Configures, modifies, or retrieves Interface Link-OAM configuration.
| URI | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-oam | Configures, modifies, or retrieves Interface Link-OAM configuration. Valid interface type: Ethernet. |
| GET URIs | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-oam | Displays the interface-level Loop-Detection Interface Link-OAM configuration. Valid interface type: Ethernet. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-oam/enable | <enable>{enumeration}</enable> | Enables Link-OAM. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-oam/allow-loopback | <allow-loopback>{enumeration}</allow-loopback> | Enables / Disables loopback. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-oam/dying-gasp/action | <action>{action-type}</action> | Sets action that will happen in a Dying Gasp event (Receiver going down). Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-oam/link-fault/action | <action>{action-type}</action> | Sets action that will happen in a Link Fault event(Receiver losing signal). Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-oam/critical-event/action | <action>{action-type}</action> | Sets action that will happen in a Critical Event (malfunction). Valid interface type: Ethernet. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-oam | <link-oam><enable>{enumeration}</enable></link-oam> | Enables / Disables Link-OAM. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-oam | <link-oam><allow-loopback>true</allow-loopback></link-oam> | Enables / Disables loopback. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-oam/remote-failure/dying-gasp | <dying-gasp><action>{action-type}</action></dying-gasp> | Sets action that will happen in a Dying Gasp (Receiver going down). Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-oam/remote-failure/link-fault | <link-fault><action>{action-type}</action></link-fault> | Sets action that will happen in a Link Fault (Receiver losing signal). Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-oam/remote-failure/critical-event | <critical-event><action>{action-type}</action></critical-event> | Sets action that will happen in a Critical Event (malfunction). Valid interface type: Ethernet. |
| DELETE URIs |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-oam/remote-failure |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-oam/dying-gasp |
GET, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
