clear-mpls-statistics
Clears MPLS statistics.
Resource URIs
URI Description
<base_URI>/operations/clear-mpls-statistics Clears MPLS statistics.
Parameters
mpls-clear-statistics-type
Specifies one of the following statistics to be cleared - OAM, tunnel, or transit traffic statistics.
tunnel-name
Specifies the tunnel name.
Usage Guidelines
Only POST operation is supported.
URI
http://host:80/rest/operations/clear-mpls-statistics
<clear-mpls-statistics><mpls-clear-statistics-type>3</mpls-clear-statistics-type><tunnel-name>t2</tunnel-name>
</clear-mpls-statistics>
None
