Configures, modifies and updates a template of auto-bandwidth parameters that can be applied to a path of an LSP.
URI | Description |
<base_URI>/operational-state/mpls-state/auto-bandwidth-template | Displays the auto-bandwidth templates. |
<base_URI>/operational-state/mpls-state/auto-bandwidth-template/{name}/adjustment-interval | Displays the adjustment interval - the time interval after which the LSP bandwidth should be adjusted. |
<base_URI>/operational-state/mpls-state/auto-bandwidth-template/{name}/adjustment-threshold | Displays the adjustment threshold: bandwidth will be adjusted only if the percentage difference of Max-Sample-BW w.r.t current-BW is greater than this value. |
<base_URI>/operational-state/mpls-state/auto-bandwidth-template/{name}/maximum-bandwidth | Displays maximum-bandwidth: the LSP bandwidth can never be greater than this value |
<base_URI>/operational-state/mpls-state/auto-bandwidth-template/{name}/minimum-bandwidth | Displays minimum-bandwidth: the LSP bandwidth can never be lower than this value |
<base_URI>/operational-state/mpls-state/auto-bandwidth-template/{name}/overflow-limit | Displays overflow-limit: The least number of times the sampled-BW should consecutively overflow adjustment-threshold to trigger premature adjustment. |
<base_URI>/operational-state/mpls-state/auto-bandwidth-template/{name}/underflow-limit | Displays underflow-limit: The number of consecutive samples which have to be below the threshold to trigger a premature adjustment. |
<base_URI>/operational-state/mpls-state/auto-bandwidth-template/{name}/mode | Displays mode value. Values are monitor-only or monitor-and-signal. If the mode is set to monitor-only, the adjustment of bandwidth will be disabled and only the rate info will be collected. |
<base_URI>/operational-state/mpls-state/auto-bandwidth-template/{name}/sample-recording | Displays whether the template is set to record the sample history. Values: enable or disable. |
<base_URI>/operational-state/mpls-state/auto-bandwidth-template/{name}/associated-paths-count | Displays the number of LSP paths associated with an auto-bandwidth template. |
<base_URI>/operational-state/mpls-state/auto-bandwidth-template/{name}/associated-paths | Displays the LSP paths associated with an auto-bandwidth template. |
<base_URI>/operational-state/mpls-state/auto-bandwidth-template/{name}/associated-paths/{lsp-name}/path-name | Displays the path currently selected for a particular LSP. |
<base_URI>/operational-state/mpls-state/auto-bandwidth-template/{name}/associated-paths/{lsp-name}/is-active | Displays whether the path for an LSP is active. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example uses the GET option to retrieve the configuration details of the auto-bandwidth template "aaa".
http://host:80/rest/operational-state/mpls-state/auto-bandwidth-template/aaa
None
<auto-bandwidth-template xmlns="urn:brocade.com:mgmt:brocade-mpls-operational" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/operational-state/mpls-state/auto-bandwidth-template/aaa"> <name>aaa</name> <adjustment-interval>1800</adjustment-interval> <adjustment-threshold>0</adjustment-threshold> <maximum-bandwidth>2147483647</maximum-bandwidth> <minimum-bandwidth>5000</minimum-bandwidth> <overflow-limit>0</overflow-limit> <underflow-limit>0</underflow-limit> <mode>false</mode> <sample-recording>false</sample-recording> <associated-paths-count>0</associated-paths-count> </auto-bandwidth-template>
