dot1x
Configures, retrieves, and modifies 802.1X authentication.
Resource URIs
URI Description
<base_URI>/config/running/dot1x Configures 802.1X authentication.
GET URIs Description
<base_URI>/config/running/dot1x IEEE 802.1X port-based access control.
<base_URI>/config/running/dot1x/enable Enables global port authentication.
<base_URI>/config/running/dot1x/test Configures 802.1X readiness check.
<base_URI>/config/running/dot1x/test/timeout Configures timeout for dot1x readiness check
PATCH URIs Payload Description
<base_URI>/config/running/dot1x <dot1x><enable>(enumeration)</enable></dot1x> Configures IEEE 802.1X port-based access control and enables global port authentication.
<base_URI>/config/running/dot1x/test <test><timeout>{dot1x-readinesstest-timeout-interval}</timeout></test> Configures timeout for dot1x readiness check.
PUT URIs Payload Description
<base_URI>/config/running/dot1x/enable <enable>(enumeration)</enable> Enables global port authentication.
<base_URI>/config/running/dot1x/test/timeout <timeout>{dot1x-readinesstest-timeout-interval}</timeout> Configures timeout for dot1x readiness check.
DELETE URIs
Parameters
test timeout
Specifies the readiness test interval value in seconds. Valid values range from 1 through 65535. The default readiness test interval is 10 seconds.
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/dot1x
None
<dot1x xmlns="urn:brocade.com:mgmt:brocade-dot1x" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/dot1x">
  <enable>true</enable>
  <test y:self="/rest/config/running/dot1x/test">
    <timeout>11</timeout>
  </test>
</dot1x>
URI
The following example uses the PATCH option to configure dot1x.
<dot1x><enable>true</enable></dot1x>
None
URI
The following example uses the DELETE option to remove dot1x.
http://host:80/rest/config/running/dot1x/enable
None
None
