get-interface-detail
Retrieves operational data for all the VLANs, physical interfaces and port-channels.
Resource URIs
URI Description
<base_URI>/operations/get-interface-detail Retrieves operational data for a given VLAN and enumeration of all the interfaces belonging to this VLAN.
Parameters
interface-type
Displays the interface type.
interface-name
Displays the interface name.
port-mode
Displays the operational mode of the particular interface. This is applicable only for physical interfaces or port-channel interfaces.
if-name
Displays the interface display name as in MIB-II's ifTable. However interface-name and interface-type values of this instance forms fully qualified name for this interface.
if-state
Displays the current operational state of this interface.
line-protocol-state
Displays the 'Line protocol' state of the interface.
line-protocol-state-info
Displays the reason for the current line protocol state of the interface.
hardware-type
Displays the type of the interface.
current-hardware-address
Displays the address of the interface at its protocol sub-layer.
logical-hardware-address
ifindex
A unique value, greater than zero, for each interface.
mtu
Displays the IP MTU value of the interface.
actual-line-speed
Displays the actual line speed of this interface.
configured-line-speed
Displays the administratively configured line speed of the interface.
queuing-strategy
Displays the 'Queuing strategy' for the interface.
ifHCInOctets
Displays the total number of octets received on the interface, including framing characters.
ifHCInUcastPkt
Displays the number of packets, delivered by this sub-layer to a higher (sub-)layer, which were not addressed to a multicast or broadcast address at this sub-layer.
ifHCInMulticastPkts
Displays the number of packets, delivered by this sub-layer to a higher (sub-)layer, which were addressed to a multicast address at the sub-layer. For a MAC layer protocol, this includes both Group and Functional addresses.
ifHCInBroadcastPkts
Displays the number of packets, delivered by the sub-layer to a higher (sub-)layer, which were addressed to a broadcast address at the sub-layer.
ifHCInErrors
For packet-oriented interfaces, the number of inbound packets that contained errors preventing them from being deliverable to a higher-layer protocol. For character-oriented or fixed-length interfaces, the number of inbound transmission units that contained errors preventing them from being deliverable to a higher-layer protocol.
ifHCOutOctets
Displays the total number of octets transmitted out of the interface, including framing characters.
ifHCOutUcastPkts
Displays the total number of packets that higher-level protocols requested be transmitted, and which were not addressed to a multicast or broadcast address at the sub-layer, including those that were discarded or not sent.
ifHCOutMulticastPkts
Displays the total number of packets that higher-level protocols requested be transmitted, and which were addressed to a multicast address at this sub-layer, including those that were discarded or not sent. For a MAC layer protocol, this includes both Group and Functional addresses.
ifHCOutBroadcastPkt
Displays the total number of packets that higher-level protocols requested be transmitted, and which were addressed to a broadcast address at this sub-layer, including those that were discarded or not sent.
ifHCOutErrors
For packet-oriented interfaces, the number of outbound packets that could not be transmitted because of errors. For character-oriented or fixed-length interfaces, the number of outbound transmission units that could not be transmitted because of errors.
media-type
Displays the media type.
wavelength
Displays the wavelength of pluggable media.
if-description
Displays the textual string containing information about the interface.
Usage Guidelines
Only POST operation is supported.
URI
http://host:80/rest/operations/get-interface-detail
<get-interface-detail></get-interface-detail>
<output xmlns='urn:brocade.com:mgmt:brocade-interface-ext'>
  <interface>
    <interface-type>port-channel</interface-type>
    <interface-name>1</interface-name>
    <port-mode>unknown</port-mode>
    <if-name>Port-channel 1</if-name>
    <if-state>up</if-state>
    <line-protocol-state>up</line-protocol-state>
    <hardware-type>aggregate</hardware-type>
    <current-hardware-address>60:9c:9f:0e:e6:f0</current-hardware-address>
    <logical-hardware-address>60:9c:9f:0e:e6:f0</logical-hardware-address>
    <if-description>lag-to-bek-1</if-description>
    <ifindex>671088641</ifindex>
    <mtu>9216</mtu>
    <actual-line-speed>600Gbps</actual-line-speed>
    <configured-line-speed>100Gbps</configured-line-speed>
    <queuing-strategy>fifo</queuing-strategy>
    <ifHCInOctets>82201936202292</ifHCInOctets>
    <ifHCInUcastPkts>316118913731</ifHCInUcastPkts>
    <ifHCInMulticastPkts>466925</ifHCInMulticastPkts>
    <ifHCInBroadcastPkts>0</ifHCInBroadcastPkts>
    <ifHCInErrors>0</ifHCInErrors>
    <ifHCOutOctets>83391499158384</ifHCOutOctets>
    <ifHCOutUcastPkts>320694336080</ifHCOutUcastPkts>
    <ifHCOutMulticastPkts>431024</ifHCOutMulticastPkts>
    <ifHCOutBroadcastPkts>0</ifHCOutBroadcastPkts>
    <ifHCOutErrors>0</ifHCOutErrors>
  </interface>
  <interface>
    <interface-name>2</interface-name>
    <if-name>Port-channel 2</if-name>
    <if-state>down</if-state>
    <line-protocol-state>down</line-protocol-state>
    <line-protocol-state-info> (admin down)</line-protocol-state-info>
    <current-hardware-address>60:9c:9f:0d:3e:4f</current-hardware-address>
    <logical-hardware-address>60:9c:9f:0d:3e:4f</logical-hardware-address>
    <if-description>Insight port-channel on MM2</if-description>
    <ifindex>671088642</ifindex>
    <mtu>1548</mtu>
    <actual-line-speed>nil</actual-line-speed>
    <configured-line-speed>10Gbps</configured-line-speed>
    <ifHCInOctets>0</ifHCInOctets>
    <ifHCInUcastPkts>0</ifHCInUcastPkts>
    <ifHCInMulticastPkts>0</ifHCInMulticastPkts>
    <ifHCOutOctets>0</ifHCOutOctets>
    <ifHCOutUcastPkts>0</ifHCOutUcastPkts>
    <ifHCOutMulticastPkts>0</ifHCOutMulticastPkts>
  </interface>
  <has-more>false</has-more>
</output>
If the entire information cannot be retrieved in a single execution, the last lines of output says has-more=true.
<has-more xmlns="urn:brocade.com:mgmt:brocade-interface-ext">true</has-more>
</rpc-reply>
In such cases the remaining information can be retrieved using "last-rcvd-interface" as shown in the request body below.
  <last-rcvd-interface>
    <interface-name>3</interface-name>
  </last-rcvd-interface>
The API can be used to retrieve information regarding a specific port by applying filter as in the request body below.
