router/mpls/dynamic-bypass
Configures, modifies or retrieves MPLS Dynamic Bypass LSP information.
Resource URIs
URI Description
<base_URI>/config/running/router/mpls/dynamic-bypass Configures, modifies or retrieves MPLS Dynamic Bypass LSP information.
GET URIs Description
<base_URI>/config/running/router/mpls/dynamic-bypass Displays MPLS Dynamic Bypass LSP information.
<base_URI>/config/running/router/mpls/dynamic-bypass/max-bypasses Displays maximum number of dynamic bypass LSPs that can be created for this MPLS interface.
<base_URI>/config/running/router/mpls/dynamic-bypass/max-bypasses-per-mp Displays the limit for total number of dynamic bypass LSPs that can be created to a merge point.
<base_URI>/config/running/router/mpls/dynamic-bypass/enable-all-interfaces Returns true if dynamic bypass on all MPLS interfaces is enabled.
<base_URI>/config/running/router/mpls/dynamic-bypass/reoptimize-timer Displays re-optimization value.
<base_URI>/config/running/router/mpls/dynamic-bypass/disable Returns true if Disable dynamic bypass is set.
POST URIs Payload Description
<base_URI>/config/running/router/mpls <dynamic-bypass /> Configures Displays MPLS Dynamic Bypass LSP.
PATCH URIs Payload Description
<base_URI>/config/running/router/mpls/dynamic-bypass <dynamic-bypass><max-bypasses>{uint32}</max-bypasses></dynamic-bypass> Sets maximum number of dynamic bypass LSPs that can be created for this MPLS interface.
<base_URI>/config/running/router/mpls/dynamic-bypass <dynamic-bypass><max-bypasses-per-mp>{uint32}</max-bypasses-per-mp></dynamic-bypass> Sets the limit for total number of dynamic bypass LSPs that can be created to a merge point.
<base_URI>/config/running/router/mpls/dynamic-bypass <dynamic-bypass><enable-all-interfaces>true</enable-all-interfaces></dynamic-bypass> Enables dynamic bypass on all MPLS interfaces.
<base_URI>/config/running/router/mpls/dynamic-bypass <dynamic-bypass><reoptimize-timer>{uint32}</reoptimize-timer></dynamic-bypass> Sets re-optimization value.
<base_URI>/config/running/router/mpls/dynamic-bypass <dynamic-bypass><disable>true</disable></dynamic-bypass> Disables dynamic bypass.
PUT URIs Payload Description
<base_URI>/config/running/router/mpls/dynamic-bypass <dynamic-bypass /> Configures Displays MPLS Dynamic Bypass LSP.
<base_URI>/config/running/router/mpls/dynamic-bypass/max-bypasses <max-bypasses>{uint32}</max-bypasses> Sets maximum number of dynamic bypass LSPs that can be created for this MPLS interface.
<base_URI>/config/running/router/mpls/dynamic-bypass/max-bypasses-per-mp <max-bypasses-per-mp>{uint32}</max-bypasses-per-mp> Sets the limit for total number of dynamic bypass LSPs that can be created to a merge point.
<base_URI>/config/running/router/mpls/dynamic-bypass/enable-all-interfaces <enable-all-interfaces>true</enable-all-interfaces> Enables dynamic bypass on all MPLS interfaces.
<base_URI>/config/running/router/mpls/dynamic-bypass/reoptimize-timer <reoptimize-timer>{uint32}</reoptimize-timer> Sets re-optimization value.
<base_URI>/config/running/router/mpls/dynamic-bypass/disable <disable>true</disable> Disables dynamic bypass.
DELETE URIs
Parameters
max-bypasses
Maximum number of dynamic bypass LSPs that can be created for this MPLS interface.
max-bypasses-per-mp
The limit for total number of dynamic bypass LSPs that can be created to a merge point.
Enable a dynamic bypass on all MPLS interfaces.
reoptimize-timer
Reoptimiztion timer value in seconds for the dynamic bypass LSPs. Range 30 - 65535 seconds. The default is 0, which means re-optimization is disabled.
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/router/mpls/dynamic-bypass
None
<dynamic-bypass xmlns="urn:brocade.com:mgmt:brocade-mpls" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/router/mpls/dynamic-bypass">
  <max-bypasses>500</max-bypasses>
  <max-bypasses-per-mp>500</max-bypasses-per-mp>
  <reoptimize-timer>301</reoptimize-timer>
</dynamic-bypass>
URI
The following example uses the PATCH option to enable all interfacesfor dynamic bypass.
None.
URI
The following example uses the DELETE option to delete maximum bypasses per mp.
http://host:80/rest/config/running/router/mpls/dynamic-bypass/max-bypasses-per-mp
None
None
