Configures, modifies, or retrieves interface mail settings.
| URI | Description |
| <base_URI>/config/running/system-monitor-mail | Configures the FRU email alerts. |
| <base_URI>/config/running/system-monitor-mail/interface | Configures email alerts for the interface. |
| POST URI | Payload | Description |
| /rest/config/running/system-monitor-mail/interface | <email-list><email>(string)</email></email-list> | Configures email address for interface. |
| PUT URI | Payload | Description |
| /rest/config/running/system-monitor-mail/interface/enable | <enable>true</enable> | Modifies email settings for interface. |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/system-monitor-mail/interface
None
<interface y:self="/rest/config/running/system-monitor-mail/interface">
<email-list y:self="/rest/config/running/system-monitor-mail/interface/email-list/abc1@brocade.com">
<email>abc1@brocade.com</email>
</email-list>
</interface>
