Configures, modifies, or retrieves the Internet Protocol (IP) access list configuration.
| URI | Description |
| <base_URI>/config/running/ip | The Internet Protocol configuration. |
| <base_URI>/config/running/ip/access-list/standard | Standard IP ACL configuration. |
| <base_URI>/config/running/ip/access-list/standard/{ACL-name}/seq | Sequence number configuration. |
| <base_URI>/config/running/ip/access-list/extended | Extended IP ACL configuration. |
| <base_URI>/config/running/ip/access-list/extended/{ACL-name}/seq | Sequence number configuration. |
| GET URIs | Description |
| <base_URI>/config/running/ip/access-list | Retrieves IP access list. |
| <base_URI>/config/running/ip/access-list/standard | Retrieves standard IP access list. |
| <base_URI>/config/running/ip/access-list/standard/{acl-name} | Retrieves a standard IP ACL. |
| <base_URI>/config/running/ip/access-list/extended | Retrieves extended IP access list. |
| <base_URI>/config/running/ip/access-list/extended/{acl-name} | Retrieves an extended IP ACL. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/ip/access-list | <standard><name>{acl-name}</name></standard> | Configures a standard ACL. |
| <base_URI>/config/running/ip/access-list | <extended><name>{acl-name}</name></extended> | Configures an extended ACL. |
| DELETE URIs |
| <base_URI>/config/running/running/ip/access-list |
| <base_URI>/config/running/running/ip/access-list/standard |
| <base_URI>/config/running/running/ip/access-list/standard/{name} |
| <base_URI>/config/running/running/ip/access-list/standard/{acl-name}/seq/{seq-id} |
| <base_URI>/config/running/running/ip/access-list/extended |
| <base_URI>/config/running/running/ip/access-list/extended/{name} |
| <base_URI>/config/running/running/ip/access-list/extended/{acl-name}/seq/{seq-id} |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the access list configurations.
http://host:80/rest/config/running/ip/access-list
None
<access-list xmlns="urn:brocade.com:mgmt:brocade-ip-access-list" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/ip/access-list">
    <standard y:self="/rest/config/running/ip/access-list/standard/managementtest">
        <name>managementtest</name>
    </standard>
    <standard y:self="/rest/config/running/ip/access-list/standard/stdacl1">
        <name>stdacl1</name>
    </standard>
    <extended y:self="/rest/config/running/ip/access-list/extended/Sachin">
        <name>Sachin</name>
    </extended>
    <extended y:self="/rest/config/running/ip/access-list/extended/extacl1">
        <name>extacl1</name>
    </extended>
    <extended y:self="/rest/config/running/ip/access-list/extended/shipra">
        <name>shipra</name>
    </extended>
    <extended y:self="/rest/config/running/ip/access-list/extended/test1">
        <name>test1</name>
    </extended>
</access-list>
		The following example uses the POST option to configure a standard access list.
<standard >
    <name>std10</name>
</standard>
		None
The following example uses the DELETE option to remove a standard access list.
http://host:80/rest/config/running/ip/access-list/standard/std10
None
None
