-transition-state>false</mt-transition-state> </is-address-family-v6> <reverse-metric y:self="/rest/operational-state/isis-state/router-isis-config/reverse-metric"> <reverse-metric-value>0</reverse-metric-value> <rev-metric-whole-lan>is-disabled</rev-metric-whole-lan> <rev-metric-te-def-metric>is-disabled</rev-metric-te-def-metric> <rev-metric-tlv-type>254</rev-metric-tlv-type> </reverse-metric> <debug-handler y:self="/rest/operational-state/isis-state/router-isis-config/debug-handler"> <debug-nsr>is-disabled</debug-nsr> </debug-handler> <l1-auth-profile y:self="/rest/operational-state/isis-state/router-isis-config/l1-auth-profile"> <auth-check>is-disabled</auth-check> <auth-mode>none</auth-mode> </l1-auth-profile> <l2-auth-profile y:self="/rest/operational-state/isis-state/router-isis-config/l2-auth-profile"> <auth-check>is-disabled</auth-check> <auth-mode>none</auth-mode> </l2-auth-profile> <l1-spf-timer y:self="/rest/operational-state/isis-state/router-isis-config/l1-spf-timer"> <init-delay-time>5000</init-delay-time> <hold-down-time>5000</hold-down-time> <max-time>5000</max-time> </l1-spf-timer> <l2-spf-timer y:self="/rest/operational-state/isis-state/router-isis-config/l2-spf-timer"> <init-delay-time>5000</init-delay-time> <hold-down-time>5000</hold-down-time> <max-time>5000</max-time> </l2-spf-timer> <l1-spf6-timer y:self="/rest/operational-state/isis-state/router-isis-config/l1-spf6-timer"> <init-delay-time>5000</init-delay-time> <hold-down-time>5000</hold-down-time> <max-time>5000</max-time> </l1-spf6-timer> <l2-spf6-timer y:self="/rest/operational-state/isis-state/router-isis-config/l2-spf6-timer"> <init-delay-time>5000</init-delay-time> <hold-down-time>5000</hold-down-time> <max-time>5000</max-time> </l2-spf6-timer> <pspf-timer y:self="/rest/operational-state/isis-state/router-isis-config/pspf-timer"> <init-delay-time>2000</init-delay-time> <hold-down-time>5000</hold-down-time> <max-time>5000</max-time> </pspf-timer> <pspf6-timer y:self="/rest/operational-state/isis-state/router-isis-config/pspf6-timer"> <init-delay-time>2000</init-delay-time> <hold-down-time>5000</hold-down-time> <max-time>5000</max-time> </pspf6-timer> </router-isis-config>
