CFM protocol configuration.
| URI | Description |
| <base_URI>/config/running/protocol/cfm | Configures CFM protocol. |
| GET URIs | Description |
| <base_URI>/config/running/protocol/cfm | Retrieves CFM protocol configuration. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name} | Retrieves maintenance domain details. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name} | Retrieves maintenance association. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name}/ccm-interval | Retrieves CCM interval details. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name}/mip-policy | Retrieves MIP policy details. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name}/mep/{mep-id} | Retrieves maintenance endpoint details. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name}/mep/{mep-id}/tlv-type | Retrieves TLV details. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name}/mep/{mep-id}/remote-mep/{remote-map} | Retrieves remote maintenance endpoint details. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name}/maid-format | Retrieves format for the maintenance association name. Allowed values: long, short. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/protocol | <cfm /> | Configures CFM protocol. |
| <base_URI>/config/running/protocol/cfm | <domain-name><domain-name>{string}</domain-name><level>{unit32}</level></domain-name> | Configures maintenance domain. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name} | <ma-name><ma-name>{string}</ma-name><id>{unit32}</id><vlan>{unit32}</vlan><priority>{unit32}</priority></ma-name> | Configures maintenance association VLAN identifier. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name} | <ma-name><ma-name>{string}</ma-name><id>{uint32}</id><bridge-domain>{uint32}</bridge-domain><priority>{uint32}</priority></ma-name> | Configures a unique L2VPN domain of the maintenance association. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name} | <mep><mep-id>{unit32}</mep-id><mep-down-up>{string}</mep-down-up><vlan>{unit32}</vlan><inner-vlan>{uint32}</inner-vlan><mep-intf-type>{interface-type}</mep-intf-type><mep-intf-name>{interface-name}</mep-intf-name></mep> | Configures Maintenance End Point (MEP). |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name}/mep/{mep-id} | <remote-mep><remote-mep>{unit32}</remote-mep></remote-mep> | Configures the remote Maintenance End Point (MEP). |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name} | <domain-name><level>{unit32}</level></domain-name> | Configures maintenance domain. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name} | <ma-name><id>{unit32}</id><vlan>{unit32}</vlan><priority>{unit32}</priority></ma-name> | Configures maintenance association VLAN. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name} | <ma-name><id>{uint32}</id><bridge-domain>{uint32}</bridge-domain><priority>{uint32}</priority></ma-name> | Configures maintenance association L2VPN domain. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name} | <ma-name><ccm-interval>{enumeration}</ccm-interval></ma-name> | Configures maintenance association CCM interval. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name} | <ma-name><mip-policy>{enumeration}</mip-policy></ma-name> | Configures Maintenance Intermediate Point (MIP). |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name}/mep/{mep-id} | <mep><mep-down-up>{enumeration}</mep-down-up><vlan>{unit32}</vlan><inner-vlan>{uint32}</inner-vlan><mep-intf-type>{interface-type}</mep-intf-type><mep-intf-name>{interface-name}</mep-intf-name></mep> | Configures Maintenance End Point (MEP). |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name}/mep/{mep-id} | <mep><tlv-type>{enumeration}</tlv-type></mep> | Configures Type, Length, Values (TLV) value. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name} | <ma-name><maid-format>{maid-format-type}</maid-format></ma-name> | Configures format for the maintenance association ID. Allowed values: long, short. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name}/ccm-interval | <ccm-interval>{enumeration}</ccm-interval> | Configures the time interval between two successive Continuity Check Messages (CCMs) that are sent by MEPs in the specified Maintenance Association (MA) |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name}/mip-policy | <mip-policy>{enumeration}</mip-policy> | Configures Maintenance Intermediate Point (MIP) policy. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name}/mep/{mep-id}/tlv-type | <tlv-type>{enumeration}</tlv-type> | Configures Type, Length, Values (TLV) value. |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name}/maid-format | <maid-format>{maid-format-type}</maid-format> | Configures format for the maintenance association ID. Allowed values: long, short. |
| DELETE URIs |
| <base_URI>/config/running/protocol/cfm/domain-name/{domain-name}/ma-name/{ma-name}/mep/{mep-id}/remote-mep/{remote-mep-id} |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/protocol/cfm
None
<cfm xmlns="urn:brocade.com:mgmt:brocade-dot1ag" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/protocol/cfm">
<domain-name y:self="/rest/config/running/protocol/cfm/domain-name/test">
<domain-name>test</domain-name>
<level>1</level>
<ma-name y:self="/rest/config/running/protocol/cfm/domain-name/test/ma-name/name">
<ma-name>name</ma-name>
<id>1</id>
<vlan>120</vlan>
<priority>1</priority>
<ccm-interval>1-second</ccm-interval>
<mep y:self="/rest/config/running/protocol/cfm/domain-name/test/ma-name/name/mep/1">
<mep-id>1</mep-id>
<mep-down-up>up</mep-down-up>
<mep-intf-type>ethernet</mep-intf-type>
<mep-intf-name>1/15</mep-intf-name>
</mep>
</ma-name>
</domain-name>
</cfm>
The following example uses the POST option to configure CFM domain.
<domain-name> <domain-name>test</domain-name> <level>5</level> </domain-name>
None
The following example uses the DELETE option to remove CFM configuration.
None
None
