Configures and manages the MPLS protocol.
URI | Description |
<base_URI>/config/running/router/mpls | MPLS Protocol |
There are separate sections for other MPLS APIs which are not covered in this topic.GET URIs | Description |
<BASE_URI>/config/running/router/mpls | MPLS Protocol |
<BASE_URI>/config/running/router/mpls/lsp-xc-traps/enable | Enable the LSP XC up/down logging/traps |
<BASE_URI>/config/running/router/mpls/cspf-group/{cspf-group-name}/penalty | Configure cspf group penalty value |
POST URIs | Payload | Description |
<BASE_URI>/config/running/router | <mpls /> | MPLS Protocol |
<BASE_URI>/config/running/router/mpls/cspf-group/{cspf-group-name} | <from><cspf-group-ip-address>{req_val}</cspf-group-ip-address></from> | Configure cspf group from ip address |
<BASE_URI>/config/running/router/mpls/cspf-group/{cspf-group-name} | <link><cspf-group-link-from>{req_val}</cspf-group-link-from><to>{req_val}</to></link> | Configure cspf group from and to ip address |
<BASE_URI>/config/running/router/mpls/cspf-group/{cspf-group-name} | <subnet><cspf-group-subnet-ip>{req_val}</cspf-group-subnet-ip></subnet> | Configure cspf group subnet address |
<BASE_URI>/config/running/router/mpls/cspf-group/{cspf-group-name} | <node><cspf-group-node-ip>{req_val}</cspf-group-node-ip></node> | Configure cspf group node ip address |
<BASE_URI>/config/running/router/mpls | <path><path-name>{req_val}</path-name></path> | Defines a path |
<BASE_URI>/config/running/router/mpls/path/{path-name} | <hop><path-hop-ip>{req_val}</path-hop-ip><path-hop-type>{strict-loose-hop}</path-hop-type></hop> | Configures path strict or loose hops |
<BASE_URI>/config/running/router/mpls/path/{path-name} | <insert><path-insert-ip>{req_val}</path-insert-ip><path-insert-type>{strict-loose-hop}</path-insert-type><before>{inet:ipv4-address}</before></insert> | Insert path strict or loose hops |
PATCH URIs | Payload | Description |
<BASE_URI>/config/running/router/mpls/lsp-xc-traps/enable | <enable /> | Enable the LSP XC up/down logging/traps |
<BASE_URI>/config/running/router/mpls/cspf-group | <absolute>{uint32}</absolute> | Configure Max reservable bandwidth as absolute value |
<BASE_URI>/config/running/router/mpls/cspf-group | <percentage>{uint32}</percentage> | Configure Max reservable bandwidth as percentage |
<BASE_URI>/config/running/router/mpls/cspf-group/{cspf-group-name} | <cspf-group><penalty>{uint32}</penalty></cspf-group> | Define a CSPF group penalty and configure cspf group penalty value |
<BASE_URI>/config/running/router/mpls/path/{path-name}/hop/{path-hop-ip} | <hop><path-hop-type>{strict-loose-hop}</path-hop-type></hop> | Configure path strict or loose hops |
<BASE_URI>/config/running/router/mpls/path/{path-name}/insert/{path-insert-ip} | <insert><path-insert-type>{strict-loose-hop}</path-insert-type><before>{inet:ipv4-address}</before></insert> | Insert path strict or loose hops |
PUT URIs | Payload | Description |
<BASE_URI>/config/running/router/mpls/cspf-group | <absolute>{uint32}</absolute> | Configure cspf-group |
<BASE_URI>/config/running/router/mpls/cspf-group | <percentage>{uint32}</percentage> | Bandwidth percentage when bandwidth is decreased or increased |
<BASE_URI>/config/running/router/mpls/cspf-group/{cspf-group-name}/penalty | <penalty>{uint32}</penalty> | Configure cspf group penalty value |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the CSPF group configuration details.
http://host:80/rest/config/running/router/mpls/cspf-group
None
<cspf-group xmlns="urn:brocade.com:mgmt:brocade-mpls" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/router/mpls/cspf-group/cspf1"> <cspf-group-name>cspf1</cspf-group-name> </cspf-group>
The following example uses the PATCH option to set the penalty value to 22.
http://host:80/rest/config/running/router/mpls/cspf-group/cspf1
<cspf-group><penalty>22</penalty></cspf-group>
None
The following example uses the DELETE option to remove the penalty configuration.
http://host:80/rest/config/running/router/mpls/cspf-group/cspf1/penalty
None
None
