Configures, modifies, or retrieves complete list of configured mirroring sessions.
| URI | Description |
| <base_URI>/config/running/monitor/session | Configures complete list of configured mirroring sessions. |
| GET URIs | Description |
| <base_URI>/config/running/monitor | Retrieves complete list of configured mirroring sessions. |
| <base_URI>/config/running/monitor/session/{session-number} | Retrieves mirroring information of particular session. |
| <base_URI>/config/running/monitor/session/{session-number}/description | Retrieves description of particular mirroring session. |
| <base_URI>/config/running/monitor/session/{session-number}/direction | Retrieves direction information of particular session. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/monitor | <session><session-number>{session-type}</session-number></session> | Configures mirroring session. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/monitor/session/{session-number} | <session><description>{string}</description></session> | Adds description information to an existing mirroring session. |
| <base_URI>/config/running/monitor/session/{session-number} | <session><source>source</source><src-ethernet-val>{slot/port}</src-ethernet-val><src-ethernet>ethernet</src-ethernet><destination>destination</destination><dest- ethernet>ethernet</dest-ethernet><dest-ethernet-val>{slot/port}</dest-ethernet-val><direction>{rx|tx|both}</direction></session> | Adds source interface, destination interface, and direction information to an existing mirroring session created using POST command. |
| <base_URI>/config/running/monitor/session/{session-number} | <session><source>source</source><src-ethernet-val>{slot/port}</src-ethernet-val><src-ethernet>ethernet</src-ethernet><destination>destination</destination><dest- ethernet>ethernet</dest-ethernet><dest-port-channel-val>{port-channel number}</dest-port-channel-val><direction>{rx|tx|both}</direction></session> | Adds source interface, destination port-channel number, and direction information to an existing mirroring session created using POST command. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/monitor/session/{session-number}/description | <description>{string}</description> | Adds description information to an existing mirroring session. |
| DELETE URIs |
GET, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/monitor/session/3
None
<session xmlns="urn:brocade.com:mgmt:brocade-span" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/monitor/session/3"> <session-number>3</session-number> <source>source</source> <src-ethernet>ethernet</src-ethernet> <src-ethernet-val>1/3</src-ethernet-val> <destination>destination</destination> <dest-ethernet>ethernet</dest-ethernet> <dest-ethernet-val>1/4</dest-ethernet-val> <direction>tx</direction> </session>
The following example uses the POST option to configure mirroring session.
None
The following example uses the DELETE option to remove mirror session.
None
None
