mpls-state/rsvp/igp-sync
Displays the MPLS RSVP IGP synchronization information.
Resource URIs
URI Description
<base_URI>/operational-state/mpls-state/rsvp/igp-sync Displays the MPLS RSVP IGP synchronization information.
Usage Guidelines
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
URI
http://host:80/rest/operational-state/mpls-state/rsvp/igp-sync
None
<igp-sync xmlns="urn:brocade.com:mgmt:brocade-mpls-operational" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/operational-state/mpls-state/rsvp/igp-sync">
  <isis-nbr-down-enabled>false</isis-nbr-down-enabled>
  <ospf-nbr-down-enabled>false</ospf-nbr-down-enabled>
</igp-sync>
