Displays IS-IS IPv4 route information
| URI | Description |
| <base_URI>/operational-state/isis-state/ipv4-routes | Displays IPv4 ISIS routes |
| <base_URI>/operational-state/isis-state/ipv4-routes/total-routes-count | Displays Total number of PIv4 ISIS routes |
| <base_URI>/operational-state/isis-state/ipv4-routes/ipv4-route-entry | Displays IPv4 ISIS route entry |
| <base_URI>/operational-state/isis-state/ipv4-routes/ipv4-route-entry/{ipv4-dest-addr},{ipv4-subnet-mask},{ipv4-prefix-len}/level | Displays ISIS route type |
| <base_URI>/operational-state/isis-state/ipv4-routes/ipv4-route-entry/{ipv4-dest-addr},{ipv4-subnet-mask},{ipv4-prefix-len}/cost | Displays Cost of ISIS route |
| <base_URI>/operational-state/isis-state/ipv4-routes/ipv4-route-entry/{ipv4-dest-addr},{ipv4-subnet-mask},{ipv4-prefix-len}/tag | Displays Tag value |
| <base_URI>/operational-state/isis-state/ipv4-routes/ipv4-route-entry/{ipv4-dest-addr},{ipv4-subnet-mask},{ipv4-prefix-len}/flags | Displays Flags |
| <base_URI>/operational-state/isis-state/ipv4-routes/ipv4-route-entry/{ipv4-dest-addr},{ipv4-subnet-mask},{ipv4-prefix-len}/is-l1-summarized | Displays whether L1 route is summarized or not |
| <base_URI>/operational-state/isis-state/ipv4-routes/ipv4-route-entry/{ipv4-dest-addr},{ipv4-subnet-mask},{ipv4-prefix-len}/is-l2-summarized | Displays whether L2 route is summarized or not |
| <base_URI>/operational-state/isis-state/ipv4-routes/ipv4-route-entry/{ipv4-dest-addr},{ipv4-subnet-mask},{ipv4-prefix-len}/is-summary | Displays whether the specified route is the summary route or not |
| <base_URI>/operational-state/isis-state/ipv4-routes/ipv4-route-entry/{ipv4-dest-addr},{ipv4-subnet-mask},{ipv4-prefix-len}/nh-info | Displays Next hop information |
| <base_URI>/operational-state/isis-state/ipv4-routes/ipv4-route-entry/{ipv4-dest-addr},{ipv4-subnet-mask},{ipv4-prefix-len}/nh-info/{outgoing-intf-type},{outgoing-intf-number}/ipv4-nh-addr | Displays the next hop ip address |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/operational-state/isis-state/ipv4-routes
None
<ipv4-routes xmlns="urn:brocade.com:mgmt:brocade-isis-operational" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/operational-state/isis-state/ipv4-routes">
<total-routes-count>11</total-routes-count>
<ipv4-route-entry y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/140.140.140.0%2C255.255.255.
0%2C24">
<ipv4-dest-addr>140.140.140.0</ipv4-dest-addr>
<ipv4-subnet-mask>255.255.255.0</ipv4-subnet-mask>
<ipv4-prefix-len>24</ipv4-prefix-len>
<level>1</level>
<cost>20</cost>
<tag>0</tag>
<flags>4</flags>
<is-l1-summarized>false</is-l1-summarized>
<is-l2-summarized>false</is-l2-summarized>
<is-summary>false</is-summary>
<nh-info y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/140.140.140.0%2C255.255.255.
0%2C24/
nh-info/eth%2C%221/49%22">
<outgoing-intf-type>eth</outgoing-intf-type>
<outgoing-intf-number>1/49</outgoing-intf-number>
<ipv4-nh-addr>140.140.140.2</ipv4-nh-addr>
</nh-info>
</ipv4-route-entry>
<ipv4-route-entry y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.1%2C255.255.255.
255%2C32">
<ipv4-dest-addr>150.150.150.1</ipv4-dest-addr>
<ipv4-subnet-mask>255.255.255.255</ipv4-subnet-mask>
<ipv4-prefix-len>32</ipv4-prefix-len>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>4</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.1%2C255.255.255.
255%2C32/
</nh-info>
</ipv4-route-entry>
<ipv4-route-entry y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.2%2C255.255.255.
255%2C32">
<ipv4-dest-addr>150.150.150.2</ipv4-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>4</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.2%2C255.255.255.255%2C32/
</nh-info>
</ipv4-route-entry>
<ipv4-route-entry y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.3%2C255.255.255.
255%2C32">
<ipv4-dest-addr>150.150.150.3</ipv4-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>4</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.3%2C255.255.255.255%2C32/
</nh-info>
</ipv4-route-entry>
<ipv4-route-entry y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.4%2C255.255.255.
255%2C32">
<ipv4-dest-addr>150.150.150.4</ipv4-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>4</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.4%2C255.255.255.255%2C32/
</nh-info>
</ipv4-route-entry>
<ipv4-route-entry y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.5%2C255.255.255.
255%2C32">
<ipv4-dest-addr>150.150.150.5</ipv4-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>4</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.5%2C255.255.255.255%2C32/
</nh-info>
</ipv4-route-entry>
<ipv4-route-entry y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.6%2C255.255.255.
255%2C32">
<ipv4-dest-addr>150.150.150.6</ipv4-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>4</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.6%2C255.255.255.255%2C32/
</nh-info>
</ipv4-route-entry>
<ipv4-route-entry y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.7%2C255.255.255.
255%2C32">
<ipv4-dest-addr>150.150.150.7</ipv4-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>4</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.7%2C255.255.255.255%2C32/
</nh-info>
</ipv4-route-entry>
<ipv4-route-entry y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.8%2C255.255.255.
255%2C32">
<ipv4-dest-addr>150.150.150.8</ipv4-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>4</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.8%2C255.255.255.255%2C32/
</nh-info>
</ipv4-route-entry>
<ipv4-route-entry y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.9%2C255.255.255.
255%2C32">
<ipv4-dest-addr>150.150.150.9</ipv4-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>4</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.9%2C255.255.255.255%2C32/
</nh-info>
</ipv4-route-entry>
<ipv4-route-entry y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.10%2C255.255.
255.255%2C32">
<ipv4-dest-addr>150.150.150.10</ipv4-dest-addr>
<level>1</level>
<cost>10</cost>
<tag>0</tag>
<flags>4</flags>
<nh-info y:self="/rest/operational-state/isis-state/ipv4-routes/ipv4-route-entry/150.150.150.10%2C255.255.255.255%2C32/
</nh-info>
</ipv4-route-entry>
</ipv4-routes>
