Configures, modifies, or retrieves Link Layer Discovery Protocol (LLDP) configuration.
| URI | Description |
| <base_URI>/config/running/protocol | Protocol configuration. |
| <base_URI>/config/running/protocol/lldp | Link Layer Discovery Protocol (LLDP). |
| GET URIs | Description |
| <base_URI>/config/running/protocol/lldp | Protocol configuration. |
| <base_URI>/config/running/protocol/lldp/description | Retrieves the user description. |
| <base_URI>/config/running/protocol/lldp/hello | Retrieves hello interval. |
| <base_URI>/config/running/protocol/lldp/mode | Retrieves LLDP Transmit Only Mode information. |
| <base_URI>/config/running/protocol/lldp/multiplier | Retrieves multiplier details. |
| <base_URI>/config/running/protocol/lldp//advertise/dot1-tlv | Retrieves advertise IEEE 802.1 Organizationally Specific TLV configuration details. |
| <base_URI>/config/running/protocol/lldp/advertise/dot3-tlv | Retrieves advertise IEEE 802.3 Organizationally Specific TLV configuration details. |
| <base_URI>/config/running/protocol/lldp/advertise/optional-tlv/management-address | Retrieves management address TLV details. |
| <base_URI>/config/running/protocol/lldp/advertise/optional-tlv/port-description | Retrieves port description TLV details. |
| <base_URI>/config/running/protocol/lldp/advertise/optional-tlv/system-capabilities | Retrieves system capabilities TLV details. |
| <base_URI>/config/running/protocol/lldp/advertise/optional-tlv/system-description | Retrieves system description TLV details. |
| <base_URI>/config/running/protocol/lldp/advertise/optional-tlv/system-name | Retrieves system name TLV details. |
| <base_URI>/config/running/protocol/lldp/system-name | Retrieves system name. |
| <base_URI>/config/running/protocol/lldp/system-description | Retrieves system description. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/description | Retrieves port profile description. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/hello | Retrieves port profile hello interval configuration details. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/mode | Retrieves port profile mode. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/multiplier | Retrieves port profile multiplier. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/dot1-tlv | Retrieves port profile advertisement TLV details. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/dot3-tlv | Retrieves port profile advertisement TLV details. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/optional-tlv/management-address | Retrieves advertise IEEE 802.1 Organizationally Specific TLV configuration details. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/optional-tlv/port-description | Retrieves advertise IEEE 802.3 Organizationally Specific TLV configuration details. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/optional-tlv/system-capabilities | Retrieves system capabilities TLV details. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/optional-tlv/system-description | Retrieves system description TLV details. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/optional-tlv/system-name | Retrieves system name TLV details. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/protocol/lldp | <profile><profile-name>(profile-name-string)</profile-name></profile> | Configures LLDP profile. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/protocol/lldp | <lldp><description>(string)</description></lldp> | Configures LLDP description. |
| <base_URI>/config/running/protocol/lldp | <lldp><hello>(unit32)</hello></lldp> | Configures LLD hello interval. |
| <base_URI>/config/running/protocol/lldp | <lldp><mode>(string)</mode></lldp> | Configures LLDP mode. |
| <base_URI>/config/running/protocol/lldp | <lldp><multiplier>(unit32)</multiplier></lldp> | Configures LLDP multiplier. |
| <base_URI>/config/running/protocol/lldp/advertise | <advertise><dot1-tlv>(string)</dot1-tlv></advertise> | Configures LLDP advertisement. |
| <base_URI>/config/running/protocol/lldp/advertise | <advertise><dot3-tlv>(string)</dot3-tlv></advertise> | Configures LLDP advertisement. |
| <base_URI>/config/running/protocol/lldp/advertise/optional-tlv | <optional-tlv><management-address>(string)</management-address></optional-tlv> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/advertise/optional-tlv | <optional-tlv><port-description>(string)</port-description></optional-tlv> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/advertise/optional-tlv | <optional-tlv><system-capabilities>(string)</system-capabilities></optional-tlv> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/advertise/optional-tlv | <optional-tlv><system-description>(string)</system-description></optional-tlv> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/advertise/optional-tlv | <optional-tlv><system-name>(string)</system-name></optional-tlv> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp | <lldp><system-name>(string)</system-name></lldp> | Configure LLDP system name. |
| <base_URI>/config/running/protocol/lldp | <lldp><system-description>(string)</system-description></lldp> | Configures LLDP system description. |
| <base_URI>/config/running/protocol/lldp | <lldp><disable>(string)</disable></lldp> | Disables LLDP. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string) | <profile><description>(string)</description></profile> | Configures LLDP profile description. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string) | <profile><hello>(unit32)</hello></profile> | Configures LLDP profile hello interval. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string) | <profile><multiplier>(nit32)</multiplier></profile> | Configures LLDP profile multiplier. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise | <advertise><dot1-tlv>(string)</dot1-tlv></advertise> | Configures LLDP profile advertisement. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise | <advertise><dot3-tlv>(string)</dot3-tlv></advertise> | Configures LLDP profile advertisement. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/optional-tlv | <optional-tlv><management-address>(string)</management-address></optional-tlv> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/optional-tlv | <optional-tlv><port-description>(string)</port-description></optional-tlv> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/optional-tlv | <optional-tlv><system-capabilities>(string)</system-capabilities></optional-tlv> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/optional-tlv | <optional-tlv><system-description>(string)</system-description></optional-tlv> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/optional-tlv | <optional-tlv><system-name>(string)</system-name></optional-tlv> | Configures LLDP optional TLV parameters. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/protocol/lldp/description | <description>(string)</description> | Configures LLDP description. |
| <base_URI>/config/running/protocol/lldp/hello | <hello>(unit32)</hello> | Configures LLD hello interval. |
| <base_URI>/config/running/protocol/lldp/mode | <mode>(unit32)</mode> | Configures LLDP mode. |
| <base_URI>/config/running/protocol/lldp/multiplier | <multiplier>(unit32)</multiplier> | Configures LLDP multiplier. |
| <base_URI>/config/running/protocol/lldp/advertise/dot1-tlv | <dot1-tlv>(string)</dot1-tlv> | Configures LLDP advertisement. |
| <base_URI>/config/running/protocol/lldp/advertise/dot3-tlv | <dot3-tlv>(string)</dot3-tlv> | Configures LLDP advertisement. |
| <base_URI>/config/running/protocol/lldp/advertise/optional-tlv/management-address | <management-address>(string)</management-address> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/advertise/optional-tlv/port-description | <port-description>(string)</port-description> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/advertise/optional-tlv/system-capabilities | <system-capabilities>(string)</system-capabilities> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/advertise/optional-tlv/system-description | <system-description>(string)</system-description> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/advertise/optional-tlv/system-name | <system-name>(string)</system-name> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/system-name | <system-name>(string)</system-name> | Configure LLDP system name. |
| <base_URI>/config/running/protocol/lldp/system-description | <system-description>(string)</system-description> | Configures LLDP system description. |
| <base_URI>/config/running/protocol/lldp/disable | <disable>(string)</disable> | Disables LLDP. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/description | <description>(string)</description> | Configures LLDP profile description. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/hello | <hello>(unit32)</hello> | Configures LLDP profile hello interval. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/mode | <mode>(unit32)</mode> | Configures LLDP profile mode. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/multiplier | <multiplier>(unit32)</multiplier> | Configures LLDP profile multiplier. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/dot1-tlv | <dot1-tlv>(string)</dot1-tlv> | Configures LLDP profile advertisement. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/dot3-tlv | <dot3-tlv>(string)</dot3-tlv> | Configures LLDP profile advertisement. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/optional-tlv/management-address | <management-address>(string)</management-address> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/optional-tlv/port-description | <port-description>(string)</port-description> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/optional-tlv/system-capabilities | <system-capabilities>(string)</system-capabilities> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/optional-tlv/system-description | <system-description>(string)</system-description> | Configures LLDP optional TLV parameters. |
| <base_URI>/config/running/protocol/lldp/profile/(profile-name-string)/advertise/optional-tlv/system-name | <system-name>(string)</system-name> | Configures LLDP optional TLV parameters. |
| DELETE URIs |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/protocol/lldp
None
<lldp xmlns="urn:Extreme.com:mgmt:Extreme-lldp" xmlns:y="http://Extreme.com/ns/rest" y:self="/rest/config/running/protocol/lldp">
<description>rest testing</description>
<hello>4</hello>
<mode>tx</mode>
<multiplier>10</multiplier>
<advertise y:self="/rest/config/running/protocol/lldp/advertise">
<dot1-tlv>true</dot1-tlv>
<dot3-tlv>true</dot3-tlv>
<optional-tlv y:self="/rest/config/running/protocol/lldp/advertise/optional-tlv">
<management-address>true</management-address>
<system-capabilities>true</system-capabilities>
<system-description>true</system-description>
</optional-tlv>
</advertise>
<system-description>Extreme BR-SLX9850-4 Router</system-description>
</lldp>
The following example uses the POST option to configure LLDP profile.
<profile> <profile-name>profile1</profile-name> </profile>
None
The following example uses the DELETE option to remove LLDP description.
http://host:80/rest/config/running/protocol/lldp/description
None
None
