ipv6/router/ospf
Configures, retrieves, and modifies Open Shortest Path First (OSPF) version 3.
Resource URIs
URI Description
<base_URI>/config/running/ipv6/router/ospf/{vrf} Configures Open Shortest Path First (OSPF) version 3.
GET URIs Description
<base_URI>/config/running/ipv6/router/ospf Retrieves Open Shortest Path First (OSPF) version 3 details.
<base_URI>/config/running/ipv6/router/ospf/{vrf} Displays the name of the VRF.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id} Displays OSPF router area address
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/normal Displays the normal area for an area ID.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa Displays an NSSA area.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/nssa-area-metric Displays NSSAs advertised stub route metric.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/default-information-originate Controls distribution of default information.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/default-information-originate/metric Displays the OSPF metric .
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/default-information-originate/metric-type Displays the OSPF metric type.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/no-redistribution Do not send redistributed LSA into nssa area.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/no-summary Do not send summary LSA into nssa area.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/translator-always Sets NSSA translator role.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/translator-interval NSSA translator stability interval (sec). Decimal value, range 10-60 seconds. Default is 40s.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/stub Displays a stub area.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/stub/no-summary Do not send summary LSA into stub area.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/stub/stub-area-metric Display Stub area's advertised route metric.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication Authentication of OSPF messages.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor} Define a virtual link and its parameters.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/hello-interval Displays the time between hello packets that the router sends on an interface. Decimal value, range 1-65535 seconds. Default is 10 seconds.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/dead-interval Decimal value, range 3-65535 seconds. Default is 40 seconds.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/hello-jitter Diaplsys the allowed jitter between hello packets. Decimal value, range 1%-50%. Default is 10%.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/retransmit-interval Displays time between Link State Advertisement(LSA) retransmissions for adjacencies belonging to the interface. Decimal value, range 1-3600 seconds. Default is 5 seconds.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/transmit-delay Displays the estimated time required to send an LSA on the interface.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication Displays the authentication details.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/range/{range-address} Defines or undefines a type-3 address range (ABR only).
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/range/{range-address}/range-effect Advertise this type-3 summarization
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/range/{range-address}/cost Displays area range cost.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/auto-cost Calculate OSPFv3 interface cost according to bandwidth.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/auto-cost/reference-bandwidth Displays Reference-bandwidth in Mbits per second. Range 1 - 4294967.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/database-overflow-interval Displays Poll Interval in Seconds. Range 0 - 86400 seconds. Default is 10.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/default-information-originate Controls distribution of default information.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/default-information-originate/always Always advertise default route.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/default-information-originate/metric Displays OSPF metric. Range 0-65535.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/default-information-originate/metric-type OSPF metric type for default route.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/default-metric Displays Default metric. Range 0-65535.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/default-passive-interface Set OSPF interface passive.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/distance/{route-type} Defines an administrative distance.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/distribute-list Prevent routes from being learnt by OSPFv3.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/distribute-list/route-map Use route-map to control routes learned by OSPFv3.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/distribute-list/route-map/in Inbound Filtering.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/distribute-list/prefix-list Use prefix list to control routes learned by OSPFv3
<base_URI>/config/running/ipv6/router/ospf/{vrf}/distribute-list/prefix-list/in Inbound Filtering.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/external-lsdb-limit External Link State Database Limit. Range 1-250000. Default is 250000.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/graceful-restart Displays graceful restart status.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/graceful-restart/helper Displays the OSPFv3 graceful restart (GR) helper capability status.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/graceful-restart/helper/disable Disables the OSPFv3 GR helper capability.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/graceful-restart/helper/strict-lsa-checking Enables the OSPFv3 GR helper mode with strict link-state advertisement (LSA) checking.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/key-add-remove-interval Display add/remove interval in seconds.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/key-rollover-interval Display new key rollover interval in seconds. Range 0-14400. Default is 300.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log Enables logging OSPF activities.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log/adjacency Enables logging adjacency changes.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log/adjacency/dr-only Enables logging adjacency changes for Designated Router interfaces only.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log/all Enables logging everything.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log/bad-packet Enables logging Bad packets.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log/bad-packet/checksum Enables logging bad checksum packets.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log/database Enables logging LSA activity.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log/retransmit Enables logging retransmit activity.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/metric-type OSPF metric type for redistributed routes.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute Enables logging route redistribution.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/connected Displays Connected routes.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/connected/route-map Displays Route map reference.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/connected/metric Displays OSPF metric.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/connected/metric-type Displays OSPF Metric type.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/static Displays Static routes.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/static/route-map Displays Route map reference.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/static/metric Displays OSPF metric.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/static/metric-type Displays OSPF Metric type.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/isis Displays ISIS routes.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/isis/route-map Displays Route map reference.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/isis/metric Displays ISIS metric.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/isis/metric-type Displays ISIS Metric type.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/bgp Displays BGP Routes.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/bgp/route-map Displays Route map reference.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/bgp/metric Displays OSPF metric.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/bgp/metric-type Displays OSPF Metric type.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/ospf Displays OSPF routes.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/ospf/route-map Displays Route map reference.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/ospf/metric Displays OSPF metric.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/ospf/metric-type Displays OSPF Metric type.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/summary-address/{summary-address-value} Displays IP address summaries.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/timers Adjusts routing timers.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/timers/lsa-group-pacing Interval between group of LSA being refreshed or maxaged. Range 10-1800. Default is 240.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/timers/spf Displays OSPF SPF timers.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/timers/spf/spf-hold-time Displays hold time (0-65535 sec) between consecutive SPF calculations.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/nonstop-routing Returns true if nonstop-routing capability is enabled.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/maximum-paths Displays maximum paths. Range 1-64. Default is 8.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric Stub Router Advertisement
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa The maximum metric advertisement in Router LSAs.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/all-lsas Replaces Metric in all External and Summary LSAs with default max metric value.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/external-lsa Replaces Metric in External LSA with max metric value.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/external-lsa/external-lsa-value Indicates the metric of all external type 5 and type 7 LSA's
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/summary-lsa Replaces Metric in Summary LSA with max metric value.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/summary-lsa/summary-lsa-value Displays the metric of all summary type 3 and type 4 LSAs.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/include-stub Configure include-stub for max-metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/on-startup Apply this on OSPF startup.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/on-startup/on-startup-time Displays the time to advertise maximum metric. Range 5 - 86400 seconds.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/on-startup/wait-for-bgp Advertise maximum metric until BGP has converged (or 600 seconds)
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf Open Shortest Path First (OSPF). Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/area Displays OSPF areas. Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/active Displays Active information. Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/passive Displays Passive information. Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/cost Displays cost. Range 1-65535. Default is 1. Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/instance Displays Instance ID. Range 0-255. Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/mtu-ignore Disables OSPF MTU mismatch detection. Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/network Broadcast interface mode. Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/priority Displays Interface priority. Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/suppress-linklsa Suppress link LSA advertisements. Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/authentication Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/authentication/ipsec Displays ipsec authentication for the interface. Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/authentication/ipsec/key-add-remove-interval Displays Key add/remove interval in seconds. Range 0-14400. Default is 300. Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/hello-interval Displays hello interval. Range 1-65535 seconds. Default is 10 seconds. Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/dead-interval Displays Dead interval. Range 3-65535 seconds. Default is 40 seconds. Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface{interface-type}/{interface-name}/ipv6/ospf/hello-jitter Displays Hello Jitter. Range 1%-50%. Default is 10%. Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/retransmit-interval Displays Retransmit interval. Range 1-3600 seconds. Default is 5 seconds. Interface types are Ethernet, Ve, and Loopback.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/transmit-delay Displays Transmit Delay. Range 0-3600 seconds. Default is 1 second. Interface types are Ethernet, Ve, and Loopback.
POST URIs Payload Description
<base_URI>/config/running/ipv6/router <ospf><vrf>{common-def:vrf-name}</vrf></ospf> Configures OSPF instance for the VRF.
<base_URI>/config/running/ipv6/router/ospf/{vrf} <area><area-id>{ospf:ospf-area-id}</area-id></area> Sets the OSPF router area id
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id} <nssa /> Specifies an nssa area.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa <default-information-originate /> Controls distribution of default information
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id} <virtual-link><virtual-link-neighbor>{inet:ipv4-address}</virtual-link-neighbor></virtual-link> Define a virtual link and its parameters.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id} <range><range-address>{common-def:ipv6-address-prefix}</range-address></range> Defines or undefines a type-3 address range (ABR only).
<base_URI>/config/running/ipv6/router/ospf/{vrf} <default-information-originate /> Controls distribution of default information.
<base_URI>/config/running/ipv6/router/ospf/{vrf} <distance><route-type>{ospf:route-type-enum}</route-type><distance-value>{uint32}</distance-value></distance> Defines an administrative distance
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log <adjacency /> Logging adjacency changes
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log <bad-packet /> Logging Bad packets
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute <connected /> Connected routes
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute <static /> Static routes
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute <isis /> ISIS routes
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute <bgp /> BGP routes
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute <ospf /> OSPF routes
<base_URI>/config/running/ipv6/router/ospf/{vrf} <summary-address><summary-address-value>{common-def:ipv6-address-prefix}</summary-address-value></summary-address> Configure IP address summaries
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric <router-lsa /> The maximum metric advertisement in Router LSAs
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa <external-lsa /> Replace Metric in External LSA with max metric value
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa <summary-lsa /> Replace Metric in Summary LSA with max metric value
<base_URI>/config/running <spi><ah>{algorithm-type-ah}</ah><ipsec><disable>{enumeration}</disable></ipsec></spi> Security Parameter Index specifying the authentication algorithm to use.
<base_URI>/config/running <spi><no-encrypt>{enumeration}</no-encrypt><ipsec><disable>{enumeration}</disable></ipsec></spi> Security Parameter Index without encrypting the key and configure ipsec authentication for the interface.
<base_URI>/config/running <spi><key>{ipsec-authentication-hexkey-string}</key><ipsec><disable>{enumeration}</disable></ipsec></spi> Security Parameter Index with Key used for ah.
<base_URI>/config/running <spi><esp>{algorithm-type-esp}</esp><ipsec><disable>{enumeration}</disable></ipsec></spi> Security Parameter Index specifying Encapsulating Security Payload (ESP)
<base_URI>/config/running <spi><esp-no-encrypt>{enumeration}</esp-no-encrypt><ipsec><disable>{enumeration}</disable></ipsec></spi> Security Parameter Index without encrypting the key
<base_URI>/config/running <spi><esp-key>{ipsec-authentication-hexkey-string}</esp-key><ipsec><disable>{enumeration}</disable></ipsec></spi> Security Parameter Index with Hexadecimal key string for ESP
<base_URI>/config/running <spi><esp-auth>{algorithm-type-ah}</esp-auth><ipsec><disable>{enumeration}</disable></ipsec></spi> Security Parameter Index using Authentication Algorithm
<base_URI>/config/running <spi><key>{ipsec-authentication-hexkey-string}</key><ipsec><disable>{enumeration}</disable></ipsec></spi> Security Parameter Index with Hexadecimal key string for authentication algorithm
<base_URI>/config/running <spi><esp-no-encrypt>{enumeration}</esp-no-encrypt><ipsec><disable>{enumeration}</disable></ipsec></spi> Security Parameter Index without encrypting the key.
PUT URIs Payload Description
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/normal <normal>{enumeration}</normal> Sets the OSPF router area id
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/nssa-area-metric <nssa-area-metric>{uint32}</nssa-area-metric> Specifies an nssa area.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/default-information-originate/metric <metric>{uint32}</metric> Controls distribution of default information
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/default-information-originate/metric-type <metric-type>{ospf:metric-type}</metric-type> Type of the metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/no-redistribution <no-redistribution>{enumeration}</no-redistribution> Do not send redistributed LSA into nssa area
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/no-summary <no-summary>{enumeration}</no-summary> Do not send summary LSA into nssa area
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/translator-always <translator-always>{enumeration}</translator-always> Set nssa translator role
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/translator-interval <translator-interval>{common-def:time-interval-sec}</translator-interval> Nssa translator stability interval
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/stub/no-summary <no-summary>{enumeration}</no-summary> Do not send summary LSA into stub area
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/stub/stub-area-metric <stub-area-metric>{uint32}</stub-area-metric> Stub area's advertised route metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <spi><ah>{algorithm-type-ah}</ah></spi> Security Parameter Index specifying the authentication algorithm to use.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <spi><no-encrypt>{enumeration}</no-encrypt></spi> Security Parameter Index without encrypting the key.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <spi><key>{ipsec-authentication-hexkey-string}</key></spi> Security Parameter Index with Key used for ah.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <spi><esp>{algorithm-type-esp}</esp></spi> Security Parameter Index specifying Encapsulating Security Payload (ESP)
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <spi><esp-no-encrypt>{enumeration}</esp-no-encrypt></spi> Security Parameter Index without encrypting the key
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <spi><esp-key>{ipsec-authentication-hexkey-string}</esp-key></spi> Security Parameter Index with Hexadecimal key string for ESP
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <spi><esp-auth>{algorithm-type-ah}</esp-auth></spi> Security Parameter Index using Authentication Algorithm
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <spi><key>{ipsec-authentication-hexkey-string}</key></spi> Security Parameter Index with Hexadecimal key string for authentication algorithm
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/hello-interval <hello-interval>{common-def:time-interval-sec}</hello-interval> Configures the time between hello packets that the router sends on an interface.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/dead-interval <dead-interval>{common-def:time-interval-sec}</dead-interval> Configures the time a neighbor router waits for a hello packet from the current router before declaring the router down.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/hello-jitter <hello-jitter>{uint32}</hello-jitter> Sets the allowed jitter between hello packets.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/retransmit-interval <retransmit-interval>{common-def:time-interval-sec}</retransmit-interval> Time between Link State Advertisement (LSA) retransmissions for adjacencies belonging to the interface.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/transmit-delay <transmit-delay>{common-def:time-interval-sec}</transmit-delay> Estimated time required to send an LSA on the interface.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <spi><ah>{algorithm-type-ah}</ah></spi> Security Parameter Index specifying the authentication algorithm to use.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <spi><no-encrypt>{enumeration}</no-encrypt></spi> Security Parameter Index without encrypting the key.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <spi><key>{ipsec-authentication-hexkey-string}</key></spi> Security Parameter Index with Key used for ah.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <spi><esp>{algorithm-type-esp}</esp></spi> Security Parameter Index specifying Encapsulating Security Payload (ESP)
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <spi><esp-no-encrypt>{enumeration}</esp-no-encrypt></spi> Security Parameter Index without encrypting the key
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <spi><esp-key>{ipsec-authentication-hexkey-string}</esp-key></spi> Security Parameter Index with Hexadecimal key string for ESP
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <spi><esp-auth>{algorithm-type-ah}</esp-auth></spi> Security Parameter Index using Authentication Algorithm
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <spi><key>{ipsec-authentication-hexkey-string}</key></spi> Security Parameter Index with Hexadecimal key string for authentication algorithm
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/range/{range-address}/range-effect <range-effect>{enumeration}</range-effect> Advertise this type-3 summarization
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/range/{range-address}/cost <cost>{ospf:range-metric}</cost> Configure area range cost
<base_URI>/config/running/ipv6/router/ospf/{vrf}/auto-cost/reference-bandwidth <reference-bandwidth>{ospf:band-width}</reference-bandwidth> Reference-bandwidth in Mbits per second
<base_URI>/config/running/ipv6/router/ospf/{vrf}/database-overflow-interval <database-overflow-interval>{common-def:time-interval-sec}</database-overflow-interval> Poll Interval in Seconds
<base_URI>/config/running/ipv6/router/ospf/{vrf}/default-information-originate/always <always>{enumeration}</always> Always advertise default route
<base_URI>/config/running/ipv6/router/ospf/{vrf}/default-information-originate/metric <metric>{uint32}</metric> Type of the metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/default-information-originate/metric-type <metric-type>{ospf:metric-type}</metric-type> OSPF metric type for default route
<base_URI>/config/running/ipv6/router/ospf/{vrf}/default-metric <default-metric>{uint32}</default-metric> Default metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/default-passive-interface <default-passive-interface>{enumeration}</default-passive-interface> Set OSPF interface passive
<base_URI>/config/running/ipv6/router/ospf/{vrf}/distribute-list/route-map <route-map><distribute-list-route-map-name>{common-def:name-string63}</distribute-list-route-map-name><in>{enumeration}</in></route-map> Use route-map to control routes learned by OSPFv3
<base_URI>/config/running/ipv6/router/ospf/{vrf}/distribute-list/prefix-list <prefix-list><distribute-list-prefix-list-name>{common-def:name-string63}</distribute-list-prefix-list-name><in>{enumeration}</in></prefix-list> Use prefix list to control routes learned by OSPFv3
<base_URI>/config/running/ipv6/router/ospf/{vrf}/external-lsdb-limit <external-lsdb-limit>{uint32}</external-lsdb-limit> External Link State Database Limit
<base_URI>/config/running/ipv6/router/ospf/{vrf}/graceful-restart/helper/disable <disable>{enumeration}</disable> Disable graceful restart helper capability
<base_URI>/config/running/ipv6/router/ospf/{vrf}/graceful-restart/helper/strict-lsa-checking <strict-lsa-checking>{enumeration}</strict-lsa-checking> Set strict LSA checking
<base_URI>/config/running/ipv6/router/ospf/{vrf}/key-add-remove-interval <key-add-remove-interval>{common-def:time-interval-sec}</key-add-remove-interval> Key add or remove interval in seconds
<base_URI>/config/running/ipv6/router/ospf/{vrf}/key-rollover-interval <key-rollover-interval>{common-def:time-interval-sec}</key-rollover-interval> New key rollover interval in seconds.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log/adjacency/dr-only <dr-only>{enumeration}</dr-only> Logging only Designated Router interfaces' adjacency changes
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log/all <all>{enumeration}</all> Logging everything
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log/bad-packet/checksum <checksum>{enumeration}</checksum> Logging bad checksum packets
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log/database <database>{enumeration}</database> Logging LSA activity
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log/retransmit <retransmit>{enumeration}</retransmit> Logging retransmit activity
<base_URI>/config/running/ipv6/router/ospf/{vrf}/metric-type <metric-type>{ospf:metric-type}</metric-type> OSPFv3 metric type for redistributed routes
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/connected/route-map <route-map>{common-def:name-string63}</route-map> Route map reference
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/connected/metric <metric>{uint32}</metric> OSPF metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/connected/metric-type <metric-type>{ospf:metric-type}</metric-type> Type of the metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/static/route-map <route-map>{common-def:name-string63}</route-map> Route map reference
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/static/metric <metric>{uint32}</metric> OSPF metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/static/metric-type <metric-type>{ospf:metric-type}</metric-type> Type of the metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/isis/route-map <route-map>{common-def:name-string63}</route-map> Route map reference
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/isis/level-1 <level-1>{enumeration}</level-1> Redistribution of IS-IS Level-1 routes only
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/isis/level-2 <level-2>{enumeration}</level-2> Redistribution of IS-IS Level-2 routes only
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/isis/level-1-2 <level-1-2>{enumeration}</level-1-2> Redistribution of IS-IS Level-1 and Level-2 routes
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/isis/metric <metric>{uint32}</metric> OSPF metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/isis/metric-type <metric-type>{ospf:metric-type}</metric-type> Type of the metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/bgp/route-map <route-map>{common-def:name-string63}</route-map> Route map reference
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/bgp/metric <metric>{uint32}</metric> OSPF metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/bgp/metric-type <metric-type>{ospf:metric-type}</metric-type> Type of the metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/ospf/route-map <route-map>{common-def:name-string63}</route-map> Route map reference
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/ospf/metric <metric>{uint32}</metric> OSPF metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/ospf/metric-type <metric-type>{ospf:metric-type}</metric-type> Type of the metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/timers/lsa-group-pacing <lsa-group-pacing>{common-def:time-interval-sec}</lsa-group-pacing> Interval between group of LSA being refreshed or maxaged
<base_URI>/config/running/ipv6/router/ospf/{vrf}/timers/spf <spf><spf-delay>{common-def:time-interval-sec}</spf-delay><spf-hold-time>{common-def:time-interval-sec}</spf-hold-time></spf> OSPFv3 SPF timers
<base_URI>/config/running/ipv6/router/ospf/{vrf}/nonstop-routing <nonstop-routing>{enumeration}</nonstop-routing> Enable nonstop-routing capability
<base_URI>/config/running/ipv6/router/ospf/{vrf}/maximum-paths <maximum-paths>{uint32}</maximum-paths> Maximum path.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/all-lsas <all-lsas>{enumeration}</all-lsas> Replace Metric in all External and Summary LSAs with default max metric value
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/external-lsa/external-lsa-value <external-lsa-value>{uint32}</external-lsa-value> Indicates the metric of all external type 5 and type 7 LSA's
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/summary-lsa/summary-lsa-value <summary-lsa-value>{uint32}</summary-lsa-value> Metric of all summary type 3 and type 4 LSAs
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/include-stub <include-stub>{enumeration}</include-stub> Configure include-stub for max-metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/on-startup/on-startup-time <on-startup-time>{uint32}</on-startup-time> Amount of time to advertise maximum metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/on-startup/wait-for-bgp <wait-for-bgp>{enumeration}</wait-for-bgp> Advertise maximum metric until BGP has converged or 600 seconds
PATCH URIs Payload Description
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id} <area><normal>{enumeration}</normal></area> Sets the OSPF router area id
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa <nssa><nssa-area-metric>{uint32}</nssa-area-metric></nssa> Specifies an nssa area.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/default-information-originate <default-information-originate><metric>{uint32}</metric></default-information-originate> Controls distribution of default information
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa/default-information-originate <default-information-originate><metric-type>{ospf:metric-type}</metric-type></default-information-originate> Type of the metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa <nssa><no-redistribution>{enumeration}</no-redistribution></nssa> Do not send redistributed LSA into nssa area
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa <nssa><no-summary>{enumeration}</no-summary></nssa> Do not send summary LSA into nssa area
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa <nssa><translator-always>{enumeration}</translator-always></nssa> Set nssa translator role
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/nssa <nssa><translator-interval>{common-def:time-interval-sec}</translator-interval></nssa> Nssa translator stability interval
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/stub <stub><no-summary>{enumeration}</no-summary></stub> Do not send summary LSA into stub area
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/stub <stub><stub-area-metric>{uint32}</stub-area-metric></stub> Stub area's advertised route metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <authentication><spi>{spi-value-type}</spi><ah>{algorithm-type-ah}</ah></authentication> Security Parameter Index specifying the authentication algorithm to use.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <authentication><spi>{spi-value-type}</spi><no-encrypt>{enumeration}</no-encrypt></authentication> Security Parameter Index without encrypting the key.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <authentication><spi>{spi-value-type}</spi><key>{ipsec-authentication-hexkey-string}</key></authentication> Security Parameter Index with Key used for ah.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <authentication><spi>{spi-value-type}</spi><esp>{algorithm-type-esp}</esp></authentication> Security Parameter Index specifying Encapsulating Security Payload (ESP)
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <authentication><spi>{spi-value-type}</spi><esp-no-encrypt>{enumeration}</esp-no-encrypt></authentication> Security Parameter Index without encrypting the key
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <authentication><spi>{spi-value-type}</spi><esp-key>{ipsec-authentication-hexkey-string}</esp-key></authentication> Security Parameter Index with Hexadecimal key string for ESP
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <authentication><spi>{spi-value-type}</spi><esp-auth>{algorithm-type-ah}</esp-auth></authentication> Security Parameter Index using Authentication Algorithm
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/authentication/virtual-link <authentication><spi>{spi-value-type}</spi><key>{ipsec-authentication-hexkey-string}</key></authentication> Security Parameter Index with Hexadecimal key string for authentication algorithm
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor} <virtual-link><hello-interval>{common-def:time-interval-sec}</hello-interval></virtual-link> Configures the time between hello packets that the router sends on an interface.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor} <virtual-link><dead-interval>{common-def:time-interval-sec}</dead-interval></virtual-link> Configures the time a neighbor router waits for a hello packet from the current router before declaring the router down.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor} <virtual-link><hello-jitter>{uint32}</hello-jitter></virtual-link> Sets the allowed jitter between hello packets.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor} <virtual-link><retransmit-interval>{common-def:time-interval-sec}</retransmit-interval></virtual-link> Time between Link State Advertisement (LSA) retransmissions for adjacencies belonging to the interface.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor} <virtual-link><transmit-delay>{common-def:time-interval-sec}</transmit-delay></virtual-link> Estimated time required to send an LSA on the interface.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <authentication><spi>{spi-value-type}</spi><ah>{algorithm-type-ah}</ah></authentication> Security Parameter Index specifying the authentication algorithm to use.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <authentication><spi>{spi-value-type}</spi><no-encrypt>{enumeration}</no-encrypt></authentication> Security Parameter Index without encrypting the key.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <authentication><spi>{spi-value-type}</spi><key>{ipsec-authentication-hexkey-string}</key></authentication> Security Parameter Index with Key used for ah.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <authentication><spi>{spi-value-type}</spi><esp>{algorithm-type-esp}</esp></authentication> Security Parameter Index specifying Encapsulating Security Payload (ESP)
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <authentication><spi>{spi-value-type}</spi><esp-no-encrypt>{enumeration}</esp-no-encrypt></authentication> Security Parameter Index without encrypting the key
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <authentication><spi>{spi-value-type}</spi><esp-key>{ipsec-authentication-hexkey-string}</esp-key></authentication> Security Parameter Index with Hexadecimal key string for ESP
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <authentication><spi>{spi-value-type}</spi><esp-auth>{algorithm-type-ah}</esp-auth></authentication> Security Parameter Index using Authentication Algorithm
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/virtual-link/{virtual-link-neighbor}/authentication/range <authentication><spi>{spi-value-type}</spi><key>{ipsec-authentication-hexkey-string}</key></authentication> Security Parameter Index with Hexadecimal key string for authentication algorithm
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/range/{range-address} <range><range-effect>{enumeration}</range-effect></range> Advertise this type-3 summarization
<base_URI>/config/running/ipv6/router/ospf/{vrf}/area/{area-id}/range/{range-address} <range><cost>{ospf:range-metric}</cost></range> Configure area range cost
<base_URI>/config/running/ipv6/router/ospf/{vrf}/auto-cost <auto-cost><reference-bandwidth>{ospf:band-width}</reference-bandwidth></auto-cost> Reference-bandwidth in Mbits per second
<base_URI>/config/running/ipv6/router/ospf/{vrf} <ospf><database-overflow-interval>{common-def:time-interval-sec}</database-overflow-interval></ospf> Poll Interval in Seconds
<base_URI>/config/running/ipv6/router/ospf/{vrf}/default-information-originate <default-information-originate><always>{enumeration}</always></default-information-originate> Always advertise default route
<base_URI>/config/running/ipv6/router/ospf/{vrf}/default-information-originate <default-information-originate><metric>{uint32}</metric></default-information-originate> Type of the metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/default-information-originate <default-information-originate><metric-type>{ospf:metric-type}</metric-type></default-information-originate> OSPF metric type for default route
<base_URI>/config/running/ipv6/router/ospf/{vrf} <ospf><default-metric>{uint32}</default-metric></ospf> Default metric
<base_URI>/config/running/ipv6/router/ospf/{vrf} <ospf><default-passive-interface>{enumeration}</default-passive-interface></ospf> Set OSPF interface passive
<base_URI>/config/running/ipv6/router/ospf/{vrf}/distance/{route-type} <distance><distance-value>{uint32}</distance-value></distance> Distance for the given type of routes
<base_URI>/config/running/ipv6/router/ospf/{vrf} <ospf><external-lsdb-limit>{uint32}</external-lsdb-limit></ospf> External Link State Database Limit
<base_URI>/config/running/ipv6/router/ospf/{vrf}/graceful-restart/helper <helper><disable>{enumeration}</disable></helper> Disable graceful restart helper capability
<base_URI>/config/running/ipv6/router/ospf/{vrf}/graceful-restart/helper <helper><strict-lsa-checking>{enumeration}</strict-lsa-checking></helper> Set strict LSA checking
<base_URI>/config/running/ipv6/router/ospf/{vrf} <ospf><key-add-remove-interval>{common-def:time-interval-sec}</key-add-remove-interval></ospf> Key add or remove interval in seconds
<base_URI>/config/running/ipv6/router/ospf/{vrf} <ospf><key-rollover-interval>{common-def:time-interval-sec}</key-rollover-interval></ospf> New key rollover interval in seconds.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log/adjacency <adjacency><dr-only>{enumeration}</dr-only></adjacency> Logging only Designated Router interfaces' adjacency changes
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log <log><all>{enumeration}</all></log> Logging everything
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log/bad-packet <bad-packet><checksum>{enumeration}</checksum></bad-packet> Logging bad checksum packets
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log <log><database>{enumeration}</database></log> Logging LSA activity
<base_URI>/config/running/ipv6/router/ospf/{vrf}/log <log><retransmit>{enumeration}</retransmit></log> Logging retransmit activity
<base_URI>/config/running/ipv6/router/ospf/{vrf} <ospf><metric-type>{ospf:metric-type}</metric-type></ospf> OSPFv3 metric type for redistributed routes
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/connected <connected><route-map>{common-def:name-string63}</route-map></connected> Route map reference
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/connected <connected><metric>{uint32}</metric></connected> OSPF metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/connected <connected><metric-type>{ospf:metric-type}</metric-type></connected> Type of the metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/static <static><route-map>{common-def:name-string63}</route-map></static> Route map reference
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/static <static><metric>{uint32}</metric></static> OSPF metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/static <static><metric-type>{ospf:metric-type}</metric-type></static> Type of the metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/isis <isis><route-map>{common-def:name-string63}</route-map></isis> Route map reference
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/isis <isis><metric>{uint32}</metric></isis> OSPF metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/isis <isis><metric-type>{ospf:metric-type}</metric-type></isis> Type of the metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/bgp <bgp><route-map>{common-def:name-string63}</route-map></bgp> Route map reference
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/bgp <bgp><metric>{uint32}</metric></bgp> OSPF metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/bgp <bgp><metric-type>{ospf:metric-type}</metric-type></bgp> Type of the metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/ospf <ospf><route-map>{common-def:name-string63}</route-map></ospf> Route map reference
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/ospf <ospf><metric>{uint32}</metric></ospf> OSPF metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/redistribute/ospf <ospf><metric-type>{ospf:metric-type}</metric-type></ospf> Type of the metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/timers <timers><lsa-group-pacing>{common-def:time-interval-sec}</lsa-group-pacing></timers> Interval between group of LSA being refreshed or maxaged
<base_URI>/config/running/ipv6/router/ospf/{vrf} <ospf><nonstop-routing>{enumeration}</nonstop-routing></ospf> Enable nonstop-routing capability
<base_URI>/config/running/ipv6/router/ospf/{vrf} <ospf><maximum-paths>{uint32}</maximum-paths></ospf> Maximum path.
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa <router-lsa><all-lsas>{enumeration}</all-lsas></router-lsa> Replace Metric in all External and Summary LSAs with default max metric value
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/external-lsa <external-lsa><external-lsa-value>{uint32}</external-lsa-value></external-lsa> Indicates the metric of all external type 5 and type 7 LSA's
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/summary-lsa <summary-lsa><summary-lsa-value>{uint32}</summary-lsa-value></summary-lsa> Metric of all summary type 3 and type 4 LSAs
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa <router-lsa><include-stub>{enumeration}</include-stub></router-lsa> Configure include-stub for max-metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/on-startup <on-startup><on-startup-time>{uint32}</on-startup-time></on-startup> Amount of time to advertise maximum metric
<base_URI>/config/running/ipv6/router/ospf/{vrf}/max-metric/router-lsa/on-startup <on-startup><wait-for-bgp>{enumeration}</wait-for-bgp></on-startup> Advertise maximum metric until BGP has converged or 600 seconds
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/ipv6/router/ospf/default-vrf
None
<ospf xmlns="urn:brocade.com:mgmt:brocade-ospfv3" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/ipv6/router/ospf/default-vrf">
  <vrf>default-vrf</vrf>
  <area y:self="/rest/config/running/ipv6/router/ospf/default-vrf/area/0">
    <area-id>0</area-id>
    <normal>true</normal>
    <stub y:self="/rest/config/running/ipv6/router/ospf/default-vrf/area/0/stub">
    </stub>
    <authentication y:self="/rest/config/running/ipv6/router/ospf/default-vrf/area/0/authentication">
    </authentication>
  </area>
  <area y:self="/rest/config/running/ipv6/router/ospf/default-vrf/area/100">
    <area-id>100</area-id>
    <stub y:self="/rest/config/running/ipv6/router/ospf/default-vrf/area/100/stub">
    </stub>
    <authentication y:self="/rest/config/running/ipv6/router/ospf/default-vrf/area/100/authentication">
    </authentication>
  </area>
  <area y:self="/rest/config/running/ipv6/router/ospf/default-vrf/area/200">
    <area-id>200</area-id>
    <nssa y:self="/rest/config/running/ipv6/router/ospf/default-vrf/area/200/nssa">
    </nssa>
    <stub y:self="/rest/config/running/ipv6/router/ospf/default-vrf/area/200/stub">
    </stub>
    <authentication y:self="/rest/config/running/ipv6/router/ospf/default-vrf/area/200/authentication">
    </authentication>
  </area>
  <auto-cost y:self="/rest/config/running/ipv6/router/ospf/default-vrf/auto-cost">
  </auto-cost>
  <default-information-originate y:self="/rest/config/running/ipv6/router/ospf/default-vrf/default-information-originate">
  <distribute-list y:self="/rest/config/running/ipv6/router/ospf/default-vrf/distribute-list">
    <route-map y:self="/rest/config/running/ipv6/router/ospf/default-vrf/distribute-list/route-map">
    </route-map>
    <prefix-list y:self="/rest/config/running/ipv6/router/ospf/default-vrf/distribute-list/prefix-list">
    </prefix-list>
  </distribute-list>
  <external-lsdb-limit>50000</external-lsdb-limit>
  <graceful-restart y:self="/rest/config/running/ipv6/router/ospf/default-vrf/graceful-restart">
    <helper y:self="/rest/config/running/ipv6/router/ospf/default-vrf/graceful-restart/helper">
    </helper>
  </graceful-restart>
  <log y:self="/rest/config/running/ipv6/router/ospf/default-vrf/log">
  </log>
  <redistribute y:self="/rest/config/running/ipv6/router/ospf/default-vrf/redistribute">
  </redistribute>
  <timers y:self="/rest/config/running/ipv6/router/ospf/default-vrf/timers">
    <spf y:self="/rest/config/running/ipv6/router/ospf/default-vrf/timers/spf">
    </spf>
  </timers>
  <nonstop-routing>true</nonstop-routing>
  <max-metric y:self="/rest/config/running/ipv6/router/ospf/default-vrf/max-metric">
  </max-metric>
</ospf>
URI
The following example uses the POST option to configure OSPF instance for the VRF.
http://host:80/rest/config/running/config/running/ipv6/router
<ospf><vrf>vrf1</vrf></ospf>
None
