interface/vlan/{vlan-number}/suppress-arp
Enables Address Resolution Protocol (ARP) suppression on the current VLAN, lessening ARP-related traffic within an IP Fabric.
Resource URIs
URI Description
<base_URI>/config/running/interface/vlan/{vlan-number}/suppress-arp Enables Address Resolution Protocol (ARP) suppression on the current VLAN.
Parameters
enable
Enables ARP suppression on the current VLAN.
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/vlan/8000/suppress-arp
None
<suppress-arp xmlns="urn:brocade.com:mgmt:brocade-arp" y:self="/rest/config/running/interface/Vlan/8000/suppress-arp">
  <enable>true</enable>
</suppress-arp>
