router/isis
Configures IS-IS protocol.
Resource URIs
URI Description
<base_URI>/config/running/router/isis Configures IS-IS protocol.
GET URIs Description
<base_URI>/config/running/router/isis Enables IS-IS.
<base_URI>/config/running/router/isis/net/{net-cmd} Defines NSAP address.
<base_URI>/config/running/router/isis/auth-check Authenticate incoming PDUs for LSPs, CSNP, and PSNP.
<base_URI>/config/running/router/isis/auth-check/level-1 Authenticate incoming PDUs for Level-1 LSPs, CSNP, and PSNP.
<base_URI>/config/running/router/isis/auth-check/level-1/disable Disables authentication of incoming PDUs for Level-1 LSPs, CSNP, and PSNP.
<base_URI>/config/running/router/isis/auth-check/level-2 Authenticate incoming PDUs for Level-2 LSPs, CSNP, and PSNP.
<base_URI>/config/running/router/isis/auth-check/level-2/disable Disables the authenticate incoming PDUs for Level-2 LSPs, CSNP, and PSNP.
<base_URI>/config/running/router/isis/auth-mode Define authentication mode.
<base_URI>/config/running/router/isis/auth-mode/md5 HMAC-MD5 authentication.
<base_URI>/config/running/router/isis/auth-mode/md5/level-1 Authentication mode for Level-1 LSPs, CSNP, and PSNP.
<base_URI>/config/running/router/isis/auth-mode/md5/level-2 Authentication mode for Level-2 LSPs, CSNP, and PSNP.
<base_URI>/config/running/router/isis/auth-key Define authentication key
<base_URI>/config/running/router/isis/auth-key/level-1 Auth-key for Level-1 ISIS Router
<base_URI>/config/running/router/isis/auth-key/level-2 Auth-key for Level-2 ISIS Router
<base_URI>/config/running/router/isis/csnp-interval Rate of transmission of CSNPs
<base_URI>/config/running/router/isis/disable-inc-stct-spf-opt Disables Incremental Shortcut SPF Optimizations; resorts to Full SPF
<base_URI>/config/running/router/isis/disable-incremental-spf-opt Disables Incremental SPF Optimizations; resorts to Full SPF
<base_URI>/config/running/router/isis/disable-partial-spf-opt Disables Partial SPF Optimizations; resorts to Full SPF
<base_URI>/config/running/router/isis/fast-flood Defines the number of LSPs to be flooded before SPF Run
<base_URI>/config/running/router/isis/fast-flood/fast-flood-value The number of LSPS to be flooded before SPF Run. Range is 1-15; default is 4
<base_URI>/config/running/router/isis/graceful-restart Enables the ISIS graceful restart capability
<base_URI>/config/running/router/isis/graceful-restart/helper-disable Disables Helper Mode
<base_URI>/config/running/router/isis/hostname Integrated IS-IS dynamic hostname
<base_URI>/config/running/router/isis/hostname/disable Disables integrated IS-IS dynamic hostname
<base_URI>/config/running/router/isis/is-type Define inter-area/intra area operation mode
<base_URI>/config/running/router/isis/log Enable Logging IS-IS activities
<base_URI>/config/running/router/isis/log/adjacency Logging Adjacency Changes
<base_URI>/config/running/router/isis/log/invalid-lsp-packets Logging Invalid LSP Packets
<base_URI>/config/running/router/isis/lsp-gen-interval Minimum interval between regenerating same LSP
<base_URI>/config/running/router/isis/lsp-interval Rate of transmission of LSPs
<base_URI>/config/running/router/isis/lsp-refresh-interval LSP refresh interval
<base_URI>/config/running/router/isis/max-lsp-lifetime Maximum LSP lifetime
<base_URI>/config/running/router/isis/nonstop-routing Enables the ISIS nonstop routing capability
<base_URI>/config/running/router/isis/partial-spf-interval Partial SPF Calculation Timers
<base_URI>/config/running/router/isis/partial-spf-interval/pspf-max-hold-time Max hold time (msec) between two PSPF calculations. Range is 0-120000. Default is 5000.
<base_URI>/config/running/router/isis/partial-spf-interval/pspf-init-delay Initial delay (msec) between receiving a LSP change to PSPF calculation. Range is 0-120000. Default is 2000.
<base_URI>/config/running/router/isis/partial-spf-interval/pspf-hold-time Hold time (msec) between two PSPF calculations. 0-120000. Default is 5000
<base_URI>/config/running/router/isis/retransmit-interval Time between retransmission of LSP.
<base_URI>/config/running/router/isis/set-debug Enabling isis debug configuration.
<base_URI>/config/running/router/isis/set-debug/nsr Sets nsr debug.
<base_URI>/config/running/router/isis/set-overload-bit Configures a device to signal other devices not to use it as an intermediate hop in their shortest path first (SPF) calculations if an IS‘s resources are overloaded and are preventing the IS from properly performing IS-IS routing.
<base_URI>/config/running/router/isis/set-overload-bit/on-startup Set overload-bit only temporarily on reboot.
<base_URI>/config/running/router/isis/spf-interval/level-1 SPF calculation Timers
<base_URI>/config/running/router/isis/reverse-metric Configure IS-IS reverse metric at the router level.
<base_URI>/config/running/router/isis/reverse-metric/reverse_metric_tlv Configure reverse metric TLV.
<base_URI>/config/running/router/isis/reverse-metric/tlv-type Configure reverse metric TLV type.
<base_URI>/config/running/router/isis/reverse-metric/rev-metric-val Configure IS-IS reverse metric value.
<base_URI>/config/running/router/isis/reverse-metric/whole-lan Change metric for whole LAN.
<base_URI>/config/running/router/isis/reverse-metric/te-def-metric Update TE default metric sub-tlv.
<base_URI>/config/running/router/isis/address-family Enter Address Family command mode.
<base_URI>/config/running/router/isis/address-family/ipv4 IPv4 address Family.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast IPv4 unicast address Family.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/metric-style Use narrow or wide metric type.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/metric-style/wide Use new style of TLVs to carry wider metric.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/metric-style/wide/level-1 Level-1 only.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/metric-style/wide/level-2 Level-2 only.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/summary-address/{summary-ip},{summary-ip-mask} Configure Integrated IS-IS address summaries
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/summary-address/{summary-ip},{summary-ip-mask}/level-1 Configure Integrated IS-IS address summaries.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/ldp-sync Enable LDP-SYNC on all eligible ISIS interfaces.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/ldp-sync/hold-down Length (in seconds) of hold-down timer. Range is 1-65535.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-link-metric Default Link Metric.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-link-metric/level-1 Default Link Metric for Level-1.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-link-metric/level-2 Default Link Metric for Level-2.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-information-originate Controls origination of default route.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-information-originate/route-map Uses route map.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-information-originate/default-information-originate-cr Controls origination of default route.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-metric Metric for route redistribution.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/distance Defines an administrative distance.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/maximum-paths Calculates multiple paths.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute Redistributes information from another routing protocol.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/connected Redistributes information from connected routing protocol.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/connected/metric Metric for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/connected/route-map Route map reference.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/connected/metric-type IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf Specifies the OSPF protocol.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/match Redistribution of OSPF routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/match/internal Internal routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/match/external1 External type 1 routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/match/external2 External type 2 routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/metric Metric for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/route-map Route map reference.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/metric-type IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/static Static routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/static/metric Metric for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/static/route-map Route map reference.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/static/metric-type IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/bgp BGP routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/bgp/metric Metric for redistributed routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/bgp/route-map Route map reference.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/bgp/metric-type IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis ISIS routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/level-1 Level-1 routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/level-1/into Level-1 routes information.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/level-1/into/level-2 Level-1 routes into Level-2
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/level-2 Level-2 routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/level-2/into Level-2 routes into level-1.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/level-2/into/level-1 Level-2 routes into Level-1
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/level-2/into/level-1/prefix-list Select routes using prefix-list.
<base_URI>/config/running/router/isis/address-family/ipv6 IPv6 address Family.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast IPv6 unicast address Family.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/disable-adjacency-check Disables IPv6 Support consistency check.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/summary-prefix/{summary-prefix-ipv6} Configure Integrated IS-IS address summaries
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/summary-prefix/{summary-prefix-ipv6}/level-2 Configure Integrated IS-IS address summaries for Level-2.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/default-link-metric Default Link Metric.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/default-link-metric/level-1 Default Link Metric for Level-1.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/default-link-metric/level-2 Default Link Metric for Level-2.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/multi-topology Enable/disable ISIS multi-topology extension for this address family.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/multi-topology/transition Accept and generate both ISIS IPv6 and Multi-topology IPv6 TLVs.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/spf-interval/level-1 SPF calculation Timers
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/partial-spf-interval Partial SPF Calculation Timers.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/partial-spf-interval/pspf-max-hold-time Max hold time (msec) between two PSPF calculations. Range is 0-120000. Default is 5000.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/partial-spf-interval/pspf-init-delay Initial delay (msec) between receiving a LSP change to PSPF calculation. Range is 0-120000. Default is 2000.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/partial-spf-interval/pspf-hold-time Hold time (msec) between two PSPF calculations. Range is 0-120000. Default is 5000.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/default-information-originate Control origination of default route.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/default-information-originate/route-map Use route map.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/default-information-originate/default-information-originate-cr Control origination of default route.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/default-metric Metric for route redistribution.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/distance Define an administrative distance.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/maximum-paths Calculate multiple paths.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute Redistribute information from another routing protocol.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/connected Connected.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/connected/metric Metric for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/connected/route-map Route map reference.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/connected/metric-type IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf Open Shortest Path First.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/match Redistribution of OSPF routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/match/internal Internal routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/match/external1 External type 1 routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/match/external2 External type 2 routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/metric Metric for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/route-map Route map reference.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/metric-type IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/static Static routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/static/metric Metric for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/static/route-map Route map reference.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/static/metric-type IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/bgp Bgp routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/bgp/metric Metric for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/bgp/route-map Route map reference.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/bgp/metric-type IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/isis ISIS routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/isis/level-1 Level-1 routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/isis/level-1/into Level-1 routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/isis/level-1/into/level-2 Level-1 routes into Level-2.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/isis/level-2 Level-2 routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/isis/level-2/into Level-2 routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/isis/level-2/into/level-1 Level-2 routes into Level-1.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/isis/level-2/into/level-1/prefix-list Select routes using prefix-list.
POST URIs Payload Description
<base_URI>/config/running/router <isis /> Configures IS-IS Protocol (ISIS).
<base_URI>/config/running/router/isis <net><net-cmd>{net-cmd}</net-cmd></net> Define NSAP address
<base_URI>/config/running/router/isis/fast-flood/ <fast-flood-value> {unit32} < /fast-flood-value > Define number of LSPs to be flooded before SPF Run
<base_URI>/config/running/router/isis <set-overload-bit></set-overload-bit> Configures a device to signal other devices not to use it as an intermediate hop in their shortest path first (SPF) calculations if an IS‘s resources are overloaded and are preventing the IS from properly performing IS-IS routing.
<base_URI>/config/running/router/isis <spf-interval><spf-interval-level>level-1</spf-interval-level><spf-interval-max-hold-time>{unit32}</spf-interval-max-hold-time><spf-interval-initial-delay>{unit32}</spf-interval-initial-delay><spf-interval-hold-time>{unit32}</spf-interval-hold-time></spf-interval> SPF calculation Timers.
<base_URI>/config/running/router/isis <reverse-metric></reverse-metric> Configure IS-IS reverse metric at the router level.
<base_URI>/config/running/router/isis/address-family/ipv4 <unicast /> IPv4 unicast address Family
<base_URI>/config/running/router/isis/address-family/ipv4/unicast <summary-address><summary-ip>{inet:ipv4-address}</summary-ip><summary-ip-mask>{inet:ipv4-address}</summary-ip-mask><Level-1>{enumeration}</Level-1></summary-address> Configures Integrated IS-IS address summaries.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast <ldp-sync></ldp-sync> Enable LDP-SYNC on all eligible ISIS interfaces
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute <connected></connected> Redistributes information from connected routing protocol.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute <ospf></ospf> Specifies the OSPF protocol.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute <static></static> Specifies the source protocol (static) from which routes are being redistributed.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute <bgp></bgp> Specifies the source protocol (BGP) from which routes are being redistributed.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/level-2/into <level-1 /> Redistributes Level 2 routes into Level 1.
<base_URI>/config/running/router/isis/address-family/ipv6 <unicast /> IPv6 unicast address Family
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/ <summary-prefix><summary-prefix-ipv6>{common-def:ipv6-address-prefix}</summary-prefix-ipv6><Level-1>true</Level-1></summary-prefix> Configure Integrated IS-IS address summaries
<base_URI>/config/running/router/isis/address-family/ipv6/unicast <multi-topology></multi-topology> Enables ISIS multi-topology extension for the address family
<base_URI>/config/running/router/isis/address-family/ipv6/unicast <spf-interval><spf6-interval-level>{enumeration}</spf6-interval-level><spf6-interval-max-hold-time>{unit32}</spf6-interval-max-hold-time><spf6-interval-initial-delay>{unit32}</spf6-interval-initial-delay><spf6-interval-hold-time>{unit32}</spf6-interval-hold-time></spf-interval> SPF calculation Timers
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ <connected></connected> Redistributes information from connected routing protocol.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute <ospf></ospf> Specifies the OSPF protocol.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/static <static></static> Specifies the source protocol (static) from which routes are being redistributed.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ <bgp></bgp> Specifies the source protocol (BGP) from which routes are being redistributed.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/isis/level-2/into/ <level-1></level-1> Redistributes Level 2 routes into Level 1.
PUT URIs Payload Description
<base_URI>/config/running/router/isis/auth-check/level-1/disable <disable>{enumeration}</disable> Disables authentication of incoming PDUs for Level-1 LSPs, CSNP, and PSNP.
<base_URI>/config/running/router/isis/auth-check/level-2/disable <disable>{enumeration}</disable> Disables the authentication of incoming PDUs for Level-2 LSPs, CSNP, and PSNP.
<base_URI>/config/running/router/isis/auth-mode/md5/level-1 <level-1>{enumeration}</level-1> Authentication mode for Level-1 LSPs, CSNP, and PSNP.
<base_URI>/config/running/router/isis/auth-mode/md5/level-2 <level-2>{enumeration}</level-2> Authentication mode for Level-2 LSPs, CSNP, and PSNP.
<base_URI>/config/running/router/isis/auth-key/level-1 <level-1>string<level-1> Auth-key for Level-1 ISIS Router
<base_URI>/config/running/router/isis/auth-key/level-2 <level-2>string<level-2> Auth-key for Level-2 ISIS Router
<base_URI>/config/running/router/isis/csnp-interval <csnp-interval>{unit32}</csnp-interval> Rate of transmission of CSNPs
<base_URI>/config/running/router/isis/disable-incremental-spf-opt <disable-incremental-spf-opt>{enumeration}</disable-incremental-spf-opt> Disables Incremental SPF Optimizations; resorts to Full SPF
<base_URI>/config/running/router/isis/disable-inc-stct-spf-opt <disable-inc-stct-spf-opt>{enumeration}</disable-inc-stct-spf-opt> Disables Incremental Shortcut SPF Optimizations; resorts to Full SPF
<base_URI>/config/running/router/isis/disable-partial-spf-opt <disable-partial-spf-opt>{enumeration}</disable-partial-spf-opt> Disables Partial SPF Optimizations; resorts to Full SPF
<base_URI>/config/running/router/isis/fast-flood/fast-flood-value <fast-flood-value>{unit32}< /fast-flood-value > Defines the number of LSPs to be flooded before SPF Run
<base_URI>/config/running/router/isis/graceful-restart/helper-disable <helper-disable>{enumeration}</helper-disable> Disables Helper Mode
<base_URI>/config/running/router/isis/hostname/disable <disable>{enumeration}</disable> Disables integrated IS-IS dynamic hostname
<base_URI>/config/running/router/isis/is-type <is-type>level-1</is-type> Define inter-area/intra area operation mode
<base_URI>/config/running/router/isis/log/adjacency <adjacency>{enumeration}</adjacency> Logging Adjacency Changes
<base_URI>/config/running/router/isis/log/invalid-lsp-packets <invalid-lsp-packets>{enumeration}</invalid-lsp-packets> Logging Invalid LSP Packets
<base_URI>/config/running/router/isis/lsp-gen-interval <lsp-gen-interval >{unit32}< /lsp-gen-interval > Minimum interval between regenerating same LSP
<base_URI>/config/running/router/isis/lsp-interval <lsp-interval>{unit32}</lsp-interval> Rate of transmission of LSPs
<base_URI>/config/running/router/isis/lsp-refresh-interval <lsp-refresh-interval>{unit32}</lsp-refresh-interval> LSP refresh interval
<base_URI>/config/running/router/isis/max-lsp-lifetime <max-lsp-lifetime>{unit32}</max-lsp-lifetime> Maximum LSP lifetime
<base_URI>/config/running/router/isis/nonstop-routing <nonstop-routing>{enumeration}</nonstop-routing> Enables the ISIS nonstop routing capability
<base_URI>/config/running/router/isis/partial-spf-interval/pspf-max-hold-time <pspf-max-hold-time>{unit32}</pspf-max-hold-time> Max hold time (msec) between two PSPF calculations. Range is 0-120000. Default is 5000.
<base_URI>/config/running/router/isis/partial-spf-interval/pspf-init-delay <pspf-init-delay>{unit32}</pspf-init-delay> Initial delay (msec) between receiving a LSP change to PSPF calculation. Range is 0-120000. Default is 2000.
<base_URI>/config/running/router/isis/partial-spf-interval/pspf-hold-time <pspf-hold-time>{unit32}</pspf-hold-time> Hold time (msec) between two PSPF calculations. 0-120000. Default is 5000
<base_URI>/config/running/router/isis/retransmit-interval <retransmit-interval>{unit32}</retransmit-interval> Time between retransmission of LSP.
<base_URI>/config/running/router/isis/set-debug/nsr <nsr>{enumeration}</nsr> Sets nsr debug.
<base_URI>/config/running/router/isis/set-overload-bit/on-startup/on-startup-overloadtime <on-startup-overloadtime>{unit32}</on-startup-overloadtime> Time in seconds to stay in overloaded state on reboot
<base_URI>/config/running/router/isis/reverse-metric/tlv-type <tlv-type>{unit32}</tlv-type> Configure reverse metric TLV type.
<base_URI>/config/running/router/isis/reverse-metric/rev-metric-val <rev-metric-val>{unit32}</rev-metric-val> Configure IS-IS reverse metric value.
<base_URI>/config/running/router/isis/reverse-metric/whole-lan <whole-lan>{enumeration}</whole-lan> Change metric for whole LAN.
<base_URI>/config/running/router/isis/reverse-metric/te-def-metric <te-def-metric>{enumeration}</te-def-metric> Update TE default metric sub-tlv
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/metric-style/wide/level-1 <level-1>{enumeration}</level-1> Level-1 only.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/metric-style/wide/level-2 <level-2>{enumeration}</level-2> Level-2 only.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/summary-address/{summary-ip},{summary-ip-mask}/Level-1 <Level-1>{enumeration}</Level-1> Configure Integrated IS-IS address summaries.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/ldp-sync/hold-down <hold-down>{unit32}</hold-down> Length (in seconds) of hold-down timer. Range is 1-65535.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-link-metric/level-1 <level-1>{unit32}</level-1> Default Link Metric for Level-1.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-link-metric/level-2 <level-2>{unit32}</level-2> Default Link Metric for Level-2.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-information-originate/default-information-originate-cr <default-information-originate-cr>{enumeration}</default-information-originate-cr> Controls origination of default route.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-information-originate/route-map <route-map>{name}</routemap> Uses route map.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-metric <default-metric>{unit32}</default-metric> Metric for route redistribution.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/distance <distance>{unit32}</distance> Defines an administrative distance.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/maximum-paths <maximum-paths>{unit32}</maximum-paths> Calculates multiple paths.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/connected/metric <metric>{unit32}</metric> Metric for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/connected/metric-type <metric-type>internal</metric-type> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/connected/route-map <route-map>{string}</route-map> Route map reference.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/connected/level-1 <level-1>{enumeration}</level-1> IS-IS Level-1 routes only
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/connected/level-2 <level-2>{enumeration}</level-2> IS-IS Level-2 routes only
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/connected/level-1-2 <level-1-2>{enumeration}</level-1-2> IS-IS Level-1-2 routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/match/internal <internal>{enumeration}</internal> Internal routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/match/external1 <external1>{enumeration}</external1> External type 1 routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/match/external2 <external2>{enumeration}</external2> External type 2routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/metric <metric>{unit32}</metric> Metric for redistributed routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/route-map <route-map>route-map-static</route-map> Route map reference
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/metric-type <metric-type>external</metric-type> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/level-1 <level-1>{enumeration}</level-1> IS-IS Level-1 routes only
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/level-2 <level-2>{enumeration}</level-2> IS-IS Level-2 routes only
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/level-1-2 <level-1-2>{enumeration}</level-1-2> IS-IS Level-1-2 routes only
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/static/metric <metric>{unit32}</metric> Metric for redistributed routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/static/metric-type <metric-type>external</metric-type> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/static/route-map <route-map>{string}</route-map> Route map reference
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/static/level-1 <level-1>{enumeration}</level-1> IS-IS Level-1 routes only
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/static/level-2 <level-2>{enumeration}</level-2> IS-IS Level-2 routes only
<base_URI>config/running/router/isis/address-family/ipv4/unicast/redistribute/static/level-1-2 <level-1-2>{enumeration}</level-1-2> IS-IS Level-1-2 routes only
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/bgp/metric <metric>{unit32}</metric> Metric for redistributed routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/bgp/metric-type <metric-type>external</metric-type> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/bgp/route-map <route-map>{string}</route-map> Route map reference
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/bgp/level-1 <level-1>{enumeration}</level-1> IS-IS Level-1 routes only
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/bgp/level-2 <level-2>{enumeration}</level-2> IS-IS Level-2 routes only
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/bgp/level-1-2 <level-1-2>{enumeration}</level-1-2> IS-IS Level-1-2 routes only
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/level-2/into/level-1/prefix-list <prefix-list>isis-route-l2tol1</prefix-list> Selects routes using prefix-list
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/disable-adjacency-check <disable-adjacency-check >{enumeration}< /disable-adjacency-check > Disables IPv6 Support consistency check
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/summary-prefix/{summary-prefix-ipv6}/Level-2 <Level-2>{enumeration}</Level-2> Configures Integrated IS-IS address summaries for Level-2.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/default-link-metric/level-1 <level-1>{unit32}</level-1> IS-IS Level-1 routes only
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/default-link-metric/level-2 <level-2>{unit32}</level-2> IS-IS Level-2 routes only
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/multi-topology/transition <transition>{enumeration}</transition> Accept and generate both ISIS IPv6 and Multi-topology IPv6 TLVs
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/partial-spf-interval/pspf-max-hold-time <pspf-max-hold-time>{unit32}</pspf-max-hold-time> Maximum hold time (msec) between two PSPF calculations
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/partial-spf-interval/pspf-init-delay <pspf-init-delay>{unit32}</pspf-init-delay> Initial delay (msec) between receiving a LSP change to PSPF calculation
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/partial-spf-interval/pspf-hold-time <pspf-hold-time>{unit32}</pspf-hold-time> Hold time (msec) between two PSPF calculations
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/default-information-originate/default-information-originate-cr <default-information-originate-cr>{enumeration}</default-information-originate-cr> Controls origination of default route.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/default-information-originate/route-map <route-map>route-map-static</route-map> Uses route map.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/default-metric <default-metric>{unit32}</default-metric> Metric for route redistribution.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/distance <distance>{unit32}</distance> Defines an administrative distance.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/maximum-paths <maximum-paths>{unit32}</maximum-paths> Calculates multiple paths.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/connected/metric <metric>{unit32}</metric> Metric for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/connected/route-map <route-map>route-map-static</route-map> Route map reference.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/connected/metric-type <metric-type>external</metric-type> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/connected/level-1 <level-1>{enumeration}</level-1> IS-IS Level-1 routes only
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/connected/level-2 <level-2>{enumeration}</level-2> IS-IS Level-2 routes only
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/connected/level-1-2 <level-1-2>{enumeration}</level-1-2> IS-IS Level-1-2 routes
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/match/internal <internal>{enumeration}</internal> Internal routes
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/match/external1 <external1>{enumeration}</external1> External type 1 routes
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/match/external2 <external2>{enumeration}</external2> External type 2routes
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/metric <metric>{unit32}</metric> Metric for redistributed routes
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/route-map <route-map>ipv6-restapi</route-map> Route map reference
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/metric-type <ospf><metric-type>external</metric-type></ospf> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/level-1 <level-1>{enumeration}</level-1> IS-IS Level-1 routes only
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/level-2 <level-2>{enumeration}</level-2> IS-IS Level-2 routes only
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/level-1-2 <level-1-2>{enumeration}</level-1-2> IS-IS Level-1-2 routes only
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/static/metric <metric>{unit32}</metric> Metric for redistributed routes
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/static/route-map <route-map>route-map-static</route-map> Route map reference
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/static/metric-type <metric-type>external</metric-type> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/static/level-1 <level-1>{enumeration}</level-1> IS-IS Level-1 routes only
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/static/level-2 <level-2>{enumeration}</level-2> IS-IS Level-2 routes only
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/static/level-1-2 <level-1-2>{enumeration}</level-1-2> IS-IS Level-1-2 routes only
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/bgp/metric <metric>{unit32}</metric> Metric for redistributed routes
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/bgp/route-map <route-map>route-map-static</route-map> Route map reference
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/bgp/metric-type <metric-type>external</metric-type> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/bgp/level-1 <level-1>{enumeration}</level-1> IS-IS Level-1 routes only
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/bgp/level-2 <level-2>{enumeration}</level-2> IS-IS Level-2 routes only
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/bgp/level-1-2 <level-1-2>{enumeration}</level-1-2> IS-IS Level-1-2 routes only
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/isis/level-2/into/level-1/prefix-list <prefix-list>isiv6-route-l2tol1</prefix-list> Selects routes using prefix-list.
PATCH URIs Payload Description
<base_URI>/config/running/router/isis/auth-check/level-1 <level-1><disable>{enumeration}</disable></level-1> Disables authentication of incoming PDUs for Level-1 LSPs, CSNP, and PSNP.
<base_URI>/config/running/router/isis/auth-check/level-2 <level-2><disable>{enumeration}</disable></level-2> Disables the authentication of incoming PDUs for Level-2 LSPs, CSNP, and PSNP.
<base_URI>/config/running/router/isis/auth-mode/md5 <md5><level-1>{enumeration}</level-1></md5> Authentication mode for Level-1 LSPs, CSNP, and PSNP.
<base_URI>/config/running/router/isis/auth-mode/md5 <md5><level-2>{enumeration}</level-2></md5> Authentication mode for Level-2 LSPs, CSNP, and PSNP.
<base_URI>/config/running/router/isis/auth-key <auth-key><level-1>{string}</level-1></auth-key> Auth-key for Level-1 ISIS Router
<base_URI>/config/running/router/isis/auth-key <auth-key><level-2>{string}</level-2></auth-key> Auth-key for Level-2 ISIS Router
<base_URI>/config/running/router/isis <isis><csnp-interval>{unit32}</csnp-interval></isis> Rate of transmission of CSNPs
<base_URI>/config/running/router/isis <isis><disable-inc-stct-spf-opt>{renumeration}</disable-inc-stct-spf-opt></isis> Disables Incremental Shortcut SPF Optimizations; resorts to Full SPF
<base_URI>/config/running/router/isis <isis><disable-incremental-spf-opt>{enumeration}</disable-incremental-spf-opt></isis> Disables Incremental SPF Optimizations; resorts to Full SPF
<base_URI>/config/running/router/isis <isis><disable-partial-spf-opt>{enumeration}</disable-partial-spf-opt></isis> Disables Partial SPF Optimizations; resorts to Full SPF
<base_URI>/config/running/router/isis/fast-flood <fast-flood><fast-flood-value>{unit32}< /fast-flood-value > </fast-flood> Defines the number of LSPs to be flooded before SPF Run
<base_URI>/config/running/router/isis/graceful-restart <graceful-restart><helper-disable>{enumeration}</helper-disable></graceful-restart> Disables Helper Mode
<base_URI>/config/running/router/isis/hostname <hostname><disable>{enumeration}</disable></hostname> Disables integrated IS-IS dynamic hostname
<base_URI>/config/running/router/isis <isis><is-type>level-1</is-type></isis> Define inter-area/intra area operation mode
<base_URI>/config/running/router/isis/log/ <log><adjacency>{enumeration}</adjacency></log> Logging Adjacency Changes
<base_URI>/config/running/router/isis/log/ <log><invalid-lsp-packets>{enumeration}</invalid-lsp-packets></log> Logging Invalid LSP Packets
<base_URI>/config/running/router/isis <isis><lsp-gen-interval>{unit32}</lsp-gen-interval></isis> Minimum interval between regenerating same LSP
<base_URI>/config/running/router/isis <isis><lsp-interval>{unit32}</lsp-interval></isis> Rate of transmission of LSPs
<base_URI>/config/running/router/isis <isis><lsp-refresh-interval>{unit32}</lsp-refresh-interval></isis> LSP refresh interval
<base_URI>/config/running/router/isis <isis><max-lsp-lifetime>{unit32}</max-lsp-lifetime></isis> Maximum LSP lifetime
<base_URI>/config/running/router/isis <isis><nonstop-routing>{enumeration}</nonstop-routing></isis> Enables the ISIS nonstop routing capability
<base_URI>/config/running/router/isis/partial-spf-interval <partial-spf-interval><pspf-max-hold-time>{unit32}</pspf-max-hold-time></partial-spf-interval> Max hold time (msec) between two PSPF calculations. Range is 0-120000. Default is 5000.
<base_URI>/config/running/router/isis/partial-spf-interval <partial-spf-interval><pspf-init-delay>{unit32}</pspf-init-delay></partial-spf-interval> Initial delay (msec) between receiving a LSP change to PSPF calculation. Range is 0-120000. Default is 2000.
<base_URI>/config/running/router/isis/partial-spf-interval <partial-spf-interval><pspf-hold-time>{unit32}</pspf-hold-time></partial-spf-interval> Hold time (msec) between two PSPF calculations. 0-120000. Default is 5000
<base_URI>/config/running/router/isis <isis><retransmit-interval>{unit32}</retransmit-interval></isis> Time between retransmission of LSP.
<base_URI>/config/running/router/isis/set-debug <set-debug><nsr>{enumeration}</nsr></set-debug> Sets nsr debug.
<base_URI>/config/running/router/isis/spf-interval/level-1 <spf-interval><spf-interval-max-hold-time>{unit32}</spf-interval-max-hold-time><spf-interval-initial-delay>{unit32}</spf-interval-initial-delay><spf-interval-hold-time>{unit32}</spf-interval-hold-time></spf-interval> Time in seconds to stay in overloaded state on reboot
<base_URI>/config/running/router/isis/reverse-metric "<reverse-metric><tlv-type>{unit32}</tlv-type></reverse-metric> Configure reverse metric TLV type.
<base_URI>/config/running/router/isis/reverse-metric <reverse-metric><rev-metric-val><reverse-metric><te-def-metric>true</te-def-metric></reverse-metric></rev-metric-val></reverse-metric> Configure IS-IS reverse metric value.
<base_URI>/config/running/router/isis/reverse-metric <reverse-metric><whole-lan>{enumeration}</whole-lan></reverse-metric> Change metric for whole LAN.
<base_URI>/config/running/router/isis/reverse-metric/ <reverse-metric><te-def-metric>{enumeration}</te-def-metric></reverse-metric> Update TE default metric sub-tlv
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/metric-style <metric-style><wide><level-1>{enumeration}</level-1></wide></metric-style> Level-1 only.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/metric-style/ <metric-style><wide><level-2>{enumeration}</level-2></wide></metric-style> Level-2 only.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/summary-address/{summary-ip},{summary-ip-mask} <summary-address><Level-1>{enumeration}</Level-1></summary-address> Configure Integrated IS-IS address summaries.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/ldp-sync/ <ldp-sync><hold-down>{unit32}</hold-down></ldp-sync> Length (in seconds) of hold-down timer. Range is 1-65535.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-link-metric <default-link-metric><level-1>{unit32}</level-1></default-link-metric> Default Link Metric for Level-1.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-link-metric <default-link-metric><level-2>{unit32}</level-2></default-link-metric> Default Link Metric for Level-2.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-information-originate/ <default-information-originate><default-information-originate-cr>{enumeration}</default-information-originate-cr></default-information-originate> Controls origination of default route.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-information-originate/ <default-information-originate><route-map>restapi</routemap></default-information-originate> Uses route map.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast <unicast><default-metric>{unit32}</default-metric></unicast> Metric for route redistribution.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast <unicast><distance>{unit32}</distance></unicast> Defines an administrative distance.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast <unicast><maximum-paths>{unit32}</maximum-paths></unicast> Calculates multiple paths.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/connected/ <connected><metric>{unit32}</metric></connected> Metric for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/connected/ <connected><metric-type>internal</metric-type></connected> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/connected/ <connected><route-map>restapi</route-map></connected> Route map reference.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/match <match><internal>{enumeration}</internal></match> Internal routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/match <match><external1>{enumeration}</external1></match> External type 1 routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/match <match><external2>{enumeration}</external2></match> External type 2routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/ <ospf><metric>{unit32}</metric></ospf> Metric for redistributed routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/ <ospf><route-map>restapi</route-map></ospf> Route map reference
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/ <ospf><metric-type>external</metric-type></ospf> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/static/ <static><metric>{unit32}</metric></static> Metric for redistributed routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/static/ <static><metric-type>external</metric-type></static> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/static/ <static><route-map>restapi</route-map></static> Route map reference
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/bgp/ <bgp><metric>{unit32}</metric></bgp> Metric for redistributed routes
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/bgp/ <bgp><metric-type>external</metric-type></bgp> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/bgp/ <route-map>{string}</route-map> Route map reference
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/level-2/into/level-1 <level-1><prefix-list>hello</prefix-list></level-1> Selects routes using prefix-list
<base_URI>/config/running/router/isis/address-family/ipv6/unicast <unicast><disable-adjacency-check>true</disable-adjacency-check></unicast> Disables IPv6 Support consistency check
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/summary-prefix/{summary-prefix-ipv6} <summary-prefix><Level-1>{enumeration}</Level-1></summary-prefix> Configures Integrated IS-IS address summaries for Level-1.
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-link-metric <default-link-metric><level-1>{unit32}</level-1></default-link-metric> IS-IS Level-1 routes only
<base_URI>/config/running/router/isis/address-family/ipv4/unicast/default-link-metric <default-link-metric><level-2>{unit32}</level-2></default-link-metric> IS-IS Level-2 routes only
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/multi-topology <multi-topology><transition>{enumeration}</transition></multi-topology> Accept and generate both ISIS IPv6 and Multi-topology IPv6 TLVs
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/spf-interval/level-2 <spf-interval><spf6-interval-max-hold-time>{unit32}</spf6-interval-max-hold-time><spf6-interval-initial-delay>{unit32}</spf6-interval-initial-delay><spf6-interval-hold-time>{unit32}</spf6-interval-hold-time></spf-interval> SPF calculation Timers.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/partial-spf-interval <partial-spf-interval><pspf-max-hold-time>{unit32}</pspf-max-hold-time></partial-spf-interval> Maximum hold time (msec) between two PSPF calculations
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/partial-spf-interval <partial-spf-interval><pspf-init-delay>{unit32}</pspf-init-delay></partial-spf-interval> Initial delay (msec) between receiving a LSP change to PSPF calculation
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/partial-spf-interval <partial-spf-interval><pspf-hold-time>{unit32}</pspf-hold-time></partial-spf-interval> Hold time (msec) between two PSPF calculations
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/default-information-originate <default-information-originate><default-information-originate-cr>{enumeration}</default-information-originate-cr></default-information-originate> Controls origination of default route.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/default-information-originate <default-information-originate><route-map>ipv6-restapi</route-map></default-information-originate> Uses route map.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast <unicast><default-metric>{unit32}</default-metric></unicast> Metric for route redistribution.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast <unicast><distance>{unit32}</distance></unicast> Defines an administrative distance.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast <unicast><maximum-paths>{unit32}</maximum-paths></unicast> Calculates multiple paths.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/connected <connected><metric>{unit32}</metric></connected> Metric for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/connected <connected><route-map>ipv6-restapi</route-map></connected> Route map reference.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/connected <connected><metric-type>external</metric-type></connected> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/match <match><internal>{enumeration}</internal></match> Internal routes
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/match <match><external1>{enumeration}</external1></match> External type 1 routes
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/match <match><external2>{enumeration}</external2></match> External type 2routes
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/ <opsf><metric>{unit32}</metric></ospf> Metric for redistributed routes
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/ <ospf><route-map>ipv6-restapi</route-map></ospf> Route map reference
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf <ospf><metric-type>external</metric-type></ospf> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/static/ <static><metric>{unit32}</metric></static> Metric for redistributed routes
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/static <route-map>route-map-static</route-map> Route map reference
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/static/metric-type <static><metric-type>external</metric-type></static> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/bgp <bgp><metric>{unit32}</metric></bgp> Metric for redistributed routes
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/bgp <bgp><route-map>ipv6-restapi</route-map></bgp> Route map reference
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/bgp <bgp><metric-type>external</metric-type></bgp> IS-IS metric type for redistributed routes.
<base_URI>/config/running/router/isis/address-family/ipv6/unicast/redistribute/isis/level-2/into/level-1 <level-1><prefix-list>{string}</prefix-list></level-1> Selects routes using prefix-list.
DELETE URIs
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/router/isis
None
isis xmlns="urn:brocade.com:mgmt:brocade-isis" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/router/isis">
  <net y:self="/rest/config/running/router/isis/net/01.1111.1111.1111.00">
    <net-cmd>01.1111.1111.1111.00</net-cmd>
  </net>
  <auth-check y:self="/rest/config/running/router/isis/auth-check">
    <level-1 y:self="/rest/config/running/router/isis/auth-check/level-1">
    </level-1>
    <level-2 y:self="/rest/config/running/router/isis/auth-check/level-2">
    </level-2>
  </auth-check>
  <auth-mode y:self="/rest/config/running/router/isis/auth-mode">
    <md5 y:self="/rest/config/running/router/isis/auth-mode/md5">
    </md5>
  </auth-mode>
  <auth-key y:self="/rest/config/running/router/isis/auth-key">
  </auth-key>
  <fast-flood y:self="/rest/config/running/router/isis/fast-flood">
    <fast-flood-value>10</fast-flood-value>
  </fast-flood>
  <graceful-restart y:self="/rest/config/running/router/isis/graceful-restart">
  </graceful-restart>
  <hello y:self="/rest/config/running/router/isis/hello">
    <padding y:self="/rest/config/running/router/isis/hello/padding">
      <point-to-point y:self="/rest/config/running/router/isis/hello/padding/point-to-point">
      </point-to-point>
    </padding>
  </hello>
  <hostname y:self="/rest/config/running/router/isis/hostname">
  </hostname>
  <is-type>level-2</is-type>
  <log y:self="/rest/config/running/router/isis/log">
    <adjacency>true</adjacency>
    <invalid-lsp-packets>true</invalid-lsp-packets>
  </log>
  <nonstop-routing>true</nonstop-routing>
  <partial-spf-interval y:self="/rest/config/running/router/isis/partial-spf-interval">
  <set-debug y:self="/rest/config/running/router/isis/set-debug">
    <nsr>true</nsr>
  </set-debug>
  <address-family y:self="/rest/config/running/router/isis/address-family">
    <ipv4 y:self="/rest/config/running/router/isis/address-family/ipv4">
      <unicast y:self="/rest/config/running/router/isis/address-family/ipv4/unicast">
        <metric-style y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/metric-style">
          <wide y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/metric-style/wide">
            <level-1>true</level-1>
            <level-2>true</level-2>
          </wide>
        </metric-style>
        <default-link-metric y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/default-link-metric">
        <default-information-originate y:self="/rest/config/running/router/isis/address-family/ipv4/
unicast/default-information-originate">
          <default-information-originate-cr>true</default-information-originate-cr>
        <default-metric>5000</default-metric>
        <distance>110</distance>
        <redistribute y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/redistribute">
          <connected y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/redistribute/connected">
            <metric>3000</metric>
            <route-map>rm-connected</route-map>
            <level-1-2>true</level-1-2>
          </connected>
          <ospf y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf">
            <match y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/redistribute/ospf/match">
              <internal>true</internal>
            </match>
            <metric>2000</metric>
            <route-map>rm-ospf</route-map>
          </ospf>
          <static y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/redistribute/static">
            <metric>4000</metric>
            <route-map>rm-static</route-map>
          </static>
          <bgp y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/redistribute/bgp">
            <metric>1000</metric>
            <route-map>rm-bgp</route-map>
          </bgp>
          <isis y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis">
            <level-1 y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/level-1">
              <into y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/level-1/into">
                <level-2 y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/
level-1/into/level-2">
                </level-2>
              </into>
            </level-1>
            <level-2 y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/level-2">
              <into y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/level-2/into">
                <level-1 y:self="/rest/config/running/router/isis/address-family/ipv4/unicast/redistribute/isis/level-2/
into/level-1">
                </level-1>
              </into>
            </level-2>
          </isis>
        </redistribute>
      </unicast>
    </ipv4>
    <ipv6 y:self="/rest/config/running/router/isis/address-family/ipv6">
      <unicast y:self="/rest/config/running/router/isis/address-family/ipv6/unicast">
        <summary-prefix y:self="/rest/config/running/router/isis/address-family/ipv6/unicast/summary-prefix/
%22100:100:100::0/64%22">
          <summary-prefix-ipv6>100:100:100::0/64</summary-prefix-ipv6>
        </summary-prefix>
%2280:80:80::0/64%22">
          <summary-prefix-ipv6>80:80:80::0/64</summary-prefix-ipv6>
        </summary-prefix>
%2290:90:90::0/64%22">
          <summary-prefix-ipv6>90:90:90::0/64</summary-prefix-ipv6>
        </summary-prefix>
        <default-link-metric y:self="/rest/config/running/router/isis/address-family/ipv6/unicast/default-link-metric">
          <level-1>500</level-1>
          <level-2>1100</level-2>
        <partial-spf-interval y:self="/rest/config/running/router/isis/address-family/ipv6/unicast/partial-spf-interval">
        <default-information-originate y:self="/rest/config/running/router/isis/address-family/ipv6/
        <default-metric>60535</default-metric>
        <distance>100</distance>
        <maximum-paths>64</maximum-paths>
        <redistribute y:self="/rest/config/running/router/isis/address-family/ipv6/unicast/redistribute">
          <connected y:self="/rest/config/running/router/isis/address-family/ipv6/unicast/redistribute/connected">
            <metric>3500</metric>
            <route-map>rm-connectedv6</route-map>
          </connected>
          <ospf y:self="/rest/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf">
            <match y:self="/rest/config/running/router/isis/address-family/ipv6/unicast/redistribute/ospf/match">
            </match>
            <metric>2500</metric>
            <route-map>rm-ospfv6</route-map>
          </ospf>
          <static y:self="/rest/config/running/router/isis/address-family/ipv6/unicast/redistribute/static">
            <metric>4500</metric>
            <route-map>rm-staticv6</route-map>
          </static>
          <bgp y:self="/rest/config/running/router/isis/address-family/ipv6/unicast/redistribute/bgp">
            <metric>1500</metric>
            <route-map>rm-bgpv6</route-map>
          </bgp>
          <isis y:self="/rest/config/running/router/isis/address-family/ipv6/unicast/redistribute/isis">
            <level-1 y:self="/rest/config/running/router/isis/address-family/ipv6/unicast/redistribute/isis/
level-1">
              <into y:self="/rest/config/running/router/isis/address-family/ipv6/unicast/redistribute/isis/
level-1/into">
                <level-2 y:self="/rest/config/running/router/isis/address-family/ipv6/unicast/redistribute/
isis/level-1/into/level-2">
                </level-2>
              </into>
            </level-1>
            <level-2 y:self="/rest/config/running/router/isis/address-family/ipv6/unicast/redistribute/isis/
level-2">
level-2/into">
level-2/into/level-1">
                </level-1>
              </into>
            </level-2>
          </isis>
        </redistribute>
      </unicast>
    </ipv6>
  </address-family>
</isis>
URI
The following is an example of the POST operation to configure an IS-IS network entity title (NET) for the routing process.
<net><net-cmd>01.1111.1111.1111.00</net-cmd></net>
None
URI
The following is an example of the DELETE operation to remove IS-IS configuration.
None
None
