Configures DHCP snooping.
| URI | Description |
<base_URI>/config/running/ip/dhcp/snooping/ |
Configures DHCP snooping. |
| GET URI | Description |
<base_URI>/config/running/ip/dhcp/snooping |
Retrieves DHCP snooping configuration information. |
| PATCH URI | Payload | Description |
<snooping><snoop-enable>true</snoop-enable></snooping> |
Enables DHCP snooping. |
<base_URI>/config/running/ip/dhcp/snooping/information |
<information><option><allow-untrusted>true</allow-untrusted></option></information> |
Enables untrusted ports to accept incoming DHCP packets. |
| DELETE URI |
<base_URI>/config/running/ip/dhcp/snooping/snoop-enable |
GET, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
<snooping xmlns="urn:brocade.com:mgmt:brocade-dhcp"
xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/ip/dhcp/snooping">
<information y:self="/rest/config/running/ip/dhcp/snooping/information">
<option y:self="/rest/config/running/ip/dhcp/snooping/information/option">
</option>
</information>
</snooping>
