Clears all voq statistics for selected slot.
| URI | Description |
| <base_URI>/operations/clear-tm-voq-stat-slot-id-egr-all | Clears all voq statistics for selected slot |
Only POST operation is supported.
http://host:80/rest/operations/clear-tm-voq-stat-slot-id-egr-all
<clear-tm-voq-stat-slot-id-egr-all><slot-id>5</slot-id></clear-tm-voq-stat-slot-id-egr-all>
