Configures DHCP relay gateway.
URI | Description |
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/dhcp/relay/gateway | Configures DHCP relay gateway. Valid interface types: Ethernet, Ve. |
GET URIs | Description |
POST URIs | Payload | Description |
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/dhcp/relay | <gateway>{ip-address}</gateway> | Configures DHCP relay gateway. Valid interface types: Ethernet, Ve. |
PATCH URIs | Payload | Description |
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/dhcp/relay/gateway | <gateway>{ip-address}</gateway> | Configures DHCP relay gateway. Valid interface types: Ethernet, Ve. |
PUT URIs | Payload | Description |
DELETE URIs |
GET, POST, PATCH, PUT, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/ve/11/ip/dhcp/relay/gateway
None
<gateway xmlns="urn:brocade.com:mgmt:brocade-dhcp" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/interface/Ve/11/ip/dhcp/relay/gateway">11.1.2.1</gateway>
The following example uses the POST option to configure DHCP relay gateway.
http://host:80/rest/config/running/interface/ethernet/%221/10%22/ip/dhcp/relay
<gateway>10.10.10.10</gateway>
None
The following example uses the DELETE option to remove DHCP relay gateway.
http://host:80/rest/config/running/interface/ethernet/%221/10%22/ip/dhcp/relay/gateway
None
None
