Displays IS-IS Interface information
| URI | Description |
| <base_URI>/operational-state/isis-state/interface-detail | Displays IS-IS Interface information. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf | Displays IS-IS interface information for a specified interface. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/v4circuit-enabled | Displays whether ISISv4 is enabled or not. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/v6circuit-enabled | Displays whether ISISv6 is enabled or not. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circuit-id | Displays IS-IS circuit ID. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circuit-ifid | Displays IS-IS ID |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circuit-state | Displays IS-IS circuit state. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circuit-ip-state | Displays true if ISISv4 is enabled. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circuit-ipv6-state | Displays true if ISISv6 is enabled. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circuit-mode | Displays ISIS interface circuit mode. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circuit-type | Displays ISIS interface circuit type. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/is-circuit-passive | Displays whether ISIS passive is enabled or not. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/mtu-size | Displays ISIS interface MTU value. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/padding-enabled | Displays whether Hello Padding is enabled or not. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-chstats | Displays Circuit State. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-chstats/circ-changes | Displays Circuit State Changes. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-chstats/adj-changes | Displays Circuit Adjacencies State Changes. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-chstats/adj-rej | Displays Rejected Adjacencies. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-chstats/l1authfail | Displays Circuit Authentication L1 failures. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-chstats/l2authfail | Displays Circuit Authentication L2 failures. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-chstats/bad-lsps | Displays Bad LSPs. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-chstats/ctrl-out | Displays Control Messages Sent. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-chstats/ctrl-in | Displays Control Messages Received |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/mpls-info | Displays mpls info |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/mpls-info/te-enabled | Displays whether MPLS TE is enabled or not |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/mpls-info/admin-group | Displays admin group information. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/mpls-info/te-metric | Displays TE metric value. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/mpls-info/max-link-bw | Displays max link bandwidth. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/mpls-info/max-reserv-bw | Displays max reserve bandwidth. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/reverse-metric-info/is-global-config | Displays True if reverse metric is enabled at global level. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/reverse-metric-info/reverse-metric-value | Displays Reverse Metric value |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/reverse-metric-info/rev-metric-whole-lan | Displays whether Reverse Metric is enabled for the whole LAN or not |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/reverse-metric-info/rev-metric-te-def-metric | Displays TE Default metric sub-TLV. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/ldp-sync-info | Displays LDP sync information. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/ldp-sync-info/ldp-sync-enabled | Displays whether LDP sync is enabled or not. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/ldp-sync-info/ldp-sync-hold-down | Displays LDP sync hold-down timer. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/ldp-sync-info/ldp-in-sync | Displays LDP sync status. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/ldp-sync-info/remain-hd-time | Displays Remain HD Timer value. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/ldp-sync-info/ldp-sync-hd-expired | Displays LDP sync HD expired value. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-metrics | Displays circuit metrics info. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-metrics/val_level_val/auth-check | Displays Authentication Check status |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-metrics/val_level_val/auth-mode | Displays Authentication mode. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-metrics/val_level_val/auth-key | Displays Authentication key. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-metrics/val_level_val/circ-metric | Displays ISIS interface metric. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-metrics/val_level_val/ip6-circ-metric | Displays ISISv6 interface metric. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-metrics/val_level_val/circ-priority | Displays Pr.iority for ISIS |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-metrics/val_level_val/hello-int | Displays interval between hello PDUs. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-metrics/val_level_val/hello-mult | Displays Multiplier of hello interval. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-metrics/val_level_val/dis | Displays Designated IS |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-metrics/val_level_val/dis-ch | Displays Designated IS Changes. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-metrics/val_level_val/next-hello | Displays Next hello packet. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/circ-metrics/val_level_val/active-adj | Displays number of Active Adjacency. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/ip-info | Displays IP Address information. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/ip-info/val_ip-add_val/ip-prefix | Displays the IP Address Prefix Length value |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/ip6-info | Displays IPv6 address information. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/ip6-info/val_ip6-add_val/ip6-prefix | Displays the IPv6 Address Prefix Length value. |
| <base_URI>/operational-state/isis-state/interface-detail/isis-intf/val_intf-type_val/val_intf-number_val/ip6-info/val_ip6-add_val/is-link-local | Displays True if the IPv6 address is link local. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/operational-state/isis-state/interface-detail
None
<interface-detail xmlns="urn:brocade.com:mgmt:brocade-isis-operational" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/operational-state/isis-state/interface-detail">
<isis-intf y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%221/49%22">
<intf-type>eth</intf-type>
<intf-number>1/49</intf-number>
<v4circuit-enabled>is-enabled</v4circuit-enabled>
<v6circuit-enabled>is-enabled</v6circuit-enabled>
<circuit-id>3</circuit-id>
<circuit-ifid>432</circuit-ifid>
<circuit-state>true</circuit-state>
<circuit-ip-state>true</circuit-ip-state>
<circuit-ipv6-state>true</circuit-ipv6-state>
<circuit-mode>isis-level1-2</circuit-mode>
<circuit-type>is-circ-lan</circuit-type>
<circuit-encap>undef</circuit-encap>
<is-circuit-passive>is-disabled</is-circuit-passive>
<mtu-size>1500</mtu-size>
<padding-enabled>is-enabled</padding-enabled>
<bfd-enabled>is-disabled</bfd-enabled>
<circ-chstats y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%221/49%22/circ-chstats">
<circ-changes>1</circ-changes>
<adj-changes>2</adj-changes>
<adj-rej>0</adj-rej>
<l1authfail>0</l1authfail>
<l2authfail>0</l2authfail>
<bad-lsps>0</bad-lsps>
<ctrl-out>2806</ctrl-out>
<ctrl-in>1044</ctrl-in>
</circ-chstats>
<mpls-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%221/49%22/mpls-info">
<te-enabled>is-disabled</te-enabled>
<admin-group>0</admin-group>
<te-metric>0</te-metric>
<max-link-bw>0</max-link-bw>
<max-reserv-bw>0</max-reserv-bw>
</mpls-info>
<reverse-metric-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%221/49%22/
reverse-metric-info">
<is-global-config>true</is-global-config>
<reverse-metric-value>0</reverse-metric-value>
<rev-metric-whole-lan>is-disabled</rev-metric-whole-lan>
<rev-metric-te-def-metric>is-disabled</rev-metric-te-def-metric>
</reverse-metric-info>
<ldp-sync-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%221/49%22/ldp-sync-info">
<ldp-sync-enabled>is-disabled</ldp-sync-enabled>
<ldp-sync-hold-down>0</ldp-sync-hold-down>
<ldp-in-sync>false</ldp-in-sync>
<remain-hd-time>0</remain-hd-time>
<ldp-sync-hd-expired>false</ldp-sync-hd-expired>
</ldp-sync-info>
<circ-metrics y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%221/49%22/circ-metrics/
isis-level1">
<level>isis-level1</level>
<auth-check>is-enabled</auth-check>
<auth-mode>none</auth-mode>
<auth-key></auth-key>
<circ-metric>10</circ-metric>
<ip6-circ-metric>10</ip6-circ-metric>
<circ-priority>64</circ-priority>
<hello-int>3</hello-int>
<hello-mult>3</hello-mult>
<dis>Fusion1-03</dis>
<dis-ch>4</dis-ch>
<next-hello>3</next-hello>
<active-adj>1</active-adj>
</circ-metrics>
isis-level2">
<level>isis-level2</level>
<dis-ch>4</dis-ch>
<next-hello>4</next-hello>
</circ-metrics>
<ip-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%221/49%22/ip-info/140.140.140.1">
<ip-add>140.140.140.1</ip-add>
<ip-prefix>24</ip-prefix>
</ip-info>
<ip6-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%221/49%22/ip6-info/140:140:140::1">
<ip6-add>140:140:140::1</ip6-add>
<ip6-prefix>64</ip6-prefix>
<is-link-local>false</is-link-local>
</ip6-info>
fe80::748e:f8ff:fe05:4835">
<ip6-add>fe80::748e:f8ff:fe05:4835</ip6-add>
<ip6-prefix>128</ip6-prefix>
<is-link-local>true</is-link-local>
</ip6-info>
</isis-intf>
<isis-intf y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%224/10%22">
<intf-number>4/10</intf-number>
<circuit-id>4</circuit-id>
<circuit-ifid>1545</circuit-ifid>
<mtu-size>9000</mtu-size>
<padding-enabled>is-disabled</padding-enabled>
<circ-chstats y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%224/10%22/circ-chstats">
<adj-changes>0</adj-changes>
<ctrl-out>694</ctrl-out>
<ctrl-in>0</ctrl-in>
</circ-chstats>
<mpls-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%224/10%22/mpls-info">
</mpls-info>
<reverse-metric-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%224/10%22/
<is-global-config>false</is-global-config>
<reverse-metric-value>555</reverse-metric-value>
<rev-metric-whole-lan>is-enabled</rev-metric-whole-lan>
<rev-metric-te-def-metric>is-enabled</rev-metric-te-def-metric>
<ldp-sync-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%224/10%22/ldp-sync-info">
</ldp-sync-info>
<circ-metrics y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%224/10%22/circ-metrics/
isis-level1">
<auth-check>is-disabled</auth-check>
<auth-mode>md5</auth-mode>
<auth-key>********</auth-key>
<circ-metric>22777</circ-metric>
<ip6-circ-metric>22777</ip6-circ-metric>
<circ-priority>100</circ-priority>
<hello-int>10</hello-int>
<dis>Fusion1-04</dis>
<dis-ch>2</dis-ch>
<next-hello>10</next-hello>
<active-adj>0</active-adj>
</circ-metrics>
isis-level2">
<circ-metric>565</circ-metric>
<ip6-circ-metric>565</ip6-circ-metric>
<circ-priority>99</circ-priority>
<hello-int>18</hello-int>
<hello-mult>5</hello-mult>
<dis-ch>2</dis-ch>
<next-hello>14</next-hello>
</circ-metrics>
<ip-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%224/10%22/ip-info/10.1.1.1">
<ip-add>10.1.1.1</ip-add>
</ip-info>
<ip6-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/eth%2C%224/10%22/ip6-info/10:1:1::1">
<ip6-add>10:1:1::1</ip6-add>
</ip6-info>
fe80::748e:f8ff:fe05:4ade">
<ip6-add>fe80::748e:f8ff:fe05:4ade</ip6-add>
</ip6-info>
</isis-intf>
<isis-intf y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/ve%2C101">
<intf-type>ve</intf-type>
<intf-number>101</intf-number>
<circuit-id>2</circuit-id>
<circuit-ifid>8164</circuit-ifid>
<circuit-mode>isis-level2</circuit-mode>
<circuit-type>is-circ-ptpt</circuit-type>
<circ-chstats y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/ve%2C101/circ-chstats">
<ctrl-out>440</ctrl-out>
<ctrl-in>441</ctrl-in>
</circ-chstats>
<mpls-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/ve%2C101/mpls-info">
<te-metric>3555</te-metric>
</mpls-info>
<reverse-metric-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/ve%2C101/
<ldp-sync-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/ve%2C101/ldp-sync-info">
<ldp-sync-enabled>is-enabled</ldp-sync-enabled>
</ldp-sync-info>
<circ-metrics y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/ve%2C101/circ-metrics/
isis-level1">
<circ-metric>3555</circ-metric>
<ip6-circ-metric>3555</ip6-circ-metric>
<dis>Fusion1-02</dis>
<dis-ch>0</dis-ch>
<next-hello>0</next-hello>
</circ-metrics>
isis-level2">
<dis-ch>0</dis-ch>
</circ-metrics>
<ip-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/ve%2C101/ip-info/11.11.1.1">
<ip-add>11.11.1.1</ip-add>
</ip-info>
<ip6-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/ve%2C101/ip6-info/11:11:1::1">
<ip6-add>11:11:1::1</ip6-add>
</ip6-info>
fe80::748e:f8ff:fe05:4801">
<ip6-add>fe80::748e:f8ff:fe05:4801</ip6-add>
</ip6-info>
</isis-intf>
<isis-intf y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/loopback%2C4">
<intf-type>loopback</intf-type>
<intf-number>4</intf-number>
<circuit-id>1</circuit-id>
<circuit-ifid>16259</circuit-ifid>
<is-circuit-passive>is-enabled</is-circuit-passive>
<mtu-size>0</mtu-size>
<circ-chstats y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/loopback%2C4/circ-chstats">
<ctrl-out>0</ctrl-out>
</circ-chstats>
<mpls-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/loopback%2C4/mpls-info">
</mpls-info>
<reverse-metric-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/loopback%2C4/
<ldp-sync-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/loopback%2C4/
ldp-sync-info">
</ldp-sync-info>
<circ-metrics y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/loopback%2C4/
circ-metrics/isis-level1">
<circ-metric>4555</circ-metric>
<ip6-circ-metric>4555</ip6-circ-metric>
<circ-priority>10</circ-priority>
<dis>Fusion1-01</dis>
<dis-ch>0</dis-ch>
</circ-metrics>
circ-metrics/isis-level2">
<hello-int>20</hello-int>
<dis-ch>0</dis-ch>
</circ-metrics>
<ip-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/loopback%2C4/ip-info/1.1.1.4">
<ip-add>1.1.1.4</ip-add>
<ip-prefix>32</ip-prefix>
</ip-info>
<ip6-info y:self="/rest/operational-state/isis-state/interface-detail/isis-intf/loopback%2C4/
ip6-info/0:0:0:0:0:0:0:1">
<ip6-add>0:0:0:0:0:0:0:1</ip6-add>
</ip6-info>
</isis-intf>
</interface-detail>
