Configures, modifies, or retrieves the Policy-based Routing (PBR) configuration.
| URI | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/policy | Configures PBR (IPv6).
Valid interface types: Ethernet, Ve.. |
| GET URIs | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/policy | Retrieves PBR (IPv6) policy. Valid interface types: Ethernet, Ve. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/policy/route-map | Retrieves PBR (IPv6) route map. Valid interface types: Ethernet, Ve. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/policy/route-map/ipv6-route-map-name | Retrieves PBR (IPv6) route map name. Valid interface types: Ethernet, Ve. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/interface/Ethernet/{name}/ipv6/policy/route-map | <route-map><ipv6-route-map-name>{common-def:name-string63}</ipv6-route-map-name></route-map> | Configures PBR (IPv6). Valid interface types: Ethernet, Ve. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/interface/Ethernet/{name}/ipv6/policy/route-map/ipv6-route-map-name | <ipv6-route-map-name>{common-def:name-string63}</ipv6-route-map-name> | Configures PBR (IPv6). Valid interface types: Ethernet, Ve. |
| DELETE URIs |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/Ethernet/%221/1%22/ipv6/policy
None
None
The following is an example of the PUT operation to configure a route map.
http://host:80/rest/config/running/interface/Ethernet/%221/1%22/ipv6/policy/route-map/map10
<policy xmlns="urn:brocade.com:mgmt:brocade-ip-policy" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/interface/Ethernet/%221/39%22/ipv6/policy">
<route-map y:self="/rest/config/running/interface/Ethernet/%221/39%22/ipv6/policy/route-map">
<ipv6-route-map-name>map10</ipv6-route-map-name>
</route-map>
</policy>
None
The following is an example of the DELETE operation to remove a route map.
None
None
