Displays MCT operational information.
| URI | Description |
| <base_URI>/operational-state/mct-state | Displays MCT operational information. |
| <base_URI>/operational-state/mct-state/show-cluster/{cluster-id} | Displays the complete client-information list, which includes cluster-id, client-id, client-name, client-esi, client-interface, client-state, active vlan list, configured vlan list |
| <base_URI>/operational-state/mct-state/show-cluster/{cluster-id}/cluster-name | Displays the cluster name configured. |
| <base_URI>/operational-state/show-cluster/{cluster-id}/cluster-status | Provides the cluster status: True for Up status, False for Down status. |
| <base_URI>/operational-state/show-cluster/{cluster-id}/client-isolation-status | Provides the configured client-isolation status(strict mode or Loose mode). |
| <base_URI>/operational-state/mct-state/show-cluster/1/num-peers | Displays number of peers. |
| <base_URI>/operational-state/mct-state/show-cluster/1/num-clients | Displays number of clients. |
| <base_URI>/operational-state/mct-state/show-cluster/1/num-config-vlans | Displays number of configured VLANs. |
| <base_URI>/operational-state/mct-state/show-cluster/1/num-active-vlans | Displays number of active VLANs. |
| <base_URI>/operational-state/show-cluster/{cluster-id}/ client-info-list/{cluster-id},{client-id}/client-name | Displays the client-name information. |
| <base_URI>/operational-state/show-cluster/{cluster-id}/ client-info-list/{cluster-id},{client-id}/client-interface | Displays the configured client-interface information. |
| <base_URI>/operational-state/mct-state/show-cluster/1/client-info-list/1/1/client-state | Displays client state. |
| <base_URI>/operational-state/mct-state/show-cluster/1/client-info-list/1/1/num-config-vlans | Displays number of VLANs. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/operational-state/mct-state
None
<mct-state xmlns="urn:brocade.com:mgmt:brocade-nsm-operational" y:self="/rest/operational-state/mct-state"> </mct-state>
