protocol/vrrp-extended
Configures, modifies, or retrieves Virtual Router Redundancy Protocol Extended (VRRP-E)
Resource URIs
URI Description
<base_URI>/config/running/protocol/vrrp-extended Configures Virtual Router Redundancy Protocol Extended (VRRP-E).
GET URIs Description
<base_URI>/config/running/protocol/vrrp-extended Retrieves Virtual Router Redundancy Protocol Extended (VRRP-E).
PATCH URIs Payload Description
<base_URI>/config/running/protocol/vrrp-extended <vrrp-extended>{enumeration}</vrrp-extended> Configures Virtual Router Redundancy Protocol Extended (VRRP-E).
PUT URIs Payload Description
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/protocol/vrrp-extended
None
<vrrp-extended xmlns="urn:brocade.com:mgmt:brocade-vrrp" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/protocol/vrrp-extended">true</vrrp-extended>
URI
The following example uses the PUT option to configure VRRP-E.
<vrrp-extended>true</vrrp-extended>
None
URI
The following example uses the DELETE option to delete a VRRP-E configuration.
None
None
