Configures, retrieves, and modifies static route to the IP routing table.
| URI | Description |
| <base_URI>/config/running/ip/route | Configures static route to the IP routing table. |
| GET URIs | Description |
| <base_URI>/config/running/ip/route | Retrieves static route to the IP routing table. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/ip/route | <static-route-nh><static-route-dest>{ip-address}</static-route-dest><static-route-next-hop>{ip-address}</static-route-next-hop></static-route-nh></static-route-nh> | Specifies the destination IPv4 address and mask in the format A.B.C.D/L (where "L" is the prefix length of the mask) |
| <base_URI>/config/running/ip/route | <static-route-oif><static-route-dest>{ip-address}</static-route-dest><static-route-oif-type>{enumeration}</static-route-oif-type><InterfaceNumber>{string}</InterfaceNumber></static-route-oif> | Specifies the destination IPv4 address for egress interface. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/ip/route/static-route-nh/{static-route-dest},{static-route-next-hop}/metric | <metric>{unit32}</metric> | Configures the cost metric of the route. Valid values range from 1 through 16. |
| <base_URI>/config/running/ip/route/static-route-nh/{static-route-dest},{static-route-next-hop}/distance | <distance>{unit32}</distance> | Configures the administrative distance of the route. When comparing otherwise equal routes to a destination, a Extreme device prefers lower administrative distances over higher ones. |
| <base_URI>/config/running/ip/route/static-route-nh/{static-route-dest},{static-route-next-hop}/tag | <tag>{unit32}</tag> | Configures the tag value of the route to use for route filtering with a route map. |
| <base_URI>/config/running/ip/route/static-route-oif/{static-route-dest},{static-route-oif-type},{InterfaceNumber}/metric | <metric>{unit32}</metric> | Configures the cost metric of the route for egress interface. Valid values range from 1 through 16. |
| <base_URI>/config/running/ip/route/static-route-oif/{static-route-dest},{static-route-oif-type},{InterfaceNumber}/distance | <distance>{unit32}</distance> | Configures the administrative distance of the route for egress interface. When comparing otherwise equal routes to a destination, a Extreme device prefers lower administrative distances over higher ones. |
| <base_URI>/config/running/ip/route/static-route-oif/{static-route-dest},{static-route-oif-type},{InterfaceNumber}/tag | <tag>{unit32}</tag> | Configures the tag value of the route to use for route filtering with a route map for egress interface. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/ip/route/static-route-nh/{static-route-dest},{static-route-next-hop} | <base_URI><static-route-nh><metric>{uint32}</metric></static-route-nh> | Configures the cost metric of the route. |
| <base_URI>/config/running/ip/route/static-route-nh/{static-route-dest},{static-route-next-hop} | base_URI><static-route-nh><distance>{uint32}</distance></static-route-nh> | Configures the administrative distance of the route. |
| <base_URI>/config/running/ip/route/static-route-nh/{static-route-dest},{static-route-next-hop} | <base_URI><static-route-nh><tag>{uint32}</tag></static-route-nh> | Configures the tag value of the route to use for route filtering with a route map. |
| <base_URI>/config/running/ip/route/static-route-oif/{static-route-dest},{static-route-oif-type},{InterfaceNumber} | <base_URI><static-route-oif><metric>{uint32}</metric></static-route-oif> | Configures the cost metric of the route for egress interface. |
| <base_URI>/config/running/ip/route/static-route-oif/{static-route-dest},{static-route-oif-type},{InterfaceNumber} | <base_URI><static-route-oif><distance>{uint32}</distance></static-route-oif> | Configures the administrative distance of the route for egress interface. |
| <base_URI>/config/running/ip/route/static-route-oif/{static-route-dest},{static-route-oif-type},{InterfaceNumber} | <base_URI><static-route-oif><tag>{uint32}</tag></static-route-oif> | Configures the tag value of the route to use for route filtering with a route map for egress interface. |
| DELETE URIs |
| <base_URI>/config/running/ip/router-id |
Specifies the tag value of the route to use for route filtering with a route map. Valid values range from 0 through 4294967295. The default is 0.
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/ip/route
None
<route xmlns="urn:Extreme.com:mgmt:Extreme-rtm" y:self="/rest/config/running/ip/route"> </route>
The following example uses the POST option to configure static route to the IP routing table.
http://host:80/rest/config/running/config/running/ip/route
<static-route-nh><static-route-dest>13.1.1.0/24</static-route-dest><static-route-next-hop>11.1.1.2</static-route-next-hop> </static-route-nh>
None
The following example uses the DELETE option to remove static route to the IP routing table.
http://host:80/rest/config/running/ip/route/static-route-nh/%2216.1.1.0/24%22%2C14.1.1.2
None
None
