Configures, modifies, or retrieves Neighbor Discovery commands at global level.
URI | Description |
<base_URI>/config/running/ipv6/nd | Configures Neighbor Discovery commands. |
GET URIs | Description |
<base_URI>/config/running/ipv6/nd/global-suppress-ra | Sets globally suppress-ra. |
<base_URI>/config/running/ipv6/nd/ra-dns-server/{string} | Sets global DNS server option applied on all ND6 interfaces |
<base_URI>/config/running/ipv6/nd/ra-domain-name/{string}/lifetime-multplier | Set global domain name option that applied on all ND6 interfaces and applies Lifetime multiplier for DNS Search List option. |
POST URIs | Payload | Description |
<base_URI>/config/running/ipv6/nd | <global-suppress-ra>(enumeration)</global-suppress-ra> | Sets globally suppress-ra. |
<base_URI>/config/running/ipv6/nd | <ra-dns-server><dns-server-prefix-global>{dns-server-prefix}</dns-server-prefix-global><lifetime-multplier>(decimal)</lifetime-multplier></ra-dns-server> | Set global DNS server option applied on all ND6 interfaces. |
<base_URI>/config/running/ipv6/nd | <ra-domain-name><domain-name-string-global>{name}</domain-name-string-global><lifetime-multplier>{decimal}</lifetime-multplier></ra-domain-name> | Set global domain name option that applied on all ND6 interfaces. |
PUT URIs | Payload | Description |
<base_URI>/config/running/ipv6/nd/ra-dns-server/{ipv6_address_of_name_server}/lifetime-multplier | <lifetime-multplier>(decimal)</lifetime-multplier> | Lifetime multiplier for the DNS Server option |
<base_URI>/config/running/ipv6/nd/ra-domain-name/{name}/lifetime-multplier | <lifetime-multplier>(decimal)</lifetime-multplier> | Lifetime multiplier for DNS search list option. |
DELETE URIs |
<base_URI>/config/running/ipv6/nd/ra-dns-server/{ipv6_address_of_name_server} |
<base_URI>/config/running/ipv6/nd/ra-domain-name/{name} |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/ipv6/nd/global-suppress-ra
None
<nd xmlns="urn:brocade.com:mgmt:brocade-ipv6-nd-ra" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/ipv6/nd"> <global-suppress-ra>true</global-suppress-ra> <ra-dns-server y:self="/rest/config/running/ipv6/nd/ra-dns-server/2100:21:2134::566"> <dns-server-prefix-global>2100:21:2134::566</dns-server-prefix-global> </ra-dns-server> <ra-dns-server y:self="/rest/config/running/ipv6/nd/ra-dns-server/3600:36::1"> <dns-server-prefix-global>3600:36::1</dns-server-prefix-global> </ra-dns-server> <ra-dns-server y:self="/rest/config/running/ipv6/nd/ra-dns-server/3600:36::11"> <dns-server-prefix-global>3600:36::11</dns-server-prefix-global> </ra-dns-server> <ra-domain-name y:self="/rest/config/running/ipv6/nd/ra-domain-name/test.in"> <domain-name-string-global>test.in</domain-name-string-global> </ra-domain-name> <ra-domain-name y:self="/rest/config/running/ipv6/nd/ra-domain-name/test.sk"> <domain-name-string-global>test.sk</domain-name-string-global> </ra-domain-name> <ra-domain-name y:self="/rest/config/running/ipv6/nd/ra-domain-name/test.uk"> <domain-name-string-global>test.uk</domain-name-string-global> </ra-domain-name> <ra-domain-name y:self="/rest/config/running/ipv6/nd/ra-domain-name/test.us"> <domain-name-string-global>test.us</domain-name-string-global> </ra-domain-name> </nd>
The following is an example of the POST operation to set global DNS server option applied on all ND6 interfaces.
<ra-dns-server><dns-server-prefix-global>3300:36::11</dns-server-prefix-global><lifetime-multplier>199</lifetime-multplier> </ra-dns-server>
None
The following is an example of the DELETE operation to remove ilfetime multiplier for the DNS Server option.
http://host:80/rest/config/running/ipv6/nd/ra-dns-server/3400:36::11/lifetime-multplier
None
None
